Old 06-28-2022, 05:12 AM   #1
allowe
allowe's Avatar
Looking for a lightweight flywheel that doesn’t rattle/chatter
My throw out bearing is going so I’m replacing everything down there. If anyone knows a lightweight flywheel that doesn’t rattle, let me know
allowe is offline   Reply With Quote
Old 06-28-2022, 10:25 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
So far my Fidanza flywheel seems quiet. I also have poly engine mounts and the STI transmission mount, so I mayjust not hear it.
Old 06-28-2022, 02:13 PM   #3
gpvecchi
gpvecchi's Avatar
TRD just chatters when oil is cold, then it goeas away.
From what I read, the issue is there just with Motul Gear 300; this sounds logical, as this oil helps gear shifting when cold, differently from other brands.
Old 06-28-2022, 02:53 PM   #4
DarkSunrise
DarkSunrise's Avatar
Am I the only one who had chatter even on the stock flywheel with the a/c on at idle? Anyway I switched to a lightweight exedy and didn’t notice any additional chatter. I believe it was 12.8 lbs.
2022 BRZ Build
2013 FR-S Build
Old 06-28-2022, 02:56 PM   #5
allowe
allowe's Avatar
Sometimes it feels like I’m having a slight chatter when going in the higher rpms and when decelerating. But you have to pay attention to it as it’s quiet
Old 06-29-2022, 04:31 AM   #6
makinen
makinen's Avatar
Drives: Toyota 86
OS Giken has one.
https://minkara.carview.co.jp/userid...035/parts.aspx
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 06-29-2022, 06:16 AM   #7
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Mine stock chatter too (quite a lot to be honest) but I do have STI engine and trans mounts.
MrSkubi is offline   Reply With Quote
Lightweight flywheel and lightweight pulleys: bad? gpvecchi Engine, Exhaust, Transmission 8 10-13-2020 03:07 AM
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 11:09 PM
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 10:30 AM
Clutch, LW flywheel and chatter.... wootwoot Engine, Exhaust, Transmission 20 11-17-2014 04:50 PM
Any experience with lightweight clutch/flywheel that doesn't CEL? dave77 Engine, Exhaust, Transmission 14 12-14-2013 11:06 PM
