Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 06-06-2022, 03:31 AM   #1
Tonik
Drives: 2022 BRZ
2022 BRZ STI lowering springs
I am considering to update my 2022 brz with the STI springs. I wander if anyone try it on the new brz? I will be appreciated if you can share your feelings of the STI lowering springs. Thanks!
Tonik is offline   Reply With Quote
Old 06-06-2022, 02:42 PM   #2
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
I purchased a set from japanparts.com. Pics are attached.
I'm a terrible judge of aftermarket parts, so take it all with a grain of sale. When I have friends drive my car - they don't realize I've changed anything, so nothing is transformative.
The same time as the springs went on the car got the STI rlca set and Pedders offset front top mounts as well as SPC camber bolt lower and crash bolt upper. The car rides probably a few milimeters lower than stock but also hard to judge because I swapped over 17x8 6UL wheels with 225/45 Falken RT660 tires. Maybe it'd look more pronounced with the factory 18" wheels. Point being, visually they don't do much of anything.
The best way to install the springs is the lift method, in my opinion - put the spring on the perch, attach the lower strut bolt to the hub, then use a jack to lift up the hub and align the top mount through the holes and get a few nuts loosely on. I tried reassembling the STI springs with shocks and top mount with spring compressors and could not get it it work. Be sure to have a pass through socket and tighten it manually with the Allen key in to prevent the strut spinning - do NOT rely just on an impact wrench, I thought it was enough sapping it with the impact wrench, it was not. Had a little clunk on first drive, got the pass through, and realized just how much more it needed to be tightened!
As far as driving impressions go... I'd really love to meet up with someone with a stock BRZ to do a back to back. I think it drives great - it's probably slightly stiffer than I remember the stock setup but it does control the bouncing when driving through dips/undulations much better. It's the only obvious/noticeable change. But other than that I don't know of any difference. I'm not a fan of stiff suspension setups, I like to romp over the curbs and I think the springs do a great job with the factory struts not upsetting the car when the gators get smacked. I'm a fat guy and dislike getting jostled around in the seat! I like em, no negatives only positives and would immediately do them again if I had a new BRZ.
If you're looking for a drop or a stiffer ride, I'd look elsewhere.
Re_Invention is offline   Reply With Quote
The Following 4 Users Say Thank You to Re_Invention For This Useful Post:
Aroundomaha (09-21-2022), DarkSunrise (06-06-2022), mike2100 (06-07-2022), mycrors7 (06-07-2022)
Old 06-06-2022, 03:26 PM   #3
mike2100
mike2100's Avatar
Drives: 23 BRZ
I don't see coil springs listed for the ZD / 22+ yet on the STI Japan website. Did you find them somewhere else or did you use the ZC / 1st gen springs?
https://www.sti.jp/en/parts/subarubr.../ST20330AS000/
https://www.sti.jp/en/parts/subarubrz_zd/suspension/
mike2100 is offline   Reply With Quote
Old 06-06-2022, 04:14 PM   #4
Re_Invention
https://www.japanparts.com/parts/detail/?id=62958
https://www.japanparts.com/parts/detail/?id=62959
https://www.blackhawkjapan.com/produ...f6199157&_ss=r
Wild - it appears the sti japan catalogue removed the springs from the list of parts. But it's still listed on their website:
https://www.sti.jp/parts/subarubrz_z.../ST20380Z2000/
The Following User Says Thank You to Re_Invention For This Useful Post:
Old 09-20-2022, 06:03 PM   #5
MauraMillender
Drives: My car sounds very good
I was considering upgrading the springs on my 2022 Brz to see if it would be beneficial.
MauraMillender is offline   Reply With Quote
Old 09-21-2022, 12:28 AM   #6
eyeballs
Drives: '22 BRZ
That mini has got to be an absolute riot on an auto-x course.
eyeballs is offline   Reply With Quote
2022 GR86\BRZSport springs Master Jedi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-23-2022 01:10 PM
WTB: TRD Lowering Springs mikwerdna Canada Classifieds 3 04-17-2020 11:11 AM
TRD lowering springs LordTaikun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 68 01-29-2017 01:03 PM
FS: D2 Lowering Springs Lumbajackmeh Brakes, Suspension, Chassis 6 03-17-2016 10:18 AM
WTB trd lowering springs Heyitsryan Want-To-Buy Requests 0 07-20-2014 01:52 AM
