| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#183 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Tim Bits with Voodoo Donut guts, a pretzel through the heart
and grinding spark ash with Geddy doing that thing.
"I gotta rock." -- Charley Brown |
#184 | |
Drives: zd8 brz
Subarus have been on the road longer and likely have more miles than gr86's do. If it has to do with early production models, id expect early model BRZ's to have already had issues, which i havent heard of any UNLESS subaru is sabotaging gr86's ![]()
#185 | |
Drives: 23 BRZ
This thread's subject line is also confusing. When I saw "seal packing" I did not immediately think "oil pan sealant." I was thinking of an engine seal, like the rear or front main seal. |
#186 |
Drives: _
Just an FYI, some (if not all) OEMs test their engines on the dyno with oil pickup tube slightly clogged, just for this kind of scenarios. I don't know if Subaru/Toyota does it, but since I know GM does it, I can confidently assume that Japanese OEMs do it too.
Now the question becomes - what percentage of blockage is off limits. |
#187 | |
Drives: GR86
When I said "never underestimate the power of ignorance" what I meant was that due to the gulf between what you understand and what someone else understands, and the limited capacity to accurately bridge that gap, other people's ignorance can exert considerable power. Often in your favor. Now I'm not a lawyer, but I could imagine a scenario where an attorney could present a case that Toyota cannot reasonably deny a warranty claim for a "lightly tracked" car when they themselves encourage people to track the car. There may be a significant difference between HPDE and autocross, but the point is whether or not Toyota's lawyers can explain that well enough to a judge for that judge to side with them and - more importantly - whether Toyota is CONFIDENT that their lawyers will succeed and NOT result in a ruling that opens them up to significantly-increased warranty costs. If that case doesn't go their way, everyone who races their car and then would normally get denied a warranty claim now has a legal basis to demand Toyota fix their cars. It may get worked out in Toyota's favor months or years from now, but in the meantime Toyota is burning money to fight it in court. It's simpler, easier (and less evil) for Toyota to just fix the car. The owner(s) simply need to push hard enough that Toyota would rather pay a little to make the problem go away. |
#188 |
Ok we have been through all this before but I guess it needs to be discussed again.
The car is heavily advertised as track ready, they offered free track days, hell it has a button in it clearly labeled “track”. The warranty wording is “ Misuse-for example, racing & competitive events, off-roading or overloading”. It may be semantics but driving your car on the track is not racing nor a competitive event. They don’t care if your car was casually tracked and the wording of the warranty gives a clear out for you to do so as long as it wasn’t an organized and recognized race event of course. What they are using is the “abuse” clause of the warranty. When they pull data and find multiple over revs, high temperatures or excessive Gs they suddenly have something they can play with. Doesn’t matter if those occurred on a track or the street that is what they can use to deny coverage IF it could cause the issue. I guess the only answer is to go to the track as they actively promote and even encourage and then just drive around like a granny.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Opie (07-31-2022), WolfpackS2k (08-01-2022) |
#189 |
Drives: 2022 MT Neptune GR86 Prem.
#190 | |
Drives: GR86
My point is simply that there's a really good chance that, with minimal-to-no personal expense, you can involve a lawyer that may trigger a "just make the problem go away" response from the dealership. IMHO, it's worth a shot. It matters less whether you can win in court compared to whether Toyota/dealership believes they can win for less cost than just doing the repair. Obviously, if someone gets a lawyer that lawyer will be able to offer infinitely more-sound legal advice than I can, and they can help you determine the best course of action. Maybe it's just a bluff, maybe there's a solid reason not to bluff, and maybe the lawyer is confident it's not a bluff at all and you have a solid case. That's for the lawyer to gauge. I'm just saying that there is definitely a potential where all it takes is the presence of a lawyer to change the minds at the dealership in favor of warranty repair. Maybe not. Maybe there's a middle ground where they counter-offer with a discounted repair. But the core of the point is that without talking to a lawyer the chances are zero that they'll change their mind. |
| The Following User Says Thank You to Spektyr For This Useful Post: | Tcoat (07-31-2022) |
#191 | |
#192 |
Drives: zd8 brz
I spoke Too soon about brz failures
From japan: Car delivered September 1, 2021 A little under 11k miles 6 track days (7-8 hours of total run time) 8 oil changes since taking delivery https://twitter.com/kakuni67174437/s...7LAn2w2Y3nq_zQ |
#193 |
Drives: 2022 GR86
Another guy just dropped his pan... 01/22 Build Date. 6,XXX miles.
Maybe we need a "Show us your oil pickup!" thread.
#194 |
Drives: '13 Scion FR-S, '12 Ford Fiesta
#195 |
Drives: 2022 BRZ sport-tech
So do we have any indication if the excessive RTV is from the oil pan, timing cover or both?
Clearly this is wide spread problem, just we do not know when/if it was fixed or if applies to all car made up to that point or random samples.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#196 |
Drives: 2015 FR-S
Did he have a problem. Or just precaution. I think an easier way would be to just get a oil pressure gauge put it on the oil dummy sensor location and have everyone mark their oil pressure at 4K RPM/200F
Anything less than 60psi with factory 0-20W fill and you need to “drop your pants” ![]() |
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
