Old 07-06-2022, 03:06 PM   #1
Sm1nts2escape
Drives: Black with a rod knock
Codes marked Permanent - Scan tool does not erase?? P0102, P0113, P0017, P219A
I recently built a new engine for a 2013 that I got that had a spun rod bearing. When I started the car with the new engine I noticed after it warmed up it dropped to a low idle, the throttle became twitchy, wanted to stall and had the check engine light and slip light on. I put a scan tool on it and I have 4 codes p0102 - Mass or Volume air flow circuit low input, p0113 - Intake air temp circuit high input, p0017 - Crankshaft position camshaft position correlation bank 1 sensor b and P219a - Bank 1 Air-fuel imbalance. All four codes are marked permanent. When I delete them they are immediately there again once the scan tool rescans... Will these codes remove themselves when the issue is found and fixed or do I have to reflash the ecu or something else? I tried disconnecting the battery and joining the power wires together to drain the capacitors in the ecu with no luck to drop the codes.
Sm1nts2escape is offline   Reply With Quote
Old 07-06-2022, 08:59 PM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Those codes are permanent specifically so they are not erased/battery disconnected to pass inspections.
The monitors need to pass for the ECM to clear them.
HELP! Cranks but won't start P0102 P0113 Sum10clever Issues | Warranty | Recalls / TSB 2 09-06-2020 12:46 AM
Codes P0102 and P0113 Alpha86 Issues | Warranty | Recalls / TSB 0 12-03-2019 10:38 AM
Engine Running Rich, P0102 P0108 P0113, and Misfires Votlon Engine, Exhaust, Transmission 12 01-21-2017 04:38 AM
Scan tool ate my TPMS LS1M Software Tuning 4 07-27-2015 09:25 PM
P0102, P0113, P2096 Engine code Oburn Engine, Exhaust, Transmission 24 09-22-2014 05:30 PM
