| Member's Car Journals Car journals by our members. |
#15 |
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
Awesome! I just got back from opening it up a bit. I'm at 925miles. My G meter looks very similar. lol.
I'll go out again at some point and bring it up to 5k. My oil change is scheduled for Thursday, my 1st track day is the 25th. |
#16 | |
For oil, I went with Mobil 1 0w20 AFE, but will probably switch to a 30 weight before my next track day. I think the manual still states a conventional 5w30 can be used if a synthetic 0w20 is not available, same as the 1st gen. FWIW that Mobil 1 oil is actually pretty stout for a 0w20 with a KV100 value of 8.8. The only 0w20 oil I've found that's thicker at high temp is Redline 0w20. I'm planning to change out the trans and diff oil this winter. Nice, I can't wait to hit the track with this car too. Have fun!
2022 BRZ Build 2013 FR-S Build |
#17 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#18 |
At 939 miles, I drive down to the dealer and got my oil changed today. Ripped it around this afternoon. This thing is a blast, can't wait for Saturday.
#19 | |
Which track and organizer are you running with?
#20 |
I got tired of all the paint damage and tried Meguiar's hybrid ceramic wax on my car. I honestly just wanted the longest lasting, easiest paint protection but was not expecting it to shine this much. Combined with the ignition red color, my car was getting so much attention just going out for lunch down the street. Very eye-popping and not recommended at all if you're trying to fly under the radar lol. It's hard to describe how shiny it came out, but here's my attempt at showing it with a picture:
#21 | |
https://www.ft86club.com/forums/showthread.php?t=146810 I just don't want to void the warranty if 5-30 is not spec'd for the engine.
#22 | |
I think the only thing that concerns me about PUP 5w30 is its KV 100 value is lower than most other 30 weight oils I've looked at: PUP 5w30: 10.3 Castrol Edge 5w30 EP: 10.8 (2.9 HTHS) M1 5w30: 11.1 M1 0w30 AFE: 11.5 Castrol Edge 5w30 LL: 11.6 (3.5 HTHS) Pennzoil Euro L 5w30: 12.6 (3.5 HTHS) I'd bet any quality synthetic 30 weight oil would be fine though. BTW I get the sense that Subaru is much more likely to void the warranty for track use than for using a 30 weight oil.
#23 | |
Yeah, the PUP is a bit thinner but the results are there. I have regularly got the oil temp to about 110C even when i am hooning hwy ramps. In my opinion, i don't think oil temp is as a big factor as the internet makes it out to be. I am sure there are added benefits if you run cooler oil during track use but you are also running other risks outside of track (longer oil warm ups, over cooling, leaks) which can also destroy your engine. It really depends on your usage case. In any case, don't want to turn this into oil/cooler discussion as there are already too many horses killed in this discussion. ![]() Good point about tracking/warranty. I wonder our ECU logs anything that can indicate how the car was driven.
| The Following User Says Thank You to Petah78 For This Useful Post: | Dzmitry (06-22-2022) |
#24 | |
Haha just kidding. Yeah I totally get why people might choose not to use an oil cooler. I'm undecided on this new car personally. It has the OEM style cooler which is better than nothing. I'll look at my own data from the track and decide from there. I'll probably only add one if I start doing 10+ track days/year again and if I can find an oil cooler with a layout I like.I doubt in the ECU logs that they'd record a long enough period of data to prove track use but they could probably make an educated guess based on time stamps, RPM/engine load, and oil temps/pressures. Maybe g-meter values on this new gen? I wouldn't hide from it anyway. Pay to play kind of deal, just my personal take.
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Dzmitry (06-22-2022) |
#25 | |
| The Following 2 Users Say Thank You to Petah78 For This Useful Post: | DarkSunrise (06-21-2022), Dzmitry (06-22-2022) |
#26 |
| The Following User Says Thank You to autosenses For This Useful Post: | DarkSunrise (06-22-2022) |
#27 | |
#28 | |
Drives: 2018 Subaru BRZ Limited with PP
| 2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition | Hachiroku | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 13 | 02-12-2022 11:44 PM |
| 2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition | Hachiroku | BRZ Second-Gen (2022+) — General Topics | 20 | 02-10-2022 11:44 AM |
| DarkSunrise FR-S | DarkSunrise | Member's Car Journals | 69 | 10-18-2021 01:03 AM |
| 2022 992 GT3 | Kiske | Other Vehicles & General Automotive Discussions | 29 | 02-23-2021 07:22 AM |
| 2022 BRZ | g e | BRZ Second-Gen (2022+) — General Topics | 110 | 11-18-2020 09:15 AM |
