Old 07-14-2022, 05:04 PM   #1163
hedtrip
hedtrip's Avatar
Drives: 2013 toyota 86
So I got my TB all back together & then noticed the car sounded a lil off. Cracked my cat back almost all the way around. But nothing a welder can't fix.
hedtrip is offline   Reply With Quote
The Following User Says Thank You to hedtrip For This Useful Post:
RedReplicant (07-14-2022)
Old 07-14-2022, 10:53 PM   #1164
Ebush
Drives: 2017 Hot Lava 86
Pretty much identical to how mine cracked. Mine actually cracked all the way around at that location though. It also cracked nearly all the way around the weld at the muffler, and at the flange for the header.
Ebush is offline   Reply With Quote
Old 07-15-2022, 10:27 AM   #1165
redlined600
redlined600's Avatar
Drives: Fr-s
Thinking out loud, I wonder if an engine torque damper would help control the movement of the engine and reduce some of the exhaust issues.
redlined600 is offline   Reply With Quote
Old 07-15-2022, 04:27 PM   #1166
RedReplicant
Drives: None
I dunno, I am ordering these 70a and crossing my fingers. A lot less area to twist on, but I am worried they won't high enough for pan clearance.
I was going to do the red 90a version, but I looked at the similar style 70a Supermiata mounts that I used in my SuperMiata and they were already super aggressive. Track car, but come on, need to be able to see out of the mirrors.
https://www.iagperformance.com/iag-s...sti-04-08-fxt/
RedReplicant is offline   Reply With Quote
Old 07-15-2022, 09:40 PM   #1167
RedReplicant
Drives: None
Yay, more oil temp stuff.
Turns out, KPower put the oil temp input on SPI, rather than AVI. Haltech has a support note about this:
https://support.haltech.com/portal/e...rature-sensors
When using temperature sensors on AVI inputs, the calibration Haltech provides is correct. This is because the AVI's in the Haltech use a 1k pullup to 5 volts.
When using temperature sensors on SPI inputs, the calibration Haltech provides is incorrect. This is because the SPI's in the Haltech use a 10k pull to 5v.
I noticed that we have an empty AVI input available, so I figured I'd just re-pin it quick, this means moving pin 10 on the small/26pin connector to pin 13. Haltech gives us a nice pinout report with wire colors that should make it easy.
KPower was like nah and threw random colors at the ECU connectors. Pin 13 was also already populated by an orange wire. Where does it go? Who knows.
Side note is that the unassigned SPI1 goes to the connector that KPower uses for their flex fuel kit.
I tried the Haltech official sensor calibration (https://www.haltech.com/product/ht-0...rature-sensor/) and the sensor is reading as 140c maxed out at rest but not disconnected. Assigning the sensor back to the SPI input in Haltech reads as disconnected, which is expected.
A lot of the calibrations for the Bosch Motorsports sensor AKA Bosch 0261230340 sensor AKA Mazda PY8V-18-541B are listed with a with 4.6k pull up resistor included in the values which is why those don't work for us.
This is pretty annoying.
The Following User Says Thank You to RedReplicant For This Useful Post:
endless_pain (07-18-2022)
Old 07-16-2022, 04:16 AM   #1168
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
It's a motor that was designed to have a counter-balancer, installing the type s oil pump removes that, then add revving it higher on top. It's not FRS/BRZ specific.
*edit: Beat^
So out of curiosity, does a stock K20A2 have vibrations since it comes with this oil pump stock?
Would a fluidampr pulley help any with vibrations?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 07-16-2022, 11:55 AM   #1169
redlined600
Drives: Fr-s
I'm assuming not since it was sold like that from the factory, I drove an rsx-s years ago and it didn't stand out. However the stroke is like 86 vs 99 iirc.
The Following User Says Thank You to redlined600 For This Useful Post:
NARFALICIOUS (07-16-2022)
Old 07-16-2022, 08:14 PM   #1170
RedReplicant
Drives: None
Well, at least I've got an answer. There is interference from DBW to other sensors, which is what is causing the oil/temp sensor reading issues. I'm wondering what else is affected by this.
Old 07-16-2022, 08:44 PM   #1171
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Interesting. I’ll have to see if mine does the same.
captain awesome is offline   Reply With Quote
Old 07-16-2022, 09:22 PM   #1172
RedReplicant
Drives: None
It might be more obvious when the car is up to running temperature since the scaling on the temp sensor is pretty exponential as you get hotter.
Old 07-17-2022, 02:43 PM   #1173
ML
ML's Avatar
Drives: 13 White MT FR-S
is your sensor grounds good? One of the benefits of using the SPI is that its shielded, so if the shielding is not grounded correctly it could get the interference like that.
Old 07-17-2022, 04:46 PM   #1174
RedReplicant
Drives: None
I haven't looked at the motor harness yet, but the harness from the haltech to the jumper board isn't using shielded wire where indicated. Stock BRZ harness from the jumper board to the engine bay connector may or may not be shielded too.
I corner weighted my car today, it went from 2901lb with the Harrop/FA20 to 2687lb after the swap. Ballpark it at about a 200lb weight loss.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (07-18-2022), Irace86.2.0 (07-17-2022)
Old 07-18-2022, 05:44 PM   #1175
FrickingReallySlow
Drives: 2015 FR-S
So the Kpower kit uses the engine mounts from the WRX? would our FA20 STI mounts work or perhaps the group N STI mounts for STI.
FrickingReallySlow is offline   Reply With Quote
Old 07-18-2022, 05:48 PM   #1176
RedReplicant
Drives: None
I'm not real familiar with Subaru stuff, but I think what they use comes from the 02-07 WRX. The STI version of that will work and what I ordered should work too, but we will see.
KPower says the STI mount just added NVH, but I am more worried about keeping things from moving. Good idea? Bad idea? I dunno.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 04:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 02:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 02:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 05:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 02:00 AM
