Old 04-08-2022, 03:16 AM   #813
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by jeepmor View Post
Any 10mm fans?
I don't think so. This is 20mm.
soundman98 (04-08-2022)
Old 04-09-2022, 12:02 PM   #814
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Originally Posted by wolffbite View Post
Well I finally got my ass in gear and sent off my firearms licence application... now the waiting game!
I can window shop rifles in the meantime. I'm interested in a .308 for hunting deer and potentially bigger game in the future, and a .22 for some cheaper plinking.
Any recommendations, or ones to avoid altogether? Keep in mind I'm up in Canada so we don't get as much cool stuff.
If you haven't already you should join Canadian Gun Nutz.
https://canadiangunnutz.com/
Everything you need to know about weapons in Canada can be found in the forums with some digging. Lots of stuff for sale. The main guys are good to filter out the true nut cases and you'll find some very knowledgeable people willing to help you make the best choice.
Good luck.
The Following 2 Users Say Thank You to Stephen W. For This Useful Post:
soundman98 (04-09-2022), wolffbite (04-09-2022)
Old 07-12-2022, 10:42 PM   #815
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
So as of today... my application has gone through initial processing!
Based on what I've been reading on Canadiangunnutz I won't hear anything further until fall at the earliest.
wolffbite is offline   Reply With Quote
Old 07-13-2022, 08:05 AM   #816
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Form 4s (for two YHM R9s) have been certified through Silencershop's "Full Auto" system! WHoo hoo!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 07-14-2022, 06:12 PM   #817
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
On kinda of a lever journey now... recently got a used Marlin 30AS from early '90s in 30-30 Win and modded/rebuilt to a more modern multi-role gun:
Can run it just open sights (Skinner winged/ghost ring rear with .6" high x 3/8" wide front), with an M21 holographic and Holosun laser (as shown), with a long eye relief 2-7×32 pistol scope, or with a night vision scope. Have only put 60 rounds through it so far, but have it currently zeroed for 50yards and it is the most fun have had shooting.
What currently have incoming is a decade old Miroku/Winchester 1885 high wall BPCR Limited Series Target single shot lever rifle in 45-70. Will be reloading with good higher BC 405grn to 600grn bullets for it since factory ammo for 45-70 is quite expensive ($3-$4 per round) and usually only FN bullets in 300-405 grain range. Only change am doing is adding an MVA Soule rear sight and globe front sight to it... will look similar to this one:
http://www.bpcr1885.net/long-range-bpcr/
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 3 Users Say Thank You to Vracer111 For This Useful Post:
Dadhawk (07-15-2022), NoHaveMSG (07-14-2022), Wally86 (07-15-2022)
Old 07-15-2022, 09:10 AM   #818
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Never seen optics on a brush gun. Interesting.
Old 07-15-2022, 03:39 PM   #819
Vracer111
Vracer111's Avatar
Here it is both naked and with the Burris pistol scope in scout configuration (need to get it zeroed @ 100yards):
Really like it with the Mepro M21 and Holosun laser since it's quick acquiring and absolutely nailed steel gong as quick as could run the lever. Should work fine to about 100 yards and with Burris scope should be good to about 200 yards. For anything past that my inclination would be using my new lightweight precision bolt rifle, the Sig Cross in .308:
Dadhawk (07-15-2022), NoHaveMSG (07-21-2022), Wally86 (07-17-2022)
Old 07-21-2022, 02:38 AM   #820
Vracer111
Vracer111's Avatar
Something I got in the other day, modern version of a classic:
humfrz probably remembers when the original version was introduced...
It's the Winchester 1885, specifically a High Wall .45-70 Govt. BPCR Limited Series Target version built by Miroku for Winchester about a decade ago. Have custom Soule style rear and aperture w/level front sights currently being made for it by Montanna Vintage Arms (MVA) which should be done within a month. Will have nearly 290MOA elevation and 90MOA windage adjustment available if I should ever want to push it long range... will be working up hand loads for 405gr FN and 535grain Postell cast bullets once I harvest the cases from some factory PRVI .45-70 I have coming in. Might just have to get a scope for it in the mean time...
Dadhawk (07-21-2022), NoHaveMSG (07-21-2022), Wally86 (07-21-2022)
Old 07-21-2022, 11:27 AM   #821
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
One of my buddies just picked up a Cross. They are very nice, surprisingly light for as stout as it looks. Pretty sure it is lighter than my Ruger precision rimfire. He just has an ACOG on it now till he gets a new optic for it.
Old 07-21-2022, 06:59 PM   #822
Vracer111
Vracer111's Avatar
They are listed as 6.5lbs from factory for the .308 version with 16" barrel. Without scope, mine weighs in @ 7lbs 9oz with Masterpiece Arms EVG grip, MDT ACIS 10rd metal mag (4.1oz heavier than the stock Magpul 5 rounder), Magpul quick release socket mount, bipod mount, & full compliment of grip panels on all four sides, and Precision Armament Hypertap muzzle brake. Add on the Hawke Frontier 4-20×44 scope, low Leupold PRW2 rings, and Kinetic Development Group SIDELOK rail it weighs 9lbs 8oz. That's quite a bit lighter than the Savage .308 action/24" heavy barrel in an MDT TAC21 chassis it's replacing (which comes in @ ~15lbs). Switched from fixed rings to the new quick release system & lower rings so could have option of switching to nightvision scope when needed.
The fixed 1" Leupold Backcountry aluminum rings that were originally on the Sig Cross can be used with 1" to 3/4" delrin spacer inserts on a vintage WW2 style M1903A4 rifle sniper scope (Hi-Lux M73G4) for mounting on the 1885 Winchester before the Soule sights come in. Should be a decent and robust enough optic and a look pretty good paired with the 1885 I think - not an out of place aesthetic like a fully modern scope would give.
Also just got in the 45-70 Govt. 535gr postell bullets... here's a size comparison of one with a .308 Win 168gr Hornady Match BTHP bullet...
Dadhawk (08-01-2022), NoHaveMSG (07-21-2022), Wally86 (07-21-2022)
Old 08-01-2022, 12:34 AM   #823
wolffbite
Just the tip
wolffbite's Avatar
Hooray!
The Following 2 Users Say Thank You to wolffbite For This Useful Post:
soundman98 (08-01-2022), Stephen W. (08-01-2022)
Old 08-01-2022, 07:05 AM   #824
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Hooray!
Congrats!!
Old 08-01-2022, 07:38 AM   #825
Every time I see the "business end" of a bullet, etc all I can think is after so many millennium most of our best weapons are still just better ways to throw a "rock".
Where's my phaser?
The Following 5 Users Say Thank You to Dadhawk For This Useful Post:
Capt Spaulding (08-03-2022), DrinkenBRZ (08-16-2022), soundman98 (08-01-2022), Spuds (08-01-2022), Wally86 (08-01-2022)
Old 08-15-2022, 02:46 PM   #826
wolffbite
Just the tip
wolffbite's Avatar
Hooray!
And I got my license in the mail on Friday
I have since done some shopping... I ordered a CZ457 Varmint 22LR. Very very excited to get out there and plink to my hearts content, and practice for grouse season!
NoHaveMSG (08-15-2022), soundman98 (08-15-2022)
No Politics or Religion discussions please Hachiroku Off-Topic Lounge [WARNING: NO POLITICS] 1 01-07-2021 12:50 PM
Product Showcase - Auto Finesse Tripple - All In One DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 11-16-2012 04:28 PM
Product Showcase: Menzerna Fast Gloss 400 DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-16-2012 09:14 AM
FR-S vs. 370z, end all be all of discussions OldSkoolToys FR-S / BRZ vs.... 1491 09-25-2012 06:58 PM
Are politics off limits? Longhorn248 Site Announcements / Questions / Issues 35 05-16-2012 10:24 PM
