#1303 |
Drives: GR Corolla
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | soundman98 (05-27-2022) |
#1304 |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#1305 |
Drives: GR Corolla
| The Following 3 Users Say Thank You to Kaotic Lazagna For This Useful Post: |
#1306 |
Just post pictures on a model site. SOMEBODY will know! You think we can be bad?
“Clearly that was repainted. You also used Tamyia Royal Red X24 when that year S15 should be Tamyia Royal Crimson X24b NOOB”
#1307 |
Drives: GR Corolla
LOL. Yeah. I don't doubt there are those who can spot the most minute thing in builds.
#1308 |
They are usually Germans.
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (05-27-2022) |
#1309 |
Drives: GR Corolla
#1310 |
Drives: RX-7 / BRZ
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | Tcoat (05-27-2022) |
#1311 |
Yep. Gold star senior top of the pack. Their work is often not a whole lot better than what they critique though.
#1312 |
Drives: GR Corolla
Tried CF decal'ing the vented hood. Pretty dang hard! Got some creases and I'm giving up before I make it worse. I'll clear coat it when I clear the body (after attempting to fix it).
#1313 |
Did you use decal setting solution? Softens them up and can usually work out creases.
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (05-28-2022) |
#1314 |
Drives: GR Corolla
Yeah, used Tamiya's softening setting solution and hair dryer. The main creases are where the vents shape taper off. Not really sure what the term is for that part of a vented hood. I'll try to snap a pic.
#1315 |
Drives: GR Corolla
If you look towards the cowl end of the hood, you'll see some creases. First time trying to apply a large piece decal, so maybe that contributed to it, but no matter what I did, the crease stayed or got worse. This was the smoothest I could get it, and I have no clue why that middle crease formed and wouldn't go away.
#1316 | |
Drives: RX-7 / BRZ
Time to learn to paint the effect. Skip to 5minutes into the video. Nylon stocking/pantyhose/legging material stretched around a prepainted part. Can even be don with spray bombs! Lightly mist your texture color through the nylon to get your pattern. Go crazy on preparing the parts and wrapping the nylon around them into all the intricate shapes. You can then use clear it. Adding some smoke/clear black will further add depth and help with the scale illusion of the parts. I've also seen people use cheese cloth, drywall tape, and mesh sandpapers for similar effects
| The Following 4 Users Say Thank You to Kiske For This Useful Post: |
| TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 07:31 PM |
| Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 11:11 AM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
| plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 01:02 PM |
