Old 07-16-2022, 09:31 AM   #19531
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Hood struts. One of my favorite mods.
Old 07-20-2022, 10:39 PM   #19532
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Fitted some Verus hood vents. I don`t know if they do anything.
Old 07-21-2022, 04:55 PM   #19533
norcalpb
norcalpb's Avatar
Well, airflow will be significantly reduced with those rain guards.
Old 07-21-2022, 05:55 PM   #19534
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
I plan to remove the guards when tracking.
Old 07-21-2022, 06:18 PM   #19535
They raise temps underneath.
Honestly, I don't know. I never considered tunnel temps before reading @rice_classic's tales of melted CV boots and hot transmissions.
Old 07-21-2022, 08:18 PM   #19536
norcalpb
norcalpb's Avatar
That’s an interesting thought, I’ve never really thought about how incoming air is designed to continue through the engine bay into the tunnel, cooling the transmission and other various drivetrain pieces in the process. Or whatever fwd has aft of the engine.
It would be cool if a company made a vent like the Civic Type R has. I BELIEVE it’s purpose is to ram air straight into the transmission tunnel. This then creates a low pressure area or some other magic and can then begin to suck the engine bay heat into the transmission tunnel.
Old 07-21-2022, 09:40 PM   #19537
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
I did a search and came up with Zilch. Any ideas where? I`d like a read.
Old 07-21-2022, 11:01 PM   #19538
Here's some discussion in his build thread. I have to find where he discusses transmission temps. Honestly, the possible detrimental effect of venting the hood is pure theory. The underside aero is all deliberate, and the exhaust heat must be shed. If I was considering a vented hood, I would take readings at key areas. One in particular is the hot spot in front of the right side sway bushing. Then I'd pull the hood and repeat the test.
Maybe there's no difference underneath. I almost feel bad for mentioning it.
Old 07-22-2022, 12:00 AM   #19539
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Okay thanks for that. I did read a thread by Verus Engineering on their temps with and w/o the vents. They measured mild temp drops around the coil pack areas.
The main reason I want some heat relief from the vents is the freshly installed Oil Cooker.
Old 07-22-2022, 12:04 AM   #19540
Oh shit, yeah. That's a no-brainer.
Old 07-22-2022, 11:38 AM   #19541
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is basically right where my duct sits. It pulls enough air it actually causes a weird swirl pattern on my windshield in the rain.
Old 07-25-2022, 12:00 AM   #19542
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Extended the middle vent rain guards so rain doesn`t pour all over the turbo. Outer vents are fine. Restriction is not an issue as they get removed at the track.
Old 07-26-2022, 05:41 PM   #19543
iag48st
Drives: 10Series 0945
Im pretty sure I read in one of the known publications, that the hood vent is for ECU temps.
iag48st is offline   Reply With Quote
Old 07-26-2022, 09:06 PM   #19544
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Couldn`t help myself. I extended all the rain guards,for better run off clearance, and painted them with a brush. Camera actually looks worse than by eye. Etch primer first then satin black polyurethane.
