Drives: 2015 Scion FR-S A/T
Valve replacement
So I've been trying to rebuild my engine after a roller rocker slipped out and I've been going with subaru parts for the most part. Apparently exhaust valves are on back order all the way til August so I was wondering if anyone knows of some good aftermarket valves to get instead of having to wait over a month.
#2 | |
Drives: 2013 Subaru BRZ
You're probably across this however coupled with this work I believe there are shims of varying thicknesses that increment by 0.02mm. There are many(!) thicknesses each with their own part number to tailor fit each valve. |
#3 | |
| Tags |
| aftermarket, engine, valves |
| PCV Valve Replacement with STI Valve | apelpapa | Forced Induction | 30 | 06-03-2022 08:23 PM |
| Valve cover gasket replacement | knucklehead | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 05-06-2021 06:38 PM |
| Private Mechanic doing Valve Spring replacement | TommyW | Issues | Warranty | Recalls / TSB | 41 | 01-14-2020 02:17 PM |
| Has anyone considered doing the J02 valve spring replacement themselves? | gutbuster | DIY (Do-It-Yourself) Guides | 15 | 11-04-2019 09:37 AM |
| Heart valve replacement surgery | mike the snake | Off-Topic Lounge [WARNING: NO POLITICS] | 94 | 09-17-2014 01:45 PM |
