Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-12-2022, 05:19 PM   #1
Grosbard
Drives: 2022 BRZ coming
Aircon effectiveness
Hi all! I would like to hear your experiences: Do you find the Aircon to be a little on the weak side? My experience with modern and modern-ish cars is that they get freezing cold when the Aircon is cranked up (beyond the midway setting point), so usually I'm at setting 1 or 2 (out of 4) for extended driving. But with the (2022) BRZ I find that I have to crank up to midway or higher on hot days in order to not be uncomfortably warm. I would like to hear other people's experience so I can figure out of if it's a common issue. Thanks!
Grosbard is offline   Reply With Quote
Old 07-12-2022, 05:32 PM   #2
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
I set mine to full auto and just adjust the temp. The AC for me has been really good and usually keep it 71-74 and I live in FL where we've been upper 90's low 100's daily. No issues with AC keeping up.
MacSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to MacSpeed For This Useful Post:
636 (08-18-2022), Grosbard (07-13-2022)
Old 07-12-2022, 05:47 PM   #3
Code Monkey
Drives: Subaru BRZ
Cold as balls on mine.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Old 07-12-2022, 06:14 PM   #4
jvincent
jvincent's Avatar
No issues here.
On my 2013 the AC was weak and I needed to add some coolant to it.
The Following User Says Thank You to jvincent For This Useful Post:
Old 07-12-2022, 07:05 PM   #5
otter
Drives: 22 BRZ
In Texas where we've already had 30+ days over 100 this year - blows super cold and has no issue keeping up. I just leave it on automatic mode at the temp I like (71-72). I do have good quality ceramic tint all around.
otter is offline   Reply With Quote
The Following User Says Thank You to otter For This Useful Post:
Old 07-12-2022, 08:49 PM   #6
DylanJZA
DylanJZA's Avatar
Drives: GR86 Premium AT Trueno Blue
it's incredible on mine... thing gets down to set temp FAST
DylanJZA is offline   Reply With Quote
The Following User Says Thank You to DylanJZA For This Useful Post:
Old 07-12-2022, 08:50 PM   #7
AK2112
AK2112's Avatar
Drives: 22 BRZ
Really cold.
AK2112 is offline   Reply With Quote
The Following User Says Thank You to AK2112 For This Useful Post:
Old 07-12-2022, 10:51 PM   #8
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Drivers side was blowing warm air last month, blowing 42 degrees now after adding a 1/2 can of freon.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Old 07-12-2022, 11:06 PM   #9
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Did you press the "Max A/C" button? I made that mistake too already lol, didn't realize there was 2 different A/C modes.
Midnightsky is offline   Reply With Quote
The Following User Says Thank You to Midnightsky For This Useful Post:
Old 07-13-2022, 12:31 AM   #10
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
Max A/C is just A/C with recirculation instead of sucking air in from outside.
Lelandjt is offline   Reply With Quote
The Following 2 Users Say Thank You to Lelandjt For This Useful Post:
Grosbard (07-13-2022), Midnightsky (07-15-2022)
Old 07-13-2022, 05:19 AM   #11
mike2100
mike2100's Avatar
Drives: 23 BRZ
Yup, and "auto" will automatically set the system to recirc depending on the difference between current temp and your desired temp.
I echo the recommendations to install ceramic tint. It blocks heat very well, so the A/C system doesn't have to work as hard.
In the heat of the summer, I'd rather get into a black car with ceramic tint than a white car with no ceramic tint, and I've owned multiples of both of those combos.
mike2100 is offline   Reply With Quote
The Following User Says Thank You to mike2100 For This Useful Post:
Old 07-13-2022, 08:35 AM   #12
Ogt
Ogt's Avatar
Drives: ‘13 AT FRS
The few times I used it and thought the same thing. Those were days that were 90+ with a very high level of humidity. I don’t think anything is defective though.
Ogt is offline   Reply With Quote
The Following User Says Thank You to Ogt For This Useful Post:
Old 07-13-2022, 11:28 AM   #13
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Like the others have said, my A/C performs like a champ. In fact it is so cold, I've had to raise the temp on the Auto settings because it is too cold and I'm trying to find the best way to aim the vents so it doesn't freeze me out of the car.
On 100F days with humidity driving the heat index north of 110, I've been quite comfortable in the car.
This car seems to do a good job of both the volume of air it moves and the temperature of the air itself. My last two cars have struggled with at least one of those two variables. In my MK6 GTI, the air temp was good, but even on high the vents moved very little air. My F30 BMW 4 series moved a lot of air, but it never got as cool as I'd like. The BMW also had the extra bennefit of the condenser freezing/icing up in high humidity when run for long periods of time. Lovely design flaw....
Desertnate is offline   Reply With Quote
The Following User Says Thank You to Desertnate For This Useful Post:
Old 07-13-2022, 02:04 PM   #14
I remember reading a similar thread a few years ago. My '13 is a bit on the weak side. That thread got me to thinking that the factory may have skimped on the refrigerant to save some money. It hasn't bothered me enough to go through the trouble of tweaking the charge. Without a sight glass, we need to follow a detailed procedure to get it just right.
Aircon blowing cold on one side Kris86 Issues | Warranty | Recalls / TSB 9 05-12-2020 01:36 PM
Cost Effectiveness of Modifying Your Car Tristor BRZ First-Gen (2012+) — General Topics 12 09-23-2018 12:22 AM
Dual Zone AirCon Operation Esseff Scion FR-S / Toyota 86 GT86 General Forum 34 05-01-2017 07:05 PM
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 02:10 AM
Swap Aircon HVAC controls from BRZ/GTS to FRS/GT MudithJ Cosmetic Modification (Interior/Exterior/Lighting) 3 08-04-2016 11:13 AM
