| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: brz 2017 hksv2
nothing, just meant that you could try more retarded timing on base timing B
#16 | |
Drives: 13' Scion FR-S 10 Series
with a hysteresis of 50rpm limiter still holds the limiter at 7600, zero bounces with a 50 hysteresis with a -0.12 retard (as provided from oft) you hear a small pop once you hit limiter only and it sluggishly bounces without popping (that one small pop is present when the car is fully stock, but the stock hysteresis is like 300 so the bounce is kinda slow. Am thinking about 3 options: 1. advance some timing on 7600 2. same timing but bigger hysteresis than 50rpm only 3. same setup and same values for the last 2 base timing B rows ( -17 timing retardation at 7450 and 7600 ) with a hysteresis of 50 |
#17 |
try bigger hysteresis also for fuel cut, 50 is very small and intended in fact to let rpm stay almost holding
#18 |
#19 |
i m not used to this feature in openflash/romraider, only ecutek sorry
#20 |
#21 | |
Drives: FT86
There in No ignition cut possible even in ecutek its all fuel cut, to do ignition cut you would need additional hardware box like bee R rev limiter |
#22 |
Drives: FT86
#23 | |
update on the tune ( got a bit busy recently that's why it's a late reply ) so the limiter still holds at 7600 with a hysteresis of 100rpm and approx -17 of timing at 7600 in the base timing B the rpm needle isn't even moving i think i remember it used to sluggishly jump a bit with the default oft v4 stage2+ tune with a hysteresis of 50rpm and -0.12 timing at 7600rpm and i think i was able to hear a one cut as soon as it hits 7600 ( similar to the stock tune cut but without dropping 300 rpm ) so i was wondering what would advancing some timing at 7600 above zero do to the limiter. |
#24 | |
Drives: Toyota 86
#25 | |
my car is banging on 0.15 load with -15 ignition timing retard my goal is to have a fast rev limiter ( similar to the rev limiter in neutral or to that guy in the video i linked in a previous post, will link it in this one as well ) it currently holds at 7600 with -16.29 on last row and a 100rpm hysteresis start at 2:15 |
#26 |
I was talking to a guy with an NA brz on instagram, the shop tuned his car using ecutek achieving the same "popcorn" rev limiter like the boosted 86 in the youtube video linked above but at 6500 instead of rev limiting above 7000 (for safety as he mentioned)
So I think it doesn't have anything to do with being boosted instagram post link below ( #6 in the album, onboard video ) https://www.instagram.com/p/CgTIwAzL..._web_copy_link |
#27 |
Drives: 2017 Toyota 86
I've been playing around with some timing and rev limiter. I haven't tried it in the dry. However, it was raining for the last couple days. When I tested this out in first gear, I achieved what we are looking for. I was able to bounce off limiter.
base time map a: 7400rpm @ -12 degrees, base time map b: 7400rpm @ -12 degrees; on the y-axis (RPM) I changed the value from 7450rpm to 7400rpm. and for the cells for 7600rpm are also -12. *I noticed that the ecu likes to blend both maps A and B, so I make them similar for more consistent results.* rev limit a (fuel cut): on = 7400rpm, off = 7300rpm rev limit b: on = 7400rpm, off = 7300rpm Last edited by silly86; 08-18-2025 at 01:25 AM. Reason: revising my results because I copied the wrong notes over; with the correct values. |
| Tags |
| ecuflash, pops and bangs, rev limit, romraider, tactrix |
| Rev limiter not working | Qwimby1 | Engine, Exhaust, Transmission | 15 | 07-26-2021 11:19 PM |
| How do I get an ECU rev limiter like this? | Tor | Software Tuning | 44 | 03-21-2017 10:17 PM |
| Where Do You Set Your Rev Limiter? | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 06-10-2014 04:48 AM |
| Rev limiter? | feldy | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-03-2012 10:47 PM |
| <3 my rev limiter | NESW20 | Other Vehicles & General Automotive Discussions | 1 | 05-02-2010 11:05 PM |
