Old 06-13-2022, 09:40 AM   #211
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by adamhaley View Post
Does anyone here know how to/ have access to 3d-print one of these? It is the little plastic cap from the oem 2017+ low profile spoiler. One of mine flew off on the freeway and is unrecoverable. Subaru doesn't have just that part, they want to replace the whole wing for $500+, of course. Let me know! see pictures attached.
It is possible but I would turn this job down as it would be the most expensive spoiler cap ever. There is a minimum of 3 hours to scan, model, slice and finish this small part that also has very little demand for additional sales.
Contact a junkyard or salvage reseller to see if you can get some of those or a whole wing for less than Subaru.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 06-14-2022, 09:48 AM   #212
Espi
Espi's Avatar
Drives: 17 BRZ
Mine are getting loose. I've resulted to new clamps but I am running out of inner plastic real estate. They get loose when the car is washed or rains. There is a demand if people know about these. I know a bunch of people that would buy including myself!
Espi is offline   Reply With Quote
Old 06-14-2022, 10:23 AM   #213
Do they serve a purpose where you would need to remove them? Seems like a little JBWeld or superglue would fix the problem if not.
Espi (06-14-2022)
Old 06-14-2022, 04:56 PM   #214
Espi
Espi's Avatar
Drives: 17 BRZ
Funny you say JBweld I thought about this myself! I've only had to remove mine when I decided to first raise the spoiler and then had to repair the 3M tape on the lip spoiler I have on mine. So I've had to remove it 3 times total - Wing risers, initial install of the lip spoiler, then a year later when I did the repair. Just like that its a little loose
The Following User Says Thank You to Espi For This Useful Post:
Dadhawk (06-15-2022)
Old 06-15-2022, 08:18 AM   #215
Heck, if its something you have to remove just a little hot glue might be good enough.
Espi (06-15-2022)
Old 06-17-2022, 02:59 PM   #216
Spektyr
Drives: GR86
It would definitely be possible to 3D print that - the trick would be modeling it.
There's 2 ways: someone measures that with calipers and builds a model in 3D from those measurements, or someone uses a fairly expensive 3D scanner to automatically generate a 3D model.
Once that's done the printing is fairly trivial.
You just want to make sure the part is printed using weather-proof material (common PLA is, at least theoretically, biodegradable and will break down in UV light). A standard FDM printer will leave visible layer lines, but depending on the Z-axis resolution used, the quality of the printer, and the final location of the part (I'm not familiar with where it goes) that may be reduced or unimportant.
Spektyr is offline   Reply With Quote
Old 06-17-2022, 05:02 PM   #217
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Here's the part in context:
LimitedSlip is offline   Reply With Quote
Old 06-21-2022, 11:42 AM   #218
Spektyr
Drives: GR86
I would say for something like that the better option would be using a cheap(ish) hobby CNC to make aluminum molds for a cheap(ish) injection molder built out of a manual hobby hydraulic press.
Since it's going to be clearly visible the layer lines you'll get from 3D printing would be a detraction for most people, and sanding/filling those lines to eliminate them would be labor-intensive.
Alternately, simply milling them out of aluminum might be preferred. Simpler process overall, and thus potentially competitive in terms of price. Also opens up the possibility of anodized finishes in addition to the typical paint options. And being made out of aluminum with that "bling" factor would support the higher per-pair cost.
Old 07-09-2022, 05:18 AM   #219
Pil
Drives: 86
Anyone able to make these for brake duct entry?
*edit: This was 3D printed by a guy who only made it for his car and his friend, seems to fit perfectly and with the option of printing it to various duct sizes.
He was not interested in making more for others unfortunately.
Pil is offline   Reply With Quote
Old 07-09-2022, 09:00 AM   #220
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would take that bezel to the hardware store and start digging around in the plumbing section...
Old 07-09-2022, 12:02 PM   #221
Spektyr
Drives: GR86
If you have calipers and can take complete measurements, I could duplicate it.
Need ID, OD, and height of each section.
Old 07-09-2022, 12:42 PM   #222
Pil
Drives: 86
I do not have these ducts myself. The photos are by the guy who 3D printed it.
Old 07-09-2022, 04:13 PM   #223
Spektyr
Drives: GR86
I could make a rough approximation based on photos and the dimensions of the part they fit into, maybe.
Old 08-09-2022, 10:33 AM   #224
elinde
Drives: 2013 Subaru BRZ Premium 6MT
Side Marker Delete STL file
Hey all!
Been searching for the STL file for side marker deletes for a while. Wasn't sure if anyone on here happened to have the file for it. I would really appreciate it!
Pic for reference:
Name:  side marker.png
Thanks!
elinde is offline   Reply With Quote
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 03:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 06:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 09:09 PM
