Old 06-28-2022, 05:39 PM   #29
StraightOuttaCanadaEh
Wes
The bulk haven't. It is just that car guys tend to take the highest spec cars and use them as the examples.
If you listen to most the Mustang Shelby GT500 is the common production model instead of about 1% of the ones on the road.
I'm actually using my wife's Mini Cooper 3 cylinder base model lol. It's got more torque and lower in the rpm range so I can just squirt past people almost instantly. Doing that in my car is so slow in comparison, yet it has 70 more hp. The 86 makes a lot of noise and it's exciting, but it's painfully slow. In fact when I moved from my 2007 Cooper S with 2 busted cylinders and 132K to the 86, I couldn't tell the difference in speed. Maybe in 2nd gear from 5000-7400 rpm. But that's it. I absolutely can't wait to turbo/supercharge it
Instagram: @gt86ws
Old 06-28-2022, 05:45 PM   #30
Teseo
Drives: frs
Before buying any car considere this before. Hint: Pick only TWO
Fast
Cheap Reliable
Old 06-28-2022, 05:47 PM   #31
Originally Posted by brandonblt2 View Post
When I look at 0 to 60 times from Car and Driver for a 2016 accord it's 5.6 sec for the V6 and 7.0 sec for the 4 cylinder. Base Camry's are a bit slower at around 8 seconds with the V6 at 5.8 sec. Our cars have a 0 to 60 of 7.1 seconds with a stick if you dump the clutch you can get 6.3 seconds and around 8 sec with an auto. In real world testing an accord is probably beating us most of the time. If you have an auto you will match a base Camry.
And sure everyone will define fast and slow differently but when comparing the twins to other sports cars that people cross shop with the twins are slower than most.
Ecoboost Mustang - 5 seconds
V6 Camaro - 5.3 seconds
WRX - 5.3 seconds
Civic Type R - 5.4 seconds
Golf GTI - 5.9 seconds
Miata - 5.8 seconds
Ford Focus RS - 4 seconds
Honda Civic Si - 6.8 seconds
Using the best case 0 to 60 time the twins only beat the Honda Si. It's at the bottom of the list so it's slower than most sports cars that it is cross shopped with which is ok since that is not what the car was meant for. What it lacks in acceleration it makes up for in handling.
And that list makes up a teenny tiny segment of the cars on the road and really a totally different class. The list of "slower" cars than the Twins will have several hundred entries. The AVERAGE time for cars is around 8 seconds so the twins are above average no matter how you look at it.
And I will point out that all those times are the best squeezed out of them as well.
This argument that the times for the twins have to be forced but every other single listed time is a just a leisurely press of the pedal and off you go is a farce.
Old 06-28-2022, 05:50 PM   #32
YA sure thing.
Old 06-28-2022, 06:06 PM   #33
86TOYO2k17
Drives: 2017 toyota 86
Fast
Cheap Reliable
Think a few more criteria should be added, like handling, aesthetics, technology possibly.
Because a 370z is only about $1k more, and way faster. And scored way higher in reliability.
Old 06-28-2022, 06:39 PM   #34
Teseo
Drives: frs
Gas mileage, insurance, maintenance in general is higher than GT86. The only 370z i could buy is in midnight blue, touring trim, MT so I can "replicate" the devil z.
Old 06-28-2022, 07:29 PM   #35
86TOYO2k17
Yeah so more than 3 categories to consider for the choose 2 scenario.
20mpg combined vs 24mpg combined for manuals, 22 vs 26 autos.
Insurance was basically the same for 2020 370z base vs 2020 brz base.
Maintenance is basically the same as well, especially since I diy everything.
Old 06-28-2022, 08:25 PM   #36
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Twins can accelerate it's just easier to get caught with your pants down unless you are in the right gear.
It's the complete opposite of how most modern tiny turbo engines are tuned.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
ACT86 (06-29-2022), alphasaur (06-28-2022)
Old 06-28-2022, 09:06 PM   #37
86TOYO2k17
Correct, just not quickly or “fastly”
Old 06-28-2022, 09:17 PM   #38
Ohio Enthusiast
Drives: 2018 BRZ
I guess it also depends on where you are and how fast normal traffic accelerates. In my area in Ohio I can keep up with traffic while shifting at 3000 RPM and the throttle only partially depressed. If I'm first at a stoplight and accelerate briskly to 40 MPH shifting at 5000 RPM I leave traffic far behind.
Old 06-28-2022, 09:30 PM   #39
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I think you're missing my point. Sports car enthusiast are comparing the twins to other sports cars or somewhat sporty cars. When you compare the twins to other sports cars in a similar price bracket it's at the bottom of the list well below average.
Also, the reason I pointed out the twins really had to push for a 6.3 sec 0 to 60 is because that's what I remember the guy who got the time said he had to do. Even so it's a moot point because it was still the second slowest with its best time.
So if you have a manual you will be slightly faster than base model volume seller cars e.g. Accords and Camrys. If you have an auto I'll be just as slow as them or slower. The twins in stock form are not fast when compared to any modern sports car or even slightly sporty car.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
The Following User Says Thank You to brandonblt2 For This Useful Post:
Cheeky (07-01-2022)
Old 06-28-2022, 10:05 PM   #40
Teseo
Drives: frs
Don't forget tyres
Old 06-28-2022, 11:06 PM   #41
86TOYO2k17
Don't forget tyres
Yeah, definitely not in favor of the brz/86
Old 06-29-2022, 12:18 AM   #42
e_lunatic
Drives: 2015 Scion FR-S
the car is slower than most sports cars for sure. it was never meant to be a drag racer, it's a momentum canyon carver.
e_lunatic is offline   Reply With Quote
fast, forced induction, naturally aspirated, slow, speed
Red GT86 from Europe - Slow build - Daily+track. Iceman Member's Car Journals 53 12-22-2020 02:59 PM
PROJECT MAKE BRZ NOT SLOW SLOW BUILD andrewsbutt Member's Car Journals 33 10-11-2018 12:19 AM
people with gt86 steering wheel... mokinbird87 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-25-2014 01:45 PM
The dumbest thing people have said about your gt86/frs/brz. bkblitzed Scion FR-S / Toyota 86 GT86 General Forum 130 08-25-2013 07:31 PM
What is it that makes people mixing up the GT86 with a Supra Killerbee Scion FR-S / Toyota 86 GT86 General Forum 31 12-20-2012 02:24 PM
