| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Red 2024 GR86 Trueno
Recommendations on a tool kit for the car?
Hi Guys,
Any recommendations on a small tool kit to keep in the car? Couple screwdrivers, one ratchet, set of sockets. The sets I've seen so far a little more comprehensive than I would need. Something that fits in spare tire well would be great. Thanks! |
| The Following User Says Thank You to haohmaru For This Useful Post: | humfrz (06-20-2022) |
#2 |
Drives: Crapcan
I have one of these as my track day tool kit. Not a huge fan of the ratchets but they get the job done. In the winter time these usually go on sale for like 20 bucks off.
https://www.lowes.com/pd/Kobalt-309-...-in/5001996759
#3 |
Drives: 2015 Scion FR-S
i would recommend getting a bag with a zipper from your local tool supply store and building your own kit, especially if room is a factor.
in the bag get a couple screwdrivers, a 3/8 ratchet, a socket rail to put some common sockets, some common wrenches, any other tools you may commonly use in a road side repair, maybe a bottle of fix-a-flat, or i have kept a 1/2" drive impact to change the tire easier. It really depends on what you feel you are going to do roadside vs available space. |
#4 |
ProCrastinationConsultant
i've got a pretty typical tool bag i throw in all my vehicles.
it starts with a simple bag https://www.harborfreight.com/tool-s...ets-61168.html then 1/4 and 3/8" sockets https://www.harborfreight.com/14-in-...-pc-62303.html https://www.harborfreight.com/38-in-...-pc-61954.html always a volt meter to troubleshoot electrical issues that arise https://www.harborfreight.com/electr...ter-63759.html a multi-bit screwdriver or two https://www.harborfreight.com/4-in-1...dle-61988.html wire stripper https://www.harborfreight.com/7-inch...ter-98410.html wire cutter https://www.harborfreight.com/micro-...ter-90708.html and some e-sockets for the seat bolts. https://www.harborfreight.com/14-in-...-pc-67898.html i also throw in a butane soldering iron, some solder, and a handful of zipties from my garage mega-bag as well for good measure. https://smile.amazon.com/Soldering-M...NsaWNrPXRydWU= https://www.harborfreight.com/11-inc...100-34637.html this covers just about anything that is roadside-fixable for me at least. anything that needs more likely isn't much of a roadside fix anymore.
#5 |
Rust bucket enthusiast
I put a fanny pack with a zipper around the passenger seat headrest (facing the back of the car) and put in 2 of each of the following short and long 3/8ths 10mm, 12mm,14mm sockets. I keep 16mm - 22mm 1/2" impact sockets as well. A 10mm, 12mm, and 14mm wrench.
Associated ratchets, zip ties, metal zip ties, and a foot of DEI sleeving. In a little box in the trunk I keep spare plugs, hose clamps, wire strippers, needle nose pliers, an extending magnet, flashlight, vacuum caps, a spare cam position sensor, a spare MAP sensor. Other notable mentions- a roll of shop towels goes under the passenger seat, jump pack goes under the passenger seat, and a spare quart of oil is tied up in a plastic bag in the trunk as well. A blanket and spare socks. I've needed all these things and not had them in my life. Never again
| The Following User Says Thank You to DarkPira7e For This Useful Post: | soundman98 (06-18-2022) |
#6 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Add a TP roll and you got everything I ever needed.
| The Following User Says Thank You to 2020BRZtS For This Useful Post: | soundman98 (06-19-2022) |
#7 | |
| The Following 4 Users Say Thank You to humfrz For This Useful Post: |
#9 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I've got screwdrivers, pliers, jumper cables and a breaker bar/socket.
So far haven't needed them for my car. It's been fairly well made. What's got the most use is an umbrella.
"I gotta rock." -- Charley Brown |
#10 |
Drives: frs
#11 |
Drives: car
I wouldn't find a reason to carry too many tools. The most I would need is a 10mm wrench for changing a car battery, and a tire iron for changing flats.
Agreed what you really should have is AAA or roadside assistance. Last edited by radroach; 06-21-2022 at 06:46 PM. |
#12 |
Drives: 2018 Subaru BRZ
I keep one of these in my car at all times. I've used 3 times, mostly for helping other people out. Lots of goodies.
#13 | |
Drives: 2013 frs base
....tooth brush, tooth paste, bar of soap, bottle of wine, loaf of bread, pack of condoms, and thou. |
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | DarkPira7e (06-22-2022), NoHaveMSG (06-22-2022) |
#14 |
Who brushes their teeth?
| The Following User Says Thank You to DarkPira7e For This Useful Post: | blsfrs (06-22-2022) |
| Best tool ecosystem? | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 20 | 10-05-2021 06:36 AM |
| FS: OEM Trunk Tool Kit | MicheleAbbate | Interior Parts (Incl. Lighting) | 7 | 09-12-2016 02:04 PM |
| pry tool | jazztennor | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 12-15-2012 03:02 AM |
| What does this tool use to | carscat | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 06-27-2012 10:24 PM |
