Old 06-06-2022, 11:17 AM   #15
Leviticus Ezra
Leviticus Ezra's Avatar
Drives: 2017 BRZ w/Performance Package
Originally Posted by Sur View Post
Anyone know what intercooler will mount up to the stage 1 kit? I don’t really want to spend $1600 on the works intercooler add on.
Works uses a air to water setup. You could run it with an intercooler. But it would be a lot of custom fabricating
Leviticus Ezra is offline   Reply With Quote
The Following User Says Thank You to Leviticus Ezra For This Useful Post:
Teseo (06-06-2022)
Old 06-06-2022, 11:19 AM   #16
Leviticus Ezra
Originally Posted by cabasse View Post
i've been thinking about the works stage 2 carb kit for a couple of years now, and i know i should probably jump on it soon. i assume this was non-carb? i'm curious about long term reliability, as i'm coming up on 100k miles on my 13...
This was in fact the non carb kit. So far everything seems to be working as it should. I installed the kit with less than 10 thousand miles on the car and currently only put 3 thousand on it since. I'll be sure to keep you posted long term wise. I'd say as long as you're not going for peak power, you should be good. The kit is very tame
Teseo (06-06-2022)
Old 06-20-2022, 05:44 PM   #17
HaloFRS
Drives: 2020 Subaru BRZ Limited
Do you have any sound clips?
Thanks
HaloFRS is offline   Reply With Quote
Old 06-25-2022, 01:12 AM   #18
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Is that the standard Perrin CAI? Or custom for the kit?
Sur is offline   Reply With Quote
Old 06-25-2022, 08:57 PM   #19
Teseo
Drives: frs
Stock. Works turbo kit was designed to keep oem airbox, so it works with the kit
Teseo is online now   Reply With Quote
Old 11-26-2022, 12:44 AM   #20
Nicolai
Drives: 2020 BRZ tS
Where and how did you mount your oil cooler core? Been looking at getting the Mishimoto one as well but it doesn't look like it would fit with the auxiliary radiator.
Nicolai is offline   Reply With Quote
Old 11-26-2022, 12:54 AM   #21
Nicolai
Drives: 2020 BRZ tS
Originally Posted by Leviticus Ezra View Post
Just got my car back a few days ago from Six Star Motorsports and could not be any happier with the results! Everything that was installed worked so well with all the other mods. The car feels great and pulls all the way to redline. The power delivery is almost instant and very smooth!
I'd say the price tag for the Works Turbo kit was most certainly worth it in the long run. As everything fit as it should and felt really nice and looked good while doing it. The kit is capable of making much more power, but I wanted something modest as I'm trying to get as many miles out of my BRZ as possible. The upgraded turbo spools real nicely and makes very lovely sounds as well. I wasn't thinking I'd hear much if anything, but it's got a very natural flutter and just enough blow off.
The car sounds much more mild yet a touch throatier. Almost achieving that iconic boxer rumble. Getting on it no longer sounds like a high pitch scream but more so distinct and low.
The car seems to be running the boost great! Temps are where they should be if not cooler due to the upgraded cooling components and oil stays well under 190 when moving air through the cooler. The cars been dying for the extra power. It almost feels more driveable, if that makes sense? Getting in and out of gears feels far more effortless and rev matching is far more predictable it seems.
Overall, it's a lot more engaging and rewarding to drive!
Your BOV is on backwards.
boost, dyno, forced induction, turbo, works
The WORKS 2017+ Stage 2 Turbo Kit is here! WORKS Forced Induction 11 02-09-2019 05:27 PM
Tuner that works with OFT in Denver area? apelpapa Rocky Mountains / Great Plains 2 09-18-2018 07:30 PM
Works stage 2 install help drz400dude Forced Induction 9 05-29-2017 09:23 PM
Experience with Works Stage 1 Turbo Kit aaguirre123 Forced Induction 33 09-18-2015 09:16 PM
My Experience with Works Stage 1 Turbo Kit aaguirre123 Member's Car Journals 9 06-09-2015 08:47 PM
