Old 06-16-2022, 10:32 PM   #1093
RedReplicant
Drives: None
Nice flat curve Curious what it'd make on a dynojet.
After screwing around with the kpower flex fuel kit today it is my suggestion to not give them your money and make one yourself. The line length and patch harness leave your literal only option as the flex sensor hanging in the air or ziptied to the clutch master hard line, it is actual bullshit.
I put it back in a box and I'll make something myself.
RedReplicant is offline   Reply With Quote
Old 06-16-2022, 11:30 PM   #1094
funkjaw
Drives: 16' WWB
Oh yeah nah I totally agree. Having at least another foot of host/wire would have been very nice. But for me it's not a big deal as my car is just a daily driver with many zip ties already in the engine bay haha
funkjaw is offline   Reply With Quote
Old 06-17-2022, 03:01 PM   #1095
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I emailed Kpower about a fuel gauge update from Haltech. They said they think they will release something soon, but they also mentioned needing to do an update during their last session, so maybe it was patched. Has anyone had a chance to do the latest update who can confirm anything?
Old 06-17-2022, 06:27 PM   #1096
funkjaw
Drives: 16' WWB
Does anyone know which pins on their flex fuel kit harness are used in the ECU? My tuner is asking for this so he can get the flex fuel going....
Old 06-17-2022, 06:34 PM   #1097
funkjaw
Drives: 16' WWB
NVM found in on their website:
https://cdn.shopify.com/s/files/1/11...f?v=1647444499
Old 06-17-2022, 08:49 PM   #1098
RedReplicant
Drives: None
So, for anyone else running an AIM DL.
If you run connected to the OBD cable or BRZ CAN you can pull most of (but not all) of the stock CAN data. Things like temperatures don't work for whatever reason (Haltech probably doesn't have them set up right in their CAN lookup) and the AIM still does that annoying thing where it will constantly turn on even when the car is off.
The alternative is to connect to the Haltech AUX CAN and then you get all of the data that Haltech would normally issue over CAN. The wideband that comes with our kit has an extra DTM connector that you can connect something to, so that is what I did.
If you have an OBD cable for you AIM you can just cut the thing off and pin the wires to a DTM6-4S connector, they are the same internally as the flying lead cable that AIM sells. The colors shown here match the colors of the wires in the AIM harness too.
As a bonus, the AIM doesn't turn itself on when the car is off anymore either.
Old 06-20-2022, 09:08 AM   #1099
redlined600
redlined600's Avatar
Drives: Fr-s
Do you lose the chassis data then like wheel speed, steering angle, brake pressure, ect...?
redlined600 is offline   Reply With Quote
Old 06-20-2022, 12:23 PM   #1100
RedReplicant
Drives: None
No, they are rebroadcast by the Haltech.
Old 06-20-2022, 01:13 PM   #1101
Irace86.2.0
No one has done the update and can verify if the fuel gauge is working better? I'm hesitant about doing the update, as I don't have wifi or cellular in the garage, so I need to go do the update remotely.
Old 06-20-2022, 01:32 PM   #1102
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I've been reluctant to do any updates lately as it seems all others are having issues and having to revert back. My car has also been down still messing with the a/c crap so there's no rush for me at this point.
captain awesome is offline   Reply With Quote
Old 06-20-2022, 05:02 PM   #1103
redlined600
Drives: Fr-s
This is extremely helpful. Thanks!
Old 06-22-2022, 02:14 PM   #1104
RedReplicant
Drives: None
I've heard of a couple more cracked headers with flex sections through the grapevine. Stock S2000 has a solid brace to the motor, wondering if this is something we're going to need to figure out.
edit: also, the header to midpipe flange hitting the chassis
Old 06-22-2022, 08:42 PM   #1105
Irace86.2.0
Does the mid pipe have the exhaust hanger and bracket shown in the installation guide pictures at the bottom, but not seen directly below in the product picture? I ask because that might make a difference. The stock manifolds tend to have support brackets, but they are typically heavier or cast, which crack after repeated heat cycles more than tubular headers (I believe). I feel like there must be thousands and thousands of headers that don't have support brackets and just have a flex pipe section. I would want to see the location of the cracks, and then I could ask myself if this was a weld failure issue or a stress issue.
You could add support braces if you have access to a welder (person or device). It is fairly easy. Just take some exhaust pipe of the same diameter and cut a square out and weld a rod to that piece and then weld the whole square to the manifold and repeat with a flat piece of thick sheetmetal to the side of the block.
Old 06-22-2022, 10:03 PM   #1106
RedReplicant
Drives: None
The most recent one I saw was using the hanger and a Perrin flex pipe exhaust, it completely separated at the last weld before the flange on the header side. Seems like a weld issue to me.
There is also something to be said about the motor twisting on the motor mounts, header to midpipe flange bottoming against the chassis, and putting stress on everything.
I got these pictures from someone that is a friend of the owner, not sure if they are on the forum here too.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
