Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 06-30-2022, 05:42 AM   #57
rennlistuser3
Drives: 2017 Subaru BRZ
Originally Posted by raisingAnarchy View Post
This doesn't really support rennlist's comment, which I'm not trying to support either, but I believe the first gen steering would overheat on track. Maybe that was just when owner's ran wider tires than stock, but I'm hoping the new gen got some improvements with regard to the few issues it had (coil packs, EPS motor overheat, etc)
This and @nikitopo are valid points
It might be for saving weight or reducing the overheat issue of the older generation
Mine did overheat and shut down on me but it only did that once during ownership.
We need someone from inside Subaru/Toyota to tell us why they decided on this new system.
I'm really liking what @PBR is saying about the new system having better feedback. My wishful thinking will have me hoping this would be my impression of it too.
In any case, I'll only be looking at a new one if my 2017 is utterly destroyed or something cause so far I'm not seeing enough to warrant an upgrade.
rennlistuser3 is offline   Reply With Quote
The Following 2 Users Say Thank You to rennlistuser3 For This Useful Post:
PBR (06-30-2022), raisingAnarchy (06-30-2022)
Old 06-30-2022, 10:31 AM   #58
raisingAnarchy
Drives: '20 Tundra, '84 SpecE30
Originally Posted by PBR View Post
Did not know any of that lol. Awesome Well. This single Dad with no life is about to go down a rabbit hole and get way more confused hahaha.
Just keep in mind that no one gets on a forum to tell the world how great their car is!
raisingAnarchy is offline   Reply With Quote
The Following 3 Users Say Thank You to raisingAnarchy For This Useful Post:
DylanJZA (07-12-2022), G_Ride (06-30-2022), PBR (06-30-2022)
Old 06-30-2022, 11:53 AM   #59
DarkSunrise
DarkSunrise's Avatar
Only time will tell, but the 2nd gen steering doesn't seem like it will cut out the way the 1st gen did with heavy loads. So that's a potentially significant positive that may outweigh the negatives if you regularly encountered that issue at your local track.
Also there are ways to increase steering feel on this chassis, namely through tire and wheel selection. The best steering feel I've felt on my FR-S was with 200tw track tires slightly stretched and with less sidewall, i.e., 235/40/17 tires on 17x9 wheels. Noticeable difference on track and in the canyons. Turn-in was very sharp and there was a bit more feedback coming through the wheel. I'll try a similar setup later this year when I track my 2nd gen but I would expect it will make a similar improvement.
2022 BRZ Build
2013 FR-S Build
The Following 5 Users Say Thank You to DarkSunrise For This Useful Post:
DylanJZA (07-12-2022), NoHaveMSG (06-30-2022), PBR (06-30-2022), raisingAnarchy (06-30-2022), rennlistuser3 (06-30-2022)
Old 06-30-2022, 12:56 PM   #60
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I would trade some steering feel for that in a heartbeat.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkSunrise (06-30-2022), DylanJZA (07-12-2022), PBR (06-30-2022)
Old 06-30-2022, 03:53 PM   #61
DarkSunrise
Yeah my thought exactly, consistency is underrated.
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
Old 06-30-2022, 07:15 PM   #62
dhutty
Drives: 2004 Subaru WRX wagon
Do this test. Gen 1 vs gen 2. Bumpy road. 30 mph..See which one has more movement. My money is all Gen 2. And that's what we call, "feedback." It's also more consistent from lock to lock without the off center dead spot like my '13
13. I've also owned a Lotus evora which, arguably, has the best steering feel yet of any modern car. Way better than my 997.1.
I seriously would love PBR's thoughts on the difference between the Evora's and the '22 BRZ's steering. I know it's not an apples-to-apples, but I've been obsessed with Evoras forever, primarily for that lauded steering feel. Since a BRZ is much more in my budget range than an Evora, any attempt at a comparison would be eagerly read.
dhutty is offline   Reply With Quote
The Following 2 Users Say Thank You to dhutty For This Useful Post:
PBR (06-30-2022), rennlistuser3 (07-01-2022)
Old 06-30-2022, 07:59 PM   #63
PBR
PBR's Avatar
Drives: 2022 BRZ Limited 6 speed manual
No problem. I owned it for about a year and did a few track days at MSR Houston and Harris Hill. It was the way it weighed up and how you could feel the front tires load up so nicely. It "jiggled" quite a bit for lack of a better term but the consistency was awesome. It felt alive from lock to lock. Oversteer was fun because it was so easy to control. Opposite lock, again just natural weight, little jiggles and a nice tactile feel. The sense of"tension" building up as you approached the limits was full of feel and linear. The chassis was also very stiff with serious lateral rigidity not just torsional rigidity. Dual wishbones all around. No expert but now understanding how those things affect feel as well. I don't find the twins so far off. When I first drove an FRS in 2012, i couldn't believe it was an EPS system. And at that time I had always assumed my RX8s were hydraulic because of their feel. I was ignorant to that while I owned them lol. Another highly stiff chassis. With the twins, both gens, I've found similar "tension" feeling and nice control weight.
PBR is offline   Reply With Quote
The Following 6 Users Say Thank You to PBR For This Useful Post:
ACT86 (07-01-2022), DarkSunrise (07-01-2022), DylanJZA (07-12-2022), Ohio Enthusiast (06-30-2022), rennlistuser3 (07-01-2022), Samba86 (07-01-2022)
Old 06-30-2022, 08:58 PM   #64
Ohio Enthusiast
Drives: 2018 BRZ
Which Evora did you have (N/A, S, 400, GT)? I know they didn't change a whole lot other than adding the supercharger with the S, but they did iterate over suspension and chassis tuning. I'm a bit of a Lotus fanboy myself.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
PBR (06-30-2022)
Old 06-30-2022, 09:01 PM   #65
ZDan
ZDan's Avatar
Drives: '23 BRZ
Steering on my '17 has never once cut out on me at the track, even on Hoosier A7s. I'm pretty sure that was more a problem on earlier gen 1s.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Dirty Harry (07-07-2022), PBR (06-30-2022), rennlistuser3 (07-01-2022)
Old 06-30-2022, 11:49 PM   #66
PBR
PBR's Avatar
NA, Launch edition. It was tough car to own. The interior was falling apart. A pillar placards would break. The passenger airbag and dash started to warp. The shift boot glue came undone. Also, engine out, 6 weeks and around $6K ish for a clutch change. Stuff like that.
The Following 4 Users Say Thank You to PBR For This Useful Post:
DylanJZA (07-12-2022), Ohio Enthusiast (07-01-2022), rennlistuser3 (07-01-2022), Samba86 (07-01-2022)
Old 07-01-2022, 12:14 AM   #67
dhutty
Lots Of Trouble Usually Serious, but still, I lust for them. Thanks for the write up and thoughts, seriously, in my mind I cross shop the Evora and the BRZ as crazy as that sounds $$ wise.
PBR (07-01-2022), rennlistuser3 (07-01-2022)
Old 07-01-2022, 12:49 AM   #68
PBR
PBR's Avatar
I don't think it's crazy at all! What other pure 2+2s are available? Does the Brz/86 miss the "cool" factor of a Lotus? Definitely. But I don't think the driving experience is so far off. It's not light-years ahead. These things are very much more than the sum of their parts. And much more affordable to maintain. Piece of mind to run them hard is great too. I learned with that with the Evora, which I got a hell of a deal on, that being able to buy a car and being able to own a car are 2 very different things. So more than satisfied with my low key and affordable compromise lol.
The Following 3 Users Say Thank You to PBR For This Useful Post:
Old 07-01-2022, 01:12 AM   #69
Samba86
Samba86's Avatar
Drives: 86 GTS
Mate, this is awesome. Saw my first in the flesh recently and it had so much presence for its size.
Samba86 is offline   Reply With Quote
The Following User Says Thank You to Samba86 For This Useful Post:
PBR (07-01-2022)
Old 07-01-2022, 01:44 AM   #70
PBR
PBR's Avatar
I don't think this is so bad either lol🍻
ACT86 (07-01-2022), DarkSunrise (07-01-2022), Dirty Harry (07-01-2022), DylanJZA (07-12-2022), rennlistuser3 (07-01-2022), Samba86 (07-01-2022)
GR86 steering wheel on 1st Gen? vin61k Cosmetic Modification (Interior/Exterior/Lighting) 5 07-07-2025 06:32 PM
FS: 2017+ Steering wheel - 2017+ Steering wheels covers trueno86power Interior Parts (Incl. Lighting) 5 06-26-2022 06:11 PM
949 Racing 50mm Steering Spacer 86 - GR86 949 Racing Tracking / Autocross / HPDE / Drifting 195 04-18-2022 12:45 PM
Electric power steering and steering column part info raspec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-12-2021 06:27 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 37 07-18-2021 04:38 PM
