Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-19-2022, 04:14 PM   #953
Sym
Sym's Avatar
Drives: 2022 BRZ
Originally Posted by mike2100 View Post
Is that the new version for the second gen, or did you order the version for the first gen?
Its the 2nd gen version. Ordered back in December, they're finally reaching US suppliers.
Sym is offline   Reply With Quote
Old 05-19-2022, 05:20 PM   #954
mike2100
mike2100's Avatar
Drives: 23 BRZ
Oh man that's a long wait. But I'm excited for you! That's the catback I've been looking at. Maybe if I order one now it will arrive by the time my car does! haha
mike2100 is offline   Reply With Quote
Old 05-19-2022, 06:25 PM   #955
joemysterio
Drives: Mini
Oof, that's a month longer than I have to wait currently. I ordered the Spec L BT004 in mid March, my ETA as of now is about mid August.
I'm really excited to hear some sound clips, Sym!
joemysterio is offline   Reply With Quote
Old 05-20-2022, 04:53 PM   #956
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Finally got around to installing my front and rear dashcam. For now, I'm using the 12V outlet for power but eventually, I'll hardwire it. Speaking of hard wiring, where is the best fusebox located for me to siphon off some power for the dashcam?
I just tucked the wire in between the trim and headliner, didn't have to take anything off.
Interceptor777 is offline   Reply With Quote
Old 05-20-2022, 08:11 PM   #957
joemysterio
Drives: Mini
On mobile. Hopefully that links work. Anyway that's what I'm using at the moment. The 15A is always on, and the 7.5 comes on with accessory if I'm not mistaken.
Old 05-21-2022, 09:38 PM   #958
Sym
Sym's Avatar
Drives: 2022 BRZ
Only a couple of cold start vids for now - still need to record some interior/flyby clips.
https://streamable.com/8zij22
https://streamable.com/ubsic0
Old 05-21-2022, 10:01 PM   #959
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
First roadtrip! 400km round trip, averaged 7.9 l/100km (per both the trip computer and the gas pump at the end).
Next week is license plate relocation and camber bolts (assuming they ever arrive).
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 05-22-2022, 12:34 AM   #960
eyeballs
Drives: '22 BRZ
Finally installed my ss-1 kit and used my new hubstands for the first time, though I think I might raise it a bit once things settle. An inch of lowering doesn't sound like much, but it sure seems low now. Not looking forward to resetting pre-load on everything again.
These cars are pretty easy to swap suspension on, though whoever designed the sensor clip that goes into the top hole on the strut bracket up front needs to be fired. I spent WAY too much time getting that off the strut.
eyeballs is offline   Reply With Quote
Old 05-24-2022, 10:30 PM   #961
chikubi
Drives: 2022 BRZ
Big ole' box o' fun showed up earlier today. Unfortunately have to wait until next week to put it on.
chikubi is offline   Reply With Quote
Old 06-02-2022, 12:00 AM   #962
DarkSunrise
DarkSunrise's Avatar
First mountain drive (slowly since I’m still in break-in). Brought my kid along and he loved it. Afterwards gave the car some STI goodies.
2022 BRZ Build
2013 FR-S Build
Old 06-03-2022, 03:03 PM   #963
LoneFashion
Drives: Arriving
Im looking at finally buying some wheels coilovers. Not really sure what wheel specs since I dont want to roll the fenders. Any recommendations for coilovers on the 2022?
LoneFashion is offline   Reply With Quote
Old 06-03-2022, 09:00 PM   #964
eyeballs
Drives: '22 BRZ
Depends on what size and type of tire you want to run, how you use your car, how much comfort you want, how much money do you want to spend, etc. There is tons of info on this forum to help you answer those questions. You'll be best off doing some searches though the forum so you can learn what would work best for YOU. As far as coilovers are concerned, what works on the 1st gen generally works on the 2nd gen.
Old 06-05-2022, 04:12 PM   #965
jbug187
Drives: 2022 Subaru BRZ Limited MT
Got new wheels, tires, Killer B exhaust tip extenders and fender flares installed. Also switched from Power Stop Track Day pads back to stock since I won't be able to get back on track until September.
The offset calculator numbers I ran made me think that I was going to need to roll, pull or cut the fenders under the flares, but the two body shops I took the car to said it doesn't look like there will be any rubbing.
The most difficult part was installing the exhaust tips since one of the flange heads sheared off. I tried to get the sheared bolt out with a center punch, left hand drill bit and some penetrating oil, but no luck. I think I may need to buy a new exhaust tip and find a way to get the existing one off.
I've had my eye on some Hipermax S coilovers, but now I'm not sure about moving away from stock suspension if it means I might have rubbing and have to change the fenders.
jbug187 is offline   Reply With Quote
Old 06-05-2022, 04:19 PM   #966
Interceptor777
That looks extremely sharp!
Also coilovers don't mean you have to rub, they're height adjustable so you can run as low or as high as you want. You could run stock height and still have much better handling.
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
