Old 06-01-2022, 04:20 PM   #1065
funkjaw
Drives: 16' WWB
Originally Posted by captain awesome View Post
You'll need to cut your Kpower intake or buy the proper one for an PRB head. Now you no longer have the water neck on the back of the head. The PRB outlets are located on both the intake and the exhaust side. Unfortunately the larger coolant hose needs to get all the way to the passenger side from the intake area to connect unless you have a custom radiator with an inlet on the driver side. I've done the mental gymnastics on this but it seems like it ends up just costing the same or more than a ported head since the PRB usually ends up between 800-1200 for a good core.
I think it's still possible but don't know if it's worth the effort or cost if you bought the complete kit. Maybe if you pieced your build together it could be a more economical choice?
Wow thanks a ton, that is very good info. Sounds like I won't be going this route haha.
funkjaw is offline   Reply With Quote
Old 06-01-2022, 11:21 PM   #1066
RedReplicant
Drives: None
Originally Posted by RedReplicant View Post
I used the calibration posted by ML in this thread, the numbers seemed sane to me when I was looking at it pre-start. Saw 90f on a 'cold' motor which felt in the ballpark to my garage temp. File: https://drive.google.com/file/d/1QLq...ew?usp=sharing
I sure hope this calibration for oil temp isn't right. I don't have my oil cooler plumbed yet but I can't see 240-270f oil temps being right when doing a few pulls then cruise for a few minutes and repeat.
RedReplicant is offline   Reply With Quote
Old 06-01-2022, 11:33 PM   #1067
funkjaw
Drives: 16' WWB
That does seem high for sure - did you get your coolant bleed all the way? What were your coolant temps at that time?
Old 06-01-2022, 11:36 PM   #1068
funkjaw
Drives: 16' WWB
If anyone is curious - I live in an emission inspection / smog check part of Texas and my Kpower Kswap BRZ passed the inspection no problem.
The Following 2 Users Say Thank You to funkjaw For This Useful Post:
Irace86.2.0 (06-02-2022), Wally86 (06-03-2022)
Old 06-01-2022, 11:51 PM   #1069
Jdmjunkie
Drives: Scion FR-S 10 Series
How does smog work there? Do they plug into the obd2 plug or is it a tailpipe test?
Jdmjunkie is offline   Reply With Quote
Old 06-02-2022, 12:09 AM   #1070
funkjaw
Drives: 16' WWB
All they did for my BRZ is plug in the OBD2 port and check for any trouble codes. For this to work in the Haltech the OBD2 Bus Selection must be enabled (this is enabled by default in the Kpower base map, see this knowledge base page from Haltech). I don't think the testing equipment cares that the swap disables the drive cycle monitors (i.e. in California if the monitors are disabled it is an automatic fail and is one way they catch ECU swapped cars).
There was no tail pipe test, no hood pop, no catalytic converter check, etc. although I do think they test the gas cap. The test seems super basic compared to states like California. I was surprised I passed but am super happy it did. There is also a safety portion of the check which they basically just make sure your car can stop.
The Following User Says Thank You to funkjaw For This Useful Post:
Jdmjunkie (06-02-2022)
Old 06-02-2022, 08:23 PM   #1071
RedReplicant
Drives: None
I spent a bit more time with the car today and figured out a few things.
1. The oil temp can have wide swings in a short period of time if you are watching it as you go from like a highway cruise to a 3rd gear pull and lift.
2. The car stays in the 180's when cruising around, if I slow down or get into traffic it slowly makes its way north of 200. I found my two 25a fan fuses popped, replaced them and they popped again on the next drive.
It appears the previous owner of my car put Spal fans into the car but didn't use a relay kit, as to why the fuses decided to start blowing after the swap I have no idea.
Old 06-02-2022, 08:57 PM   #1072
funkjaw
Drives: 16' WWB
So I too used the calibration file you listed for the oil temp, and yup when I floor it the temps swing super wild; definitely does not seem right what so ever and I suspect it is not accurate. Not sure what is going on... you can see the video here: https://www.youtube.com/shorts/5gZxEJi04kk
Old 06-02-2022, 09:12 PM   #1073
RedReplicant
Drives: None
Yeah, that is exactly what mine does.
Looking around, these Mazda sensors are a Bosch part. I tried a couple of the calibrations floating around onlineand they both gave me negative temperatures. It isn't clear to me, my first guess if it wasn't the calibration was some kind of wire shielding issue since it is a 2 in 1 sensor, but I hadn't gotten that far into it.
The Following User Says Thank You to RedReplicant For This Useful Post:
funkjaw (06-02-2022)
Old 06-02-2022, 09:17 PM   #1074
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I know ML had to send me an updated file so maybe the wrong one was posted? I haven't had any temp swings like that on mine.
captain awesome is offline   Reply With Quote
The Following User Says Thank You to captain awesome For This Useful Post:
Old 06-02-2022, 09:22 PM   #1075
funkjaw
Drives: 16' WWB
Can you post it by chance? I can run a diff between the two and see if anything is changed.
Old 06-02-2022, 09:31 PM   #1076
captain awesome
Wears Pants
Try this one.
CLICK ME
Old 06-02-2022, 10:39 PM   #1077
RedReplicant
Drives: None
Unfortunately, that is the same as the one I've been running. This is pretty weird.
Old 06-03-2022, 01:02 PM   #1078
captain awesome
Wears Pants
Definitely weird. I would confirm it's wired correctly at the sensor as well as at the Haltech plug? Seems unlikely to be the case since RedReplicant appears to be suffering from the same issue but worth checking out.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
