| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#15 | ||
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
** Canceled the RPF1s, and will likely be getting the ARC-8s. Thanks for the feedback : ))
https://www.corvetteforum.com/forums...-compared.html Regarding spring rates, as far as what I understand from my long (and awesome!!) discussion with Karcepts, the new cars push more with square spring setup compared to first gen cars. Spring rate is also much more important than a sway bar when there's heavy compression, like turn-in. My local tracks are all full of sharp turns. Anyway, looking forward to playing with it all once I receive the car and all these parts.. Quote:
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
#16 |
Drives: 2015 BRZ Series.Blue
Stock brakes. You only need pads and fluid. Experts on this forum agree.
#17 | |
Has anyone installed 6 point and race seats in these cars, yet?
#18 |
LMGTFY
Drives: 13 FRS, 91 Miata
| The Following 3 Users Say Thank You to x808drifter For This Useful Post: |
#19 | |
Drives: 2022 MT Neptune GR86 Prem.
https://www.carid.com/acdelco/drum-b...SABEgL4h_D_BwE |
| The Following User Says Thank You to CincyJohn For This Useful Post: | X25 (05-05-2022) |
#20 |
Drives: 2015 Scion FRS Release Series 1.0
Both are correct. If you want your car to do a few track days a year, dedicated track pads like xp24s and G4 335 fluid will be perfectly fine.
But if you’re doing one like once a month, it makes more sense to have better heat dissipation… so a bbk would be in your interest |
#21 |
Drives: 2022 BRZ WRB
Brake master cylinder support?
#22 |
Do we know if this is an issue in second gen cars? The new car is stiffer (which might also mean stiffer firewall), and also BBK would probably be easier on the master cylinder since you probably don't need to slam it as hard as you would with the slider OEM brakes.
Anyway, just thinking out loud.. : )
| The Following User Says Thank You to X25 For This Useful Post: | Midnightsky (05-11-2022) |
#23 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Racecomp Engineering (05-19-2022), RToyo86 (05-18-2022) |
#24 |
Mike, do you think 299mm kit will be enough for the Hoosiers? You guys still haven't shipped, so I guess we could still upgrade if 325mm kit would be a better fit : )
#25 |
Drives: 2022 GR86 Premium Track bRed
You mentioned raybestos being out of stock:
I was able to get a set of ST-43 from LPI Racing, but basically he said he called porterfield and they managed to find the materials they needed to make the ST-43 rear on the shelf by chance. Apparently raybestos is moving a bunch of manufacturing stateside due to the shipping problems we have all come to know and love and their manufacturing has been down for a while |
#26 | |
#27 | |
Balance wise, the 299 is better; if you want a larger kit, I'd point you to something else. If you want AP, the 9660; if you want Brembo, the BM4. No ETA on the 9660 either, as Essex is very, very late on all of their updated Sprint kits due to supply chain issues. |
#28 | |
| Takumi788's More Track than Street FRS - Now NASA TT Focused | Takumi788 | Member's Car Journals | 473 | 03-19-2023 10:37 PM |
| What mods needed to turbo a FR-S | TSaanity | Forced Induction | 64 | 09-10-2020 03:36 AM |
| looking for twins-focused shops - track prep/maintenance | burzze | New England | 9 | 06-20-2020 12:51 PM |
| MeisterR ClubRace Coilovers: Affordable Track Focused Suspension | MeisterR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-02-2017 06:22 PM |
| No longer needed, mods please delete | wheelsun | Software Tuning | 0 | 08-11-2016 03:17 AM |
