| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2012 Toyota 86 GTS
Damage to front left wheel and lower control arm
Toyota 86 2012 GTS (front wheel damage) help
Recently hit a curb and rock under the front left hand side wheel of my 86, resulting in a fair bit of damage, i was wondering if anyone could assess these photos and let me know anything more than i do myself. Thank you. |
#2 |
Drives: 2013 frs base
Are we looking at the passenger side: ie Right front? A minimum would be replacing the lower control arm, spindle, tie rod, sway bar link, and strut. Being a 2012, you would probably replace both fronts, if not all 4 struts. That's just the damage that's seen in the pictures. I can't tell if anything else is bent. To be honest, if you are asking these questions, you probably should take it to a shop.
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | NoHaveMSG (07-24-2022), soundman98 (07-24-2022) |
#3 |
ProCrastinationConsultant
It's going to need and alignment anyways, I would say least get a shop to look it over
#4 | |
#5 | |
It's hard to know if frame/crossmember is bent where the lca attaches. Someone experienced with suspensions may be able tell by looking at it in person. |
| The Following User Says Thank You to blsfrs For This Useful Post: | soundman98 (07-24-2022) |
#6 | |
Yeah all good, thank you, so is there any chance it’s written off, or like an expensive job? Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to sam p For This Useful Post: | blsfrs (07-25-2022) |
#7 |
it really depends on if that curb/rock damaged anything else underneath the vehicle
| The Following User Says Thank You to soundman98 For This Useful Post: | blsfrs (07-25-2022) |
#9 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
With that type of damage and the possibility of bent tie rods, I'd probably take a look at the steering rack too to make sure it isn't damaged. The force of the impact may have been transmitted "down stream" past the tie rods into the rest of the steering system.
| Need A Left Front Control Arm Near Portland (PIR) Today | Totemo_Hayai | Northwest | 0 | 07-11-2020 06:50 PM |
| Need left driver side lower control arm | jrsd1 | Want-To-Buy Requests | 0 | 08-21-2015 11:38 AM |
| WTB: OEM Control Arms: Front Left & Back Left | norcalpb | Want-To-Buy Requests | 0 | 02-26-2015 08:55 PM |
| TRD Style ABS Front Bumper Lip, CFW Trunk Spoiler, LH Lower Control Arm Front | STS-V | Want-To-Buy Requests | 0 | 03-18-2014 03:42 PM |
| WTB: Front Lower Control Arm and Rear Upper Control Arm | YDNA | Brakes, Suspension, Chassis | 0 | 11-10-2013 04:40 AM |
