Old 06-29-2022, 03:26 PM   #869
If, like the typical EV driver, I charge 95% of the time at home, I wouldn't be willing to do a battery swap while on a road trip unless there is some type of guarantee on the swapped battery when used outside the "swap" process.
Capt Spaulding (06-30-2022), soundman98 (06-30-2022)
Old 06-29-2022, 04:07 PM   #870
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by 86league View Post
I can see this having advantages and disadvantages. Makes for fewer number of charge points needed for normal times, but that could make holiday travel a mess (well more of a mess than it is now even).
With the huge gas stations we have now along freeways near major cities there can be big lines during thanksgiving travel. If the "fill-up" time for EV's is longer than gasoline cars - there will be a need for a larger number of charge/swap stations to handle that holiday traffic - or make the wait time longer. But, there will be no business case to build them for single digit uses during the year. I'm guessing they will size the # of charge/swap stations to something sustainable for regular day-to-day traffic.
It depends on the ecosystem needed. For instance, there are already many Superchargers used at the midpoint between the Bay Area and LA, so this could be a location for swap stations that meet a holiday need. Who knows what will be around in 30-50 years in terms of high speed rails, as China and Japan and other parts of the world seem to be ahead of the game than the US, but where there is a need and desire there could be development.
While the lithium sulfur batteries are 3x as dense, they would charge about as fast because charging 50kWh takes a similar time, but if the battery is 150kWh for the weight of 50kWh then range would make swapping not necessary, and it would also mean the battery could have the potential to charge faster per mile because the battery is bigger, so a car in the future may add another 150 miles of range in just minutes. Level 3 charging is already capable of adding 3-30 miles of range per minute, but if the battery was 3x the size then we are looking at a lot of miles in 5-10 minutes. Swapping to a larger battery could be done to improve range to not have to stop, or swapping along the journey could be possible to speed up the process instead of charging. There could be a holiday surcharge for battery swapping. Who knows?
There is mobile charging. I don't know if there could be mobile swapping in some capacity. I don't know what goes into a swapping station.
Old 06-29-2022, 07:37 PM   #871
Irace86.2.0
You wouldn't own the battery. Same with leasing a car, where you and the bank don't own the car. The battery would need to be insured like a car that is leased, which really isn't an issue because the rest of the car needs to be insured. If something happens to the battery in the form of an accident that is your fault then it would be your fault, but if the battery needs to be replaced or something happened out of your control then the battery would be swapped out.
The company launched a Battery as a Service (BaaS) subscription model that lets owners deal with charging needs by simply having a fresh battery pack installed in a matter of minutes. Users have the option of signing up for different battery sizes and making the exchange at special Power Swap stations. The service allows Nio to sell vehicles without a battery. It's essentially "batteries not included" on a large scale, and according to Nio, it can save buyers about $10,000 off the price of a vehicle.
https://www.caranddriver.com/news/a3...tteries-lease/
Old 06-30-2022, 07:31 AM   #872
You wouldn't own the battery. Same with leasing a car, where you and the bank don't own the car....
Got it....
This a little slight of hand frankly since in the the long run it doesn't save anything. It's also different than providing fuel for ICE because built into the price of the battery subscription is the amortized cost of the battery plus probably some margin of error (the service likely has a more than 1:1 relationship of cars to batteries).
Honestly, I'm not saying that battery swapping is a bad idea, but I don't think you are going to find the OEMs agreeing to a standard format unless forced upon them.
Ohio Enthusiast (06-30-2022), soundman98 (06-30-2022), Tcoat (06-30-2022)
Old 06-30-2022, 07:53 AM   #873
Ohio Enthusiast
Drives: 2018 BRZ
OEMs are still fighting over a charging port standard (which is a relatively simple change and can even be solved via adapters in some cases). I see no chance that swappable batteries can become standardized in any significant way in personal vehicles.
The Following 4 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Dadhawk (06-30-2022), soundman98 (06-30-2022), Tcoat (06-30-2022), Wally86 (06-30-2022)
Old 06-30-2022, 01:16 PM   #874
Irace86.2.0
Got it....
I don’t think they are trying to make a slight of hand. People say the same thing about Tesla when they advertise prices that include government subsidies or if they advertise the price being lower based on gas savings and maintenance. I think people go in well aware of what they are paying each month. Also, the monthly subscription is in lieu of fast charging, which often costs similar to filling up with gasoline, so the $142 for six swaps seems fair. At $6/gal, that is 24 gallons or 710 miles/month at 30mpg, which seems like a bargain. Cheaper than filling up with gas for most people, so the battery is essentially free.
There is also an option to pay $12/month to rent the battery, which is $1,440 after ten years, and there is the option to buy the battery for $10k, which might prove cheaper for higher resale value and home charging, but that could also mean someone is financing a $30k car instead of a $20k car, and they are selling a battery that is old and partially depleted at 10 years old.
Nio is proprietary, so they swap Nio cars only. We would need swapping dealerships/stations based on manufacturers or groups like VAG might all work. I wouldn’t dismiss the possibility of a standardization. It won’t happen tomorrow, but it probably will happen. You might be aware of the car connectivity consortium, which is a group of manufacturers creating a standard for connecting our phones to the cars for keyless entry like Tesla has. I would personally love to lose my bulky key fob. Apple in Europe needs to comply with laws to use USB-C as a standard, so we reduce cable waist. They will probably avoid this by switching to Magsafe. Outside or Tesla, EVs already have a standard for charging. I can totally see a future with a bolting pattern and size standard with a quick disconnect standard.
https://carconnectivity.org/
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 06-30-2022, 01:45 PM   #875
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
That's where the programming comes in. Sound changes at MPH points. Could even program in a little brake grab to give you a shifting gears feel. Maybe a faux gear lever too for the "full engagement" experience.
You could vary the sound generator to mimic a 2 stroke. It might sound like my mother in law. Biiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiithc Nag Nag. Biiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiithcNAGNAGNAGNAG.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Old 06-30-2022, 01:50 PM   #876
People say it because its true. Any vehicle could be advertised this way. Say Toyota asks you what you're driving then they show you the difference between driving a Prius and a Suburban as your "cost" for purchasing the car, but it really isn't. The upfront cost is the purchase price, not some theoretical cost based on driving habits and former car ownership.
If my first car is a Tesla, Tesla's "lower based" cost is a pure fabrication, as an extreme example.
Regardless of all that, I agree with you that until the magical 10 minute to refill to 300 mile battery comes along, swapping makes theoretical sense.
Personally though, however its done I don't won't to depend on the car OEM to provide me fueling/charging/switching infrastructure. I should have my pick similar to fuel.
I guess we'll see how it plays out over time.
Old 06-30-2022, 02:04 PM   #877
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
One of my charger vendors has a guy that sits on the committee for BCI and says it's the wild west when it comes to the the lithium ion manufacturers. They can't agree on any type of standardization.
Old 06-30-2022, 02:13 PM   #878
Capt Spaulding
Persona Non Grata
Swapping could be a great alternative if the logistics can be worked out. However, I'd be reasonably happy with a 20 minute refill on a 400 mile battery. For me though the sweet spot for range is 500 - 600 miles. I don't need that for around town, but 500-600 is my daily average for road trips. Being able to travel interrupted only by our biological constraints would be perfection. (I think)
Old 06-30-2022, 02:22 PM   #879
Irace86.2.0
Well they kind of do this on the window sticker with gas mileage. I think saying $20k Nio with $140/month swapping program or $12/month for renting the battery or $30k with the battery is fairly transparent and a great business model to give people options.
Old 06-30-2022, 02:29 PM   #880
Irace86.2.0
This is where the government comes in. We have how many different electrical plugs in the world? Something like 15, yet every plug in the US has the standard 120/240v plugs.
The world would do well to standardize the plugs now, or we will just get many varieties or a situation like the US being on standard instead of metric and having too much cost to switch to metric or too much cost to change all homes to a world standard for electrical outlets.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Dadhawk (06-30-2022), Ohio Enthusiast (06-30-2022)
Old 06-30-2022, 10:06 PM   #881
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm still not convinced that the US market overall will accept a battery swap program.
tire rental doesn't really exist. but could be viable in the same regard at one-day track days.
people are too possessive of their cars stuff to 'rent'/'borrow' batteries while owning the rest of the car.
if we follow the beginnings of the gasoline vehicle, i really doubt we'll see any sort of standardization or calming of the market for at least the next 20 years. it's interesting to be a part of, but too many players all too aggressively fighting for a really tiny piece of pie.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Capt Spaulding (07-07-2022), NoHaveMSG (07-01-2022), Wally86 (07-05-2022)
Old 06-30-2022, 10:08 PM   #882
jflogerzi
jflogerzi's Avatar
Pretty much the world is coming to a standard plug here in the US and European markets. The CCS plug is quickly becoming the plug. Even Tesla is moving supporting CCS plugs
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
Dadhawk (07-01-2022), Irace86.2.0 (06-30-2022)
Tcoat banned? Hotrodheart Off-Topic Lounge [WARNING: NO POLITICS] 95 07-06-2019 01:46 AM
Does anyone know why pansontw got banned? Soloside Off-Topic Lounge [WARNING: NO POLITICS] 17 10-26-2018 04:20 AM
Got banned from gf's complex jdmblood Other Vehicles & General Automotive Discussions 11 07-12-2015 12:46 PM
Why have so many users been banned? xuimod Site Announcements / Questions / Issues 9 03-08-2015 02:23 PM
Banned Toyota GT 86 Advert Banned Nevermore FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 11-16-2012 07:27 PM
