Old 08-10-2021, 09:26 PM   #1639
daniloneil8
What is the latest status on the valve spring recall?
Are people still doing it? Or did everyone who is gonna do it, already do it?
I never did the recall. I doubt I will bother at this point.
Who else decided to skip the recall ?
daniloneil8 is offline   Reply With Quote
Old 08-11-2021, 07:57 AM   #1640
We have no real way of knowing if people are still getting the recall done, but it is likely since those in CA are required to do it.
I did it early on, and have had no issues, but if given the choice again and given my car had 100K miles on it at the time, I would not bother. At the time I used it as some "free labor" to get other work done such as changing plugs, etc.
The general agreement seems to be skip it because if they were going to fail, it's likely they already would have.
Old 08-11-2021, 04:27 PM   #1641
daniloneil8
I'm at 60k miles, and don't plan to bother with the recall.
Was just curious if dealers are still screwing up the repair
Old 08-11-2021, 04:30 PM   #1642
TommyW
TommyW's Avatar
Drives: '13 Whiteout
the requirements for the recall for registration purposes have passed so doubtful any more will happen
TommyW is offline   Reply With Quote
Old 08-11-2021, 04:40 PM   #1643
Actually, probably not true. Not everyone that owns the car knows there is a problem, and actually that is the majority of owners.. Also, many dealers clear recall work when reselling a car (it may required in some states). So it is possible more will be successfully done, and some may fail.
Not sure if there is a place you can get the progression on a recall (how many are complete) but that would be interesting.
Old 06-30-2022, 07:20 PM   #1644
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Necro.
My car was on PNO for the past 4 years so never did the recall. California forced me to do the recall before I could reactivate my registration.
I feel like I just started the clock to my car's demise
Is there anything I can do to verify the sealant was properly placed?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-30-2022, 07:26 PM   #1645
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by l0aded View Post
Necro.
Drop the oil pan.
Old 06-30-2022, 07:44 PM   #1646
l0aded
Addicted
l0aded's Avatar
Originally Posted by x808drifter View Post
Drop the oil pan.
Forgive my lack of knowledge here, how difficult is it to drop the oil pan to inspect? Is it as simple as lifting the car and accessing it or is more disassembly required?
Are there any DIY guides or YT videos I can reference? I checked around but don't see anything definitive.
Thank you!
Old 06-30-2022, 08:18 PM   #1647
radroach
Drives: car
@l0aded you might get a borescope camera through the oil drain hole and inspect the oil pickup for silicone debris
Old 06-30-2022, 09:35 PM   #1648
Drop the oil pan.
That will tell you if there is sealant in the pickup tube but not if any of the channels were plugged. Unfortunately the only way to check that would be t I pull the timing cover which means you have to reseal and be back to not knowing.
Old 06-30-2022, 09:40 PM   #1649
Thank you!
Keep in mind that those that had issues were the tiny minority not the majority.
Many of the failures occurred before Subaru issued the updated instructions and tech awareness was low. They are all well aware by now!
Not to say that it couldn’t still happen but the odds are much much lower now than they were 4 years ago.
Even if you pull the pan and see sealant a shady dealer isn’t going to do anything about it anyway. A good dealer may but even then if it hasn’t failed then there is no issue in their mind.
Old 07-01-2022, 02:04 AM   #1650
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Got my springs done last winter. Aintn't broke yet. 0.02
Been out to the ocean a few times and out to the races this weekend.
Don't feel bad. Stuff happens and you get over it.
Old 05-24-2023, 12:45 PM   #1651
Dylan
Drives: 2023 GR86
Vehicle Mileage: 66,096
Vehicle Make: Scion FR-S 2013
Mileage After Recall Performed: 63,716 (done twice, first one at 51,216)
Symptom(s): Engine knocking after a hard pull from a stop sign on a highway on-ramp, headed uphill. Loss of power before eventual stall.
Failure: Crankshaft rod bearing failure. Dealer quoted $7k+ to replace only the lower end and send some parts out for machining.
Resolution(?): None yet, currently reaching out to corporate. Initially got the GM to agree on a trade-in value towards a GR86, but they have no idea when they'd get one (friend said he waited over a year!?) and the trade-in would drop as time goes by. Backtracked and now seeking repairs.
State: Milford, CT, USA
Dealership Offering Repair: Colonial Toyota
This was a bit of a saga. I brought it in for the J02 recall initially at 51,216, but it always had a small leak around the timing cover and I brought it back 6 times over 3 years to have it "fixed". They kept pulling and resealing the timing cover, as well as completely replaced it, before having a regional specialist come out who decided the valve cover wasn't sealed properly during the recall. So they pulled the engine and sealed the valve cover a second time. This was right before winter, so I was barely driving it before April when this happened. The car's never been tracked, autox'ed, redlined, or otherwise thrashed as it's my daily.
Credit where it's due, they never charged me for the repairs up until this point and always comp'ed a rental.
UPDATE: Dealer's buying out the car in cash and I've got a reserve on an incoming '23 GR86 somewhere else. Life's good
Dylan is offline   Reply With Quote
Old 05-30-2023, 02:06 PM   #1652
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Wow. Seems like the dealer took pretty good care of you!
Dzmitry is offline   Reply With Quote
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
