#3851 | |
ProCrastinationConsultant
windows 7 was peak windows. 10 and beyond is just getting bloated. i'd still be on 7 if there were updates, but can't even update to service pack 2 anymore from my install disc...
#3852 |
Yea, I agree. Too bad Windows 7 wasn't the "last version of Windows", you know, like Windows 10 is...was...said it would be...we were just joking...
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#3853 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
*nix was my preferred platform for work. The filesystem and device interfaces just make sense to me.
We had Apollos, Sun, AIX and various off brands that don't exist anymore. PDP was a dedicated digitizer, but we only used it for acquisition. Used the unix boxes for manipulation. Then we had to shove various files and DBs into and out of IBM 370s. Those were, uh, well ... The great advantage is the mnemonic tool commands and not having to waste memory on whizzy graphic displays that only make things dumber. If you don't have to hunt and peck, some actual work can be performed in short order. Started mid 80s but only got a home linux system in 95 with Redhat. I've got a Redhat sticker in my 86. No, not a meshback. Only using W10 now because it came with the laptop and Ubuntu was still a bit unsure with UEFI at the time. Thought I'd see what the peons were coping with for a while. Looks like time's up. Ever goin' to give it up ...
"I gotta rock." -- Charley Brown |
#3854 |
TRACKBREAD
I知 piecing together some parts to get my old PC running as a home server. I have a B450 mobo laying around so I知 looking for a 2200G or 3200G processor, maybe an athlon 220G. Basically anything AM4 that痴 on the low end of the power scale.
Plan is for it to have it run as a Plex server, NAS to back up the other PCs to, and a Pi-hole. I知 thinking of going with Ubuntu and use my MacBook to remote into it since it値l just be plugged into power and Ethernet. Anything obvious I知 missing? Any additional capabilities I can add to a home server? Any tips for keeping power consumption down? Going with an APU keeps me from wasting power on a GPU, and it leaves more room in the case to add 3.5� HDDs for storage/backup space. |
#3855 | |
....and it makes me look like a TV hacker to the young bucks that have no idea how to use the commands.
#3856 | |
Does the MB support at least mirroring natively or are you doing it through software for the NAS functions?
#3857 | |
Drives: 2017 BRZ
Note with APU it won't support ECC RAM. Your call on how much you care. Also count your cpu lanes and choose cards wisely. I have HomeAssistant in a VM, data logging (tracking electric costs live from the meter and ComEd api, and more), my Squeezebox server, a couple time machine shares, a VM for hosting rFactor2 events, and I'm barely scratching the surface. I ended up with an ASRock Rack board with IPMI so no video card at all, ECC memory, LSI card and Mellanox card (SFP+ via DAC to a 10g SFP+ switch on the internal network side). It supports binding VMs and Docker services to VLans. About 50W with the disks spun down. Mirrored SSD "cache" drive, VM and Docker off a pcie m2 drive. Music on its own SSD.
#3858 | ||
TRACKBREAD
#3859 | |
Drives: 2017 BRZ
RAID 1 how? software or hardware? How easy is it to recover/replicate if the OS has to be rebuilt, or hardware dies? This also limits scalability. (this is all stuff I learned when I wandered further down the path...) I started out running a standard server install and manually maintaining docker images, VMs, etc. My two VMs were migrated over directly from that variant of the server, in fact. It was frustrating work to get in to manage the VMs, half the network config was stuff I bookmarked and upon review still took hours to remember what I did / where stuff was (google just returned instructions for older flavors, the new stuff doesn't work that way...). By comparison, the Unraid UI is a blessing. Far too easy to set up and get going, though some quirks to learn. And unlike TrueNAS (the other option I was considering) very memory efficient. Also no scaling limits on storage since it's a different approach to handling drive failures - as long as the file-system is readable, you can always pull stuff off a single drive even w/o Unraid. VMs are super easy to run and maintain - mine are both VLAN bound and show up as independent machines on my network topology - so I'd not discount that as an option for your security stuff. I'm dabbling in Unifi/Ubiquiti on the camera front so for now not looking elsewhere... I did need something that was completely headless as it's tucked under my rack. If you want to be closer to the metal on managing your setup, by all means forge ahead! I can do it (and started out doing so), but don't enough where I remember the details so it's slow tedious work... I like the 'magic' in this case. I mostly know what it is doing so am probably configuring stuff properly and can dig in if needed, but don't really need to. Whatever road you wander down, have fun.
#3860 |
Drives: 2018 Subaru BRZ
Imagine scalping every single possible GPU away from people who wanted to upgrade their workstations/gaming pc, to build mining rigs, or to scam people for their money, just to watch your efforts crash hard as bitcoin falls below 30K. Add to that, those who hoarded GPUs now have to sit on their inventory and sell it at MSRP, or even below as prices continue to fall due to increased availability and new gen releasing soon.
敵od gave me an okay mind, but a really good ass, which can feel everything in a car.� Nikki Lauda
#3861 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#3862 | |
Next task is to hook it to the 70" TV in the gaming room so you can watch others play. Then I want to connect some BT controllers to it so you can play either on the arcade machine or on the TV with the controllers. That would also potentially allow 4 player games.
#3863 |
Never get Razer headphones. After a constant battle with EQ settings, THX, Surround Sound, and re-installs. I'm done.
#3864 |
I really like my SteelSeries Artis 7 headset. Most comfortable I've ever owned and I find both the playback and voice channels easily adjusted to my needs.
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 04:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 06:37 PM |
