Old 05-25-2022, 01:30 AM   #1
conehead
Drives: RS 2.0
No BS: why do they blow engines all the time?
OK, ok. I know there is golden info buried in different threads, but someone please break it down. Why do 86 track cars always have blown engines? Is there an easy solution??
I love them, I own one, I have boxes of autox trophies. I do other racing and this seems like the (much better) successor to the spec miata. People call me to sell one and it ALWAYS has a blown engine. Is this solvable or does it ruin the whole platform as a future budget track workhorse?
conehead is offline   Reply With Quote
Old 05-25-2022, 07:13 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The top reasons I can think of -
Spun bearings from low oil pressure due to high oil temp, or low oil level
Bad tuning causing issues
The track has great potential to be the highest RPM / load for a long duration any car will likely see. Things will break.
Forced induction
J02 Recall
The reason you see them with blown engines is because people are less likely to sell if the engine and car are running harmoniously
soundman98 (05-25-2022)
Old 05-25-2022, 07:41 AM   #3
Autoxer62
My conclusion is that the lack of oil pan baffling and pickup problem are major contributing factors. You can run any oil you want, but if it doesn't get to the bearings at high RPM it's just a matter of time.
Reference link:
https://www.ft86club.com/forums/showthread.php?t=134863
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following User Says Thank You to Autoxer62 For This Useful Post:
ZDan (05-26-2022)
Old 05-25-2022, 07:55 AM   #4
First off the term "blown" engine can mean a pile of different things.
Head gasket - Overheating or over boost
Spun bearings - Heat again, oiling issues
Thrown rod - Heat (notice a pattern?), over boost, money shift (no matter how vehemently denied)
Then there is bad tuning issues, defective parts (rare other than sealant), poor setups putting excessive strain on the driveline beyond the design max, just poor driving (see thrown rods) that can cause all sorts of issues up to actually "blowing up" an engine.
As Dark said the number of blown engines is probably not near as high as reading social media or forums may make it seem. There will be thousands of trouble free track cars out there for each one that blew an engine. Also see very, very, very few 2014+ cars with blown engines so it is mostly an early production issue.
gcmak (06-17-2022), jcw99 (06-10-2022), nikitopo (05-26-2022), racingfool (05-25-2022), Scargod (06-08-2022), Veypor (05-25-2022)
Old 05-25-2022, 08:36 PM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
I've been to the track at least 50 times and seen about a million (slight exaggeration by a bit) 86's and have never seen or heard of anyone blowing an engine.
These are all short technical tracks.
The Following 3 Users Say Thank You to new2subaru For This Useful Post:
evanescent03 (05-26-2022), kevaughan (06-09-2022), NoHaveMSG (05-25-2022)
Old 05-25-2022, 08:42 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
As bad of a rap as the FA gets its not fragile. I know of a couple guys who have spun rod bearings. I had a fluke rocker arm ejection which led to a thrown rod.
The main thing I have seen with used cars with blown engines is they are expensive long blocks and a PITA to rebuild since the case halves have to come apart. Short blocks new from Subaru are like 1800 which isn’t terrible. I have been tracking my car for years and have seen my oil pressure gauge drop out under high loads and it’s still fine. A baffle will help a lot.
The Following 7 Users Say Thank You to NoHaveMSG For This Useful Post:
Aroundomaha (06-12-2022), CSG Mike (05-26-2022), kevaughan (06-09-2022), new2subaru (05-25-2022), Opie (06-13-2022), Scargod (06-08-2022), soundman98 (05-25-2022)
Old 05-26-2022, 12:45 AM   #7
conehead
Drives: RS 2.0
Thanks for the input. It does always seem to be spun rod bearings. I have read some of the treads with extensive oil passage reworks, but that is way above what I would consider budget friendly.
I guess I should ask it this way, if using a stock engine, bolting on ?????? parts is enough to stop it from spinning bearings. Most cars have have some weak links that need regular replacement, but the whole engine can't be one of them.
Baffles and oil pick up tube? Have people had success with that?
Old 05-26-2022, 11:05 AM   #8
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
My first engine had baffled pan and don't know what else (I bought it as a built race car with a reliable history.)
I blew the engine the first race weekend after a long left hand carousel holding >1G the whole time.
When I replaced the engine, I reinstalled the baffled pan and had DD Performance port the oil passages on the timing cover and install Toda oil pump. I also installed data acquisition at the same time to record oil pressure.
Took the car to another local track, and even with the above mods, the oil pressure was still going nuts in a few turns- particularly hard lefts after a braking zone.
Sooo I installed a 2 qt Accusump as well. That has improved the situation and the oil pressures are higher in the turns but still ugly.
The issue is that these engines are flat and wide. under hard cornering, all the oil schleps to the outside head and valve cover and doesn't drain back into the pan before the oil pump empties the sump. voila. no oil, spun bearings. done fast enough, it doesn't just spin the bearing but breaks a rod and the rod then turns into an axe and chops the block into pieces.
I'm working on some other ideas on the oiling and will post about them if they work.
Matt93SE is offline   Reply With Quote
The Following 11 Users Say Thank You to Matt93SE For This Useful Post:
conehead (05-26-2022), gcmak (06-17-2022), Jdmjunkie (05-26-2022), kevaughan (06-09-2022), Lynxis (05-26-2022), NoHaveMSG (05-26-2022), PulsarBeeerz (05-27-2022), soundman98 (05-26-2022), Tatsu333 (05-28-2022), timurrrr (05-26-2022), Wally86 (05-26-2022)
Old 05-26-2022, 11:12 AM   #9
andys_garage
Drives: 2022 GR86 Premium Track bRed
i'm gonna add this to the list of reasons to not spend a bunch of money adding grip to this car.
andys_garage is offline   Reply With Quote
The Following 4 Users Say Thank You to andys_garage For This Useful Post:
gcmak (06-17-2022), Ohio Enthusiast (05-26-2022), Tatsu333 (05-28-2022), timurrrr (05-26-2022)
Old 05-26-2022, 12:06 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Interesting. One of our local tracks has a long left we call the carousel, my oil pressure fluctuates a bit but stays just under 40 psi for the most part with no oil pan baffle. It’s a steady 1.2g in my car. It’s a corner I get fuel starve in, especially with e85.
Old 05-26-2022, 12:29 PM   #11
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Edit: I'm going to preface this with an edit becauset I realize that something I take for granted but is likely the biggest contributor of problems; basic maintenance. Everything written below is assuming your failure isn't related to incorrectly performed or otherwise insufficient maintenance, especially oil changes.
It's pretty well established by now that the issues are typically related to oiling and as Matt93SE points out, this is as much a function of the design of the motor as anything else.
I will say these cars are incredibly popular for track use given their performance, price and relative reliability. I know even at track days with only 20 cars, I'll find at least 3 of these cars which is incredibly high relative rate to all other cars. I don't think it would be a stretch to suggest these are the single most tracked cars in America right now. Just mentioning this because relative numbers are important to keep in mind, if you see 5 blown FA20s for one blown Miata, just keep in mind this is probably proportional to the number of tracked cars out there.
I'll note that the vast majority of people who stick to NA power and street tires (200tw limit) have been driving their cars for years now without a more serious failure than a burnt coilpack. Of the 5 people I personally know who track 2016 or older twins, not one of us has had a blown motor but we've all limited our mods to headers and tune and 200tw tires. I think the higher frequency of issues with tracked cars are largely from people who are adding FI or race slicks and at that point, you should probably be running baffles and sump oiling systems at a minimum but these are the things that are forgotten until a motor explodes.
This is just what my personal, mostly anecdotal experience has to say.
Lynxis is offline   Reply With Quote
The Following 2 Users Say Thank You to Lynxis For This Useful Post:
Aroundomaha (06-12-2022), kevaughan (06-09-2022)
Old 05-26-2022, 12:40 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Track layout also has a big effect. 3 of my local tracks have sudden elevation and camber changes that drop out oil pressure even on slower tires. It’s usually brief.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
timurrrr (05-26-2022), Ultramaroon (05-26-2022)
Old 05-26-2022, 01:10 PM   #13
If I were to purpose-build a boxer, I would start with dry sump and go from there. Won't happen, though. I don't want it badly enough.
Capt Spaulding (06-01-2022), conehead (06-01-2022), soundman98 (05-26-2022)
Old 05-26-2022, 01:28 PM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
That's why my 911 holds 13 quarts of oil in the oil tank.
Wally86 (05-27-2022)
VR6 engines... dem00n Other Vehicles & General Automotive Discussions 29 01-25-2013 01:41 AM
100 hp/l NA engines einzlr Other Vehicles & General Automotive Discussions 95 11-15-2012 07:55 PM
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 04:45 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 03:49 AM
