go_a_way1
Old 07-11-2022, 09:39 AM   #1373
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Some mornings it's easier for me to communicate using pictures of my cat.
The Following 10 Users Say Thank You to ScoobsMcGee For This Useful Post:
Dadhawk (07-11-2022), NoHaveMSG (07-20-2022), pope (07-11-2022), soundman98 (07-11-2022), spike021 (07-11-2022), Spuds (07-11-2022), Stephen W. (07-11-2022), Tcoat (07-11-2022), wbradley (07-26-2022), wolffbite (07-11-2022)
Old 07-14-2022, 02:13 AM   #1374
dpfarr
Drives: BRZ ts
Does anyone use soft crates in their twin? Took Bruno to the lake after work and he was anxious until he laid across my arms. Sternum pinning my arm between him and center console, still able to shift with wrist articulation. Neck drooped over steering arm. Comatose. If not this, pacing the cabin. Less safe.
dpfarr is offline   Reply With Quote
The Following User Says Thank You to dpfarr For This Useful Post:
wolffbite (07-14-2022)
Old 07-14-2022, 09:24 AM   #1375
new2subaru
Weight Weenie
Drives: 15 FR-S
Yes, we used soft crates with all of our 3 pups until they learned to stay in the rear. The soft crate calms them and makes it feel den like. We do not use any restraints, dividers now. Probably should but we don't.
Having animals in the front is a no go for me. Too much of a distraction.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
Dadhawk (07-14-2022), dpfarr (07-14-2022)
Old 07-14-2022, 01:06 PM   #1376
spike021
spike021's Avatar
Sooo nothing has really worked for Haru, except my latest experiment.
I use:
1. Seatbelt tether (it buckles in and clips to his collar/harness)
2. A similar divider to this: https://www.amazon.com/dp/B06XKH4C9F
The problem with our car and most of these dividers/hammock things is that they're made with the expectation that every car has anchor points behind and at the bottom of the front seats. As far as I've been able to tell, the twins do not have those anchors.
This means the bottom of the mesh divider hangs loosely. For Haru at least, he's an escape artist, so that wasn't quite enough to contain him.
What I ended up doing was grabbing two spare 5lb weights. I tied the bottom anchor straps of the divider to them. I then basically wedged them between the back bench and the back of each front seat.
For the most part that worked well enough. But, like I said before, Haru is an escape artist. The sides are still fairly loose (either that or I haven't figured out the right adjustment to make them taut and flush to the sides of the seats). So Haru would still squeeze through.
So then I draped a blanket over it that fills all the extra space. Now Haru has been behaving MUCH better. He's gotten calmer on short drives now, but it's still a work in progress.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 3 Users Say Thank You to spike021 For This Useful Post:
dpfarr (07-14-2022), soundman98 (07-14-2022), wolffbite (07-14-2022)
Old 07-14-2022, 01:13 PM   #1377
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Yep I use a soft carrier that is raised up off the front passenger seat for my girl.
She is clipped into it with her harness, and is quite content to be up higher and able to look out as we drive around. Though she typically falls asleep even during short car rides.
Kurgo booster Journey model.
wolffbite is offline   Reply With Quote
The Following 3 Users Say Thank You to wolffbite For This Useful Post:
dpfarr (07-14-2022), McMCOO (07-25-2022), NoHaveMSG (07-20-2022)
Old 07-14-2022, 01:23 PM   #1378
Pretty innovative solutions to "Small Dog World" problems. My dogs stay where they are put because they are too big to roam!
NoHaveMSG (07-20-2022), soundman98 (07-14-2022), wolffbite (07-14-2022)
Old 07-14-2022, 01:32 PM   #1379
spike021
spike021's Avatar
Especially tough just having the one car. I think my situation could've been a bit easier if I had a more practical (lol I always thought this was already a very practical car) second car, like a four-door sedan. Even just a Corolla or some other basic car.
Without this kind of setup, Haru was able to reach the front and keep me from shifting or once or twice hit my arm while I was holding the wheel going 70-ish on the freeway .
Old 07-14-2022, 01:41 PM   #1380
We've had two different Newfies since I had my 86. Both have travelled in my car, and MomHawk's Mustang for short rides (like to the Vet or boarding). Usually we haul them around in the Suburban though, where they typically go to the back seat and curl up. If they want to look out the window they sit in one of the middle seats and we roll down the window.
I posted this on page 4, but this is Bella, the larger of the two, checking out my car.
spike021 (07-14-2022), wbradley (07-26-2022)
Old 07-14-2022, 02:58 PM   #1381
dpfarr
Drives: BRZ ts
I definitely agree having animals in the front isn’t safe, and having him lay across me is an exacerbated safety concern. Him being calm and predictable in that state is at least more safe than his oafish 50 lb frame pressing into while we’re moving faster than 20mph.
The center ridge is def an issue. My girl can sorta get comfortable in there. She’s 100% more calm though. I think the seats can lay almost flat right? Soft create atop folded down seats?
[edit]
He jumped off the edge of the tub and didn’t survive upon impact.
Old 07-14-2022, 04:20 PM   #1382
Awww... Long trip for such short legs.
Old 07-20-2022, 11:01 PM   #1383
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Rex.
The Following 4 Users Say Thank You to gen3v8 For This Useful Post:
Dadhawk (07-21-2022), NoHaveMSG (07-20-2022), spike021 (07-22-2022), wbradley (07-26-2022)
Old 07-21-2022, 01:23 AM   #1384
dpfarr
Drives: BRZ ts
Going to start obedience training soon. This dude made so much mischief today.
The Following 7 Users Say Thank You to dpfarr For This Useful Post:
ACT86 (07-21-2022), Dadhawk (07-21-2022), NoHaveMSG (07-21-2022), spike021 (07-22-2022), Ultramaroon (07-21-2022), wbradley (07-26-2022), wolffbite (07-25-2022)
Old 07-21-2022, 07:28 AM   #1385
Originally Posted by gen3v8 View Post
Rex.
What a handsome dog. Is he a specific breed?
Old 07-21-2022, 10:50 AM   #1386
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
A Japanese spitz 5yo
The Following User Says Thank You to gen3v8 For This Useful Post:
Not another BRZ vs WRX thread... stayclam BRZ First-Gen (2012+) — General Topics 5 02-28-2012 02:58 PM
Honda to show off EV plug in concepts at Tokyo Auto Show Dark Other Vehicles & General Automotive Discussions 4 11-10-2011 08:34 PM
Subaru to Show BRZ Concept w/ Body at L.A. Show; More Details Emerge on BRZ and FR-S Hachiroku BRZ First-Gen (2012+) — General Topics 77 09-27-2011 10:15 PM
FT-86 doesn't show at 2010 New York Auto Show Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 30 04-02-2010 05:17 PM
