Old 04-28-2022, 02:09 AM   #1
Eazy-V
FRS won't start
My FRS has been parked in an underground parking lot for about 4 months due to winter/cold weather and was just attempting to start the car for the first time for spring/summer season, but the car doesn't start now.
I've never had this issue before and seemed to happened out of nowhere. I made sure my battery is charged and even tried a portable jump starter, but it keeps cranking and doesn't fire up.
Only different thing I noticed (could be just bad memory) is that the fuel pump prime doesn't seem to be a loud as before (running Walbro 485), but does make a sound when I put the key into the ON position.
If there is an issue with the Fuel Pump then should I be getting DTC codes? Also, I'm running an EcuTek tune for years, would EcuTek logs show fuel pressure from the the fuel pump? Also, any suggestions would be appreciated.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 04-28-2022, 03:02 AM   #2
You might have someone spray some starter fluid in the intake as you turn the engine over.
Well, hell, it used to work, back in the day -
Old 04-28-2022, 08:30 PM   #3
Eazy-V
Yeah, I might have to grab a can of that and see what happens.
I'm not sure if a datalog will show anything useful, but I'll try to grab a log during cranking.
The Following User Says Thank You to Eazy-V For This Useful Post:
humfrz (04-29-2022)
Old 04-28-2022, 11:10 PM   #4
Eazy-V
It looks like my battery is not good, but I used a jump starter and attached the logs, so would the logs indicated fuel system/pump is working?
https://datazap.me/u/eazy-v/2013-frs...12-13-16-17-35
I also have this log which was just a few minutes before and I noticed the variable "fuel quantity total I" goes from 0 to about 71, so what would that represent?
https://datazap.me/u/eazy-v/2013-frs...ta=12-13-16-17
Old 04-29-2022, 08:49 AM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
buy new battery and test it out
Old 05-01-2022, 02:36 AM   #6
Eazy-V
Tried new battery and still only cranks, I'm guess it's a fueling issue and added a new datalog:
https://datazap.me/u/eazy-v/2013-frs...16-17-26-32-35
One variable on the graph is "fuel quantity total I" which shoots to 70.56, so not sure what that means and if that's normal?
Old 05-20-2022, 09:54 AM   #7
Eazy-V
Got it resolved, found that the inline fuse on my Deatschwerks fuel pump hardwire kit was completely melted
Old 05-20-2022, 10:23 AM   #8
OK so now the question is why did it melt?
soundman98 (05-20-2022)
Old 05-20-2022, 11:10 PM   #9
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Where is this inline fuse you speak of? It's not part of the Deatschwerks 9-1010 fuel pump install kit for the Walbro 485 pump I hope...
BirdTRD is offline   Reply With Quote
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 11:32 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 03:12 PM
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 12:54 PM
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 10:57 AM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
