Old 10-11-2020, 09:41 PM   #225
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Tokay444 View Post
54mm should be the minimum.
Based on what? That sounds way too big to me. If you can make 270hp on 50mm ITBs on a 3SGE beams revving over 9k rpm what would make you think the FA20 (that cant even safely sustain revs to 8k) would need TBs that big?
Edit: After some googling I am guessing you are used to Hondas. FA20 =/= K20. FA20 is lower revving and doesn't have the Vtec big cam to deal with.
1974 TA22 Celica
2013 86 GT
Old 10-12-2020, 11:15 AM   #226
Tokay444
Based on wanting make any real gains.
Old 10-12-2020, 01:54 PM   #227
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by Turdinator View Post
It seems like they are using 4AGE 20v ITBs. The start of the thread lists the throttle sizes as 45mm for the Sard and 48mm for the Greddy. I would have thought the 48mms would be enough for this motor. Do we know which was used in for this dyno? The Sard does seem to have a greater volume plenum and shorter runners which I think would be preferable. Maybe a mix and match would net better results. I also know you can get 50mm TBs from people like Toda. So if its only the TB size that is restricting things there are ways around that if you are prepared to spend a little extra.
The first dyno used the Greddy 48mm ITBs and supplied plenum. The second dyno used the Sard ITBs and no plenum. SUR Fab a NZ company that makes some very nice CNC 50mm ITBs for the 3SGE as well. But IDk at least with the plenum installed you could get the same affect or better from the RacerX IM for >$900. Swapping out ITs easily doubles the cost..
PulsarBeeerz is offline   Reply With Quote
Old 10-12-2020, 02:38 PM   #228
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Stock head flows 265cfm.
With the butterfly's so close to the actual valves honestly the sizes on both the kits are way too big.
Read:
https://racehead.com.au/designing-pe...-should-i-use/
Source of head flow
https://dsportmag.com/the-tech/educa...ylinder-heads/
The Following User Says Thank You to x808drifter For This Useful Post:
Turdinator (10-12-2020)
Old 10-12-2020, 10:18 PM   #229
Tokay444
Lol.
Old 06-25-2022, 04:12 PM   #230
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
botbs is offline   Reply With Quote
The Following 4 Users Say Thank You to botbs For This Useful Post:
ballsdeep (06-25-2022), nikitopo (06-26-2022), SuperTom (06-27-2022), Thefalls (06-26-2022)
Old 06-28-2022, 03:36 AM   #231
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Originally Posted by botbs View Post
They needed a motec ecu to get it to work
cyde01 is offline   Reply With Quote
The Following User Says Thank You to cyde01 For This Useful Post:
Drifter X (06-28-2022)
Old 06-28-2022, 03:39 AM   #232
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Yeah they removed the MAFS which the stock ECU needs, so they needed a standalone.
Drifter X is offline   Reply With Quote
The Following User Says Thank You to Drifter X For This Useful Post:
jrhudson (06-29-2022)
Old 06-28-2022, 08:47 AM   #233
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I'd be curious to know how the ecu monitors intake air volume without a MAF or MAP. If not monitored it's almost like having multiple carburetors.
Old 06-28-2022, 10:21 AM   #234
churchx
churchx's Avatar
Drives: 2014 GT86
Just install 4 sensors
Old 06-28-2022, 12:47 PM   #235
blsfrs
blsfrs's Avatar
Easier said than done. (IMHO)
Old 06-28-2022, 11:32 PM   #236
churchx
churchx's Avatar
Drives: 2014 GT86
Obviously. Kind of trolled a bit
Old 06-28-2022, 11:40 PM   #237
Teseo
Drives: frs
Then you are at the territory of FI price wise
Old 06-29-2022, 12:40 PM   #238
cyde01
cyde01's Avatar
Yeah DK is saying this will be popular everywhere but it’s become prohibitively expensive
In for the long haul Ultimate NA build thread. celek Engine, Exhaust, Transmission 669 06-07-2020 06:26 PM
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL Andrew666 AUSTRALIA 8 11-19-2018 04:24 AM
RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** RallySport Direct Transmission and Driveline 92 09-01-2015 12:17 PM
RallySport Direct's Ultimate Interior Thread! RallySport Direct Interior Parts (Incl. Lighting) 45 03-25-2015 01:12 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
