Old 07-18-2022, 09:52 PM   #1
jtfuruyama
Drives: 2013 subaru brz
replacement studs for ichiba wheel spacers v2
hi folks, anybody know what kind of studs the ichiba v2 wheel spacers use? tire shop damaged a couple nuts and i ended up with a broken stud on two spacers. the thread is the same as the stock stud, but at least the knurl is a different width. not sure how to approach getting a like for like replacement. i have 20mm in the front and 25mm in the back. both studs appear to be the same length. thanks in advance
jtfuruyama is offline   Reply With Quote
Ichiba 5mm Spacers w/Studs XanRules Wheels and Tires 14 04-03-2018 03:10 AM
Ichiba 10mm hubcentric spacers with extended studs protpibe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-01-2015 03:21 PM
Eibach Sport Pro Springs, 10mm/5mm Hub centric Spacers, Ichiba extended studs bryan767 Brakes, Suspension, Chassis 9 04-26-2015 07:40 PM
FS: 20mm and 25mm Ichiba wheel spacers Jyn Brakes, Suspension, Chassis 12 11-17-2014 04:54 PM
