Old 06-08-2022, 12:43 PM   #1
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
Input from gmeter possible?
I want to add a second fuel pump to my fuel tank passenger side. Id like for it to come on and off based on the amount of g's the car is pulling. Is it possible to get input from the gmeter plugged into computer and get output to the second fuel pump to come on. Does anyone know if this is possible.
Thanks
Rabrooks is offline   Reply With Quote
Old 06-08-2022, 12:57 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Possible, yes. Shit ton of work, also yes.
Old 06-08-2022, 01:53 PM   #3
Rabrooks
Rabrooks's Avatar
Can you elaborate.
Old 06-08-2022, 01:59 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Rabrooks View Post
Can you elaborate.
G meter on dash coms through canbus. So you are asking to create a device that looks for that signal, can read and interpret that can value, then based on the desired value switch on a pump. Geraldjust would be good to talk to about this as he is a can expert. To me it would be easier to trigger the pumps through other means. I am working on some arduino based setup but it will probably be most of the year before I am done with it.
Old 06-08-2022, 02:28 PM   #5
Rabrooks
Rabrooks's Avatar
I will contact Gerald and see what his tboughts are. Thanks
Old 06-09-2022, 07:07 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Imho some mechanical means to solve the issue, eg. some baffles/plates to reduce chance of fuel starvation (IIRC in left-hand turns) for fuel pump, just enough to last for fuel for one long curve would be much cheaper, simpler, reliable. No uber advanced electronic gimmickry that will take much more time & money, if simpler means also solve that.
For example, how about this?
Old 06-09-2022, 01:55 PM   #7
It's a great addition but not quite enough for long sweepers when burning alcohol.
Old 06-09-2022, 02:13 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Then maybe some surge tank setup?
Old 06-09-2022, 02:24 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Can confirm. Aero and e85 this isn’t enough. Either surge tank or dual pump setup.
Input dholloway543 Forced Induction 17 11-20-2019 08:28 AM
Need some sensible input... to FI or not modbus Forced Induction 63 09-02-2016 10:15 PM
Need some input LOOK!! skavengers412 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-21-2016 12:50 PM
Looking for SUV Input ap5512 Other Vehicles & General Automotive Discussions 16 09-23-2014 02:48 PM
Need input on Carrozzeria red1993sol User/Vendor/Sponsor Reviews, Feedback, Comments 0 09-25-2013 05:21 AM
