| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#239 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
And do all the potential issues related to the large amounts of sealant deposits necessarily mean that the cars are not still coping minor damage to various things, or suffering from minor aeration and so forth? I know oil starvation itself takes very very little time to do major damage, but its possible that minor starvation events are occurring still right? Just the shear lack of inspection by Toyota is alarming, and honestly is setting off alarm bells about this issue - its a very new car that they in theory you would want to investigate deeply so as head off potential recalls early on and have fixes for. It makes you wonder if they absolutely know about it, and absolutely don't want to officially have to inspect it. |
#240 | |
Drives: GR86
Related to the original post in this thread which showed a dipstick with crud on it...my brain just made the connection that my dipstick had stubborn bits stuck to it around ~2,500 miles. They were not present on my dipstick early on (I have photos because my car was delivered lower on oil), but I stupidly didn't think more of it and vigorously rubbed it off without documenting it. However, I did a crappy job of cleaning (or there's new build-up) because I pulled my dipstick today and see there's still (gray) stuff on it near the edge around the low oil marker. Sorry the phone photo doesn't look great. ![]() Someone else I know with a new GR86 shared with me that his dipstick has similar crud on it and he's still in his break-in period of <1,000 miles. Not sure what to make of it yet, but the dipstick should not have this foreign material on it. |
| The Following User Says Thank You to gcmak For This Useful Post: | Blighty (08-02-2022) |
#241 |
Read the warranty. Modifications beyond stock and the use of non approved parts is a guaranteed warranty denial no matter who installed them.
#242 | |
If they opt to keep things the same then it is not refreshed and yes the risk is lower. Failure can happen anyplace in the lifecylce. The valve spring recall from the 2013s had nothing to do with first run issue (there were 400,000 other cars involved) and neither does this sealant issue really. Remember they have been making near identical 2.4s for over four years now. If it had been an injector issue it could be attributed to new processes but it is exactly the same bottom end in the Ascent engines.
#243 | |
Drives: '23 BRZ Limited
I really think some of you are blowing this WAY out of proportion.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Opie (08-02-2022) |
#244 | |
Drives: 2023 BRZ Allocation
Thanks for the info. |
#245 | |
Drives: '12 C63 P31, '23 GRC
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#246 | |
Drives: 2022 GR86
Astrologers proclaim the week of checking dipstick tips.
Follow the build thread for my GR86!
#247 |
Drives: 1993 Caterham HPC Evo
| The Following User Says Thank You to Stephen W. For This Useful Post: | Ultramaroon (08-01-2022) |
#248 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | OkieSnuffBox (08-01-2022) |
#249 | |
Drives: frs
| The Following User Says Thank You to Teseo For This Useful Post: | Ultramaroon (08-01-2022) |
#250 |
Drives: '22 BRZ
This is some scary, but informative, info. I'll keep an eye on the updates, but not going to let this scare me from enjoying my car. It's from an early batch (delivered 1/22) and currently sits just over 3000 miles. Oil changed at 1000 miles with OEM oil/filter. Only mod to the drivetrain is a cat-back. Car has zero issues. Repeatedly checking the dipstick - clean as a whistle. 5-year/60k mile warranty will have my back should anything happen. Happy to provide data for those attempting to correlate. Until then, party on dudes.
| The Following User Says Thank You to Panda Grahams For This Useful Post: | diga (08-01-2022) |
#251 |
Drives: 2005 Toyota Camry
this is one of the reasons why I always do used oil analysis on every play car I own, because I want data to back up my claims in case I need to get warranty coverage.
#252 |
Drives: 22 BRZ limited
Should I change my cars spirit animal from Darkness to Megumin?
| The Following User Says Thank You to dragoontwo For This Useful Post: | Jdmjunkie (08-01-2022) |
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
