Drives: 22 Neptune
Eyesight can’t see anything after mirror install
Hey everyone. I took my car in to get the stock mirror replaced by an auto dimming one. After I did this, eyesight keeps telling me it can’t see anything. Sometimes it will work for like 20 seconds after turning the car on, but then once again it says it can’t see anything. I cleaned the cameras with a micro fiber cloth and they look fine. I’m wondering if there’s an easy fix or if I need to take it in
#2 |
Drives: 22 BRZ limited
If the dealer did the work and it's not working, take it in. My guess is they didn't get a connector properly reconnected.
| The Following User Says Thank You to dragoontwo For This Useful Post: | Dadhawk (07-18-2022) |
#3 |
Drives: 22 Neptune
#4 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Don't they have to re-calibrate everything after messing with that and/or the window?
"I gotta rock." -- Charley Brown |
#5 |
Drives: 22 Neptune
#6 |
Drives: _
On a side note, is the Eyesight standard on all trim levels? What about Toyota versions?
#7 |
#8 |
Is the new mirror exactly the same size as the old one? Even slightly bigger and the cameras may be catching an edge. Those cameras do not play well with even the slightest deviation from the norm.
Don’t think it would be wired into the system but it is possible.
| DIY: APR Door Mirror Install | RallySport Direct | DIY (Do-It-Yourself) Guides | 53 | 04-26-2019 03:08 PM |
| Probability of Eyesight Tech in 2018 BRZ | towch | BRZ First-Gen (2012+) — General Topics | 29 | 08-24-2017 09:45 AM |
| Homelink Mirror Install/Question | JGalp | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-30-2015 11:14 AM |
| DIY JDM frameless mirror install | ayau | DIY (Do-It-Yourself) Guides | 8 | 01-10-2014 08:36 PM |
| How to install Homelink mirror? | Grimlock | Electronics | Audio | NAV | Infotainment | 10 | 06-10-2012 06:07 PM |
