Looking for a lightweight flywheel that doesn’t rattle/chatter
My throw out bearing is going so I’m replacing everything down there. If anyone knows a lightweight flywheel that doesn’t rattle, let me know
#2 |
Rust bucket enthusiast
So far my Fidanza flywheel seems quiet. I also have poly engine mounts and the STI transmission mount, so I mayjust not hear it.
#3 |
TRD just chatters when oil is cold, then it goeas away.
From what I read, the issue is there just with Motul Gear 300; this sounds logical, as this oil helps gear shifting when cold, differently from other brands. |
#4 |
Am I the only one who had chatter even on the stock flywheel with the a/c on at idle? Anyway I switched to a lightweight exedy and didn’t notice any additional chatter. I believe it was 12.8 lbs.
2022 BRZ Build 2013 FR-S Build |
#5 | |
Sometimes it feels like I’m having a slight chatter when going in the higher rpms and when decelerating. But you have to pay attention to it as it’s quiet Sent from my iPhone using Tapatalk |
#6 |
Drives: Toyota 86
#7 |
Drives: 24 GR Yaris, 23 GR86
Mine stock chatter too (quite a lot to be honest) but I do have STI engine and trans mounts.
| Lightweight flywheel and lightweight pulleys: bad? | gpvecchi | Engine, Exhaust, Transmission | 8 | 10-13-2020 03:07 AM |
| Flywheel Rattle? | CB762 | Issues | Warranty | Recalls / TSB | 119 | 11-16-2016 11:09 PM |
| Flywheel Chatter | samisons | Issues | Warranty | Recalls / TSB | 13 | 12-05-2014 10:30 AM |
| Clutch, LW flywheel and chatter.... | wootwoot | Engine, Exhaust, Transmission | 20 | 11-17-2014 04:50 PM |
| Any experience with lightweight clutch/flywheel that doesn't CEL? | dave77 | Engine, Exhaust, Transmission | 14 | 12-14-2013 11:06 PM |
