Old 06-03-2022, 07:45 PM   #15
jrhudson
Drives: 2016 scion frs
Would take a big-ass soldering iron/gun to get enough heat into that cable but, honestly, it's what I would do. Heat shrink is a pro move.
Thanks!
i dont have anything on hand to burns that hot. i tried with a propane burner thing and yea didnt get hot enough and this was just so i could move the car move the car around, it hasnt moved a full mile in like a month, still gotta pull the motor because of the trans rattling.
jrhudson is offline   Reply With Quote
The Following User Says Thank You to jrhudson For This Useful Post:
humfrz (06-04-2022)
Old 06-03-2022, 08:53 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by jrhudson View Post
...okay so i realized i bought the wrong thing. The terminal that broke was actually on the side coming from the fuse box. ugh have to get those battery terminal things for the positive side. This is annoying.
check your local car parts shops. many rent tools, they might also have a terminal crimper.
Ultramaroon (06-04-2022)
Old 06-04-2022, 01:21 AM   #17
Bubba's plan B.
soundman98 (06-04-2022)
Old 06-04-2022, 01:24 AM   #18
Thanks!
jrhudson, I'm ah starten ta worry bout ya - why do you feel you have to pull the motor (engine) to fix the transmission? -
Old 06-04-2022, 01:26 AM   #19
soundman98
soundman98's Avatar
easier than pulling the rear diff?
humfrz (06-04-2022)
Old 06-04-2022, 01:27 AM   #20
jrhudson
it was coming out for a different reason already.
humfrz (06-04-2022)
Old 06-04-2022, 02:20 AM   #21
Well, yes, that would be true -
Part number for fusible link block on positive battery terminal? Jack Black Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 08-24-2022 08:58 AM
Battery terminal covers 2017BRZ4ME BRZ First-Gen (2012+) — General Topics 21 04-27-2020 12:04 AM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 12:55 PM
Battery terminal setup fuddbutter Electronics | Audio | NAV | Infotainment 0 01-24-2017 04:27 PM
Lost my battery terminal nut. qqzj BRZ First-Gen (2012+) — General Topics 3 08-05-2014 07:51 AM
