Old 12-29-2017, 12:22 AM   #15
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
So in other words, they are saying only use the battery when street racing/ autox/ drift/ drag strip and after that when done with purpose to change back to the stock battery.
Dr. BRZ is offline   Reply With Quote
Old 12-29-2017, 06:22 PM   #16
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Amazing DIY!
Old 12-29-2017, 06:59 PM   #17
cjd
cjd's Avatar
Drives: 2017 BRZ
Not designed or tested for that purpose. Very short trips I've actually come home with the battery below its recommended minimum (at least, the charger goes into its safety/recover mode). Also if I leave the dash cams running... a calculated risk on my part. I'm looking at alternatives for camera power while parked, but the short trip thing may still remain (and will bug the heck out of me... why does it happen? no idea!)
Starts the car every time, and I've never run into issues on road trips. However, it's definitely not ideal. You'll probably lower the battery life, and without care you increase the risk of something bad happening slightly. So, yeah - not at all surprised that is their official stance.
Old 01-21-2020, 08:57 AM   #18
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Updated with TRUNK setup
Redid my setup to be in the trunk. I know people say don't do it! Too much Cable Weight! But I only used 2lbs of 4g to run it. My car has a lot of weight reduction in the rear so my goal has been to get more weight off the front to balance it out.
Ive been running it in the Winter now, it does crank slower but will start after a second (2-3 cranks, 20 Degrees). I drive it 3 times a week 100miles a day.
Made A cage out of aluminum bar from Home Depot and rivets, only added a 1.2lb!
Used the above mentioned Terminals up front with an old rubber exhaust hanger as my connection point. The terminals are a hair small, Pepboys sells terminal Shims to make it wider.
Would have preferred to put in behind the spare but there wasn't enough flat space, ( to keep center of gravity central). But it fit easy and easy to drill holes in this location. Used the spare tire mount as my ground point
SuperTom is offline   Reply With Quote
Old 01-21-2020, 01:39 PM   #19
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Question
Originally Posted by cjd View Post
Highly recommend a Shorai tender... It manages individual cells. Less fire risk.
I haven't done my research on this yet, but it sounds like a this is a giant LiPo battery. The Shorai tender sounds like a great idea, but my main concern, the alternator will be trying to charge this battery when driving. What's to say it doesn't over-charge or doesn't charge each cell equally? LiPos burst into a nasty lithium fire when the cells get imbalanced, jarred the wrong way, or even punctured (think a car accident).
ROFL it's Waffle is offline   Reply With Quote
Old 01-21-2020, 09:13 PM   #20
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
you can see teh batterys voltage on your dash. it definitely sags when your lights are off and the alternator is off
Old 01-22-2020, 08:29 AM   #21
ROFL it's Waffle
I guess my point is, the only time the alternator is "off" is when the engine isn't running, since the alternator is belt-driven. Unless there's some kind of controller that cuts off the charging of the battery... am I missing something??
Old 01-22-2020, 08:47 AM   #22
T-Steve
Drives: 2014 BRZ
Kind of an interesting side track that I am investigating: The motorcycle part suppliers now have lithium battery voltage regulators that optimize the vehicle charging for lithium batteries.
For example,
https://shop.revivalcycles.com/lifep...tor-rectifier/
I am guessing that the twins' charging is too tightly integrated to the ECU/PCM to change charging schemes but we can dream...
T-Steve is offline   Reply With Quote
The Following User Says Thank You to T-Steve For This Useful Post:
why? (01-23-2020)
Old 01-23-2020, 12:51 AM   #23
86TOYO2k17
Drives: 2017 toyota 86
I use a 10mm oversized alt pulley. I don’t remember all the numbers off the top of my head and it was a long time ago I calculated. But it put the alternators battery charging more in line with the shorais recommended charging specs. 2 years now, 2 winters, and zero issues so far.
Old 01-23-2020, 01:48 PM   #24
ROFL it's Waffle
I certainly won't discredit that it has zero issues so far. By nature I think about latent failures (e.i. fine now, then out of the blue it's on fire). My confidence is slowly increasing though because people are not reporting catastrophic failures.
Old 05-17-2022, 03:09 PM   #25
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Originally Posted by SuperTom View Post
Thanks I took the battery with me into the store and just starting testing things that would work. Cheap, easy to build, lightweight, solid, no brainer if your going with one of these battery.
Here is a side pic
This is great.
I know you moved it to the trunk already... But any idea if this setup would have any issues with heat due to proximity to rear mounted turbo like the Works kit? I imagine using a heat shield, plus your wrap would be fine, but I read that lithium batteries don't like heat.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 05-17-2022, 08:12 PM   #26
SuperTom
SuperTom's Avatar
Originally Posted by NARFALICIOUS View Post
This is great.
Well its since been moved to the behind the backseat, buts its the same battery still running strong.
As to answer your question I guess the only way to is to put a thermometer in the engine bay to see how much heat your turbo generates, then compare it to the recommended specs for the battery.
The Following User Says Thank You to SuperTom For This Useful Post:
NARFALICIOUS (05-20-2022)
Old 05-18-2022, 06:53 PM   #27
jflogerzi
jflogerzi's Avatar
Anyone have a lead on these batteries. I can't seem to find them anywhere in stock.
2013 Series 10 FRS #553
Old 05-20-2022, 11:50 AM   #28
NARFALICIOUS
It shows the larger battery available on Shorai's website:
https://shoraipower.com/lfx36l3-bs12--p130
NARFALICIOUS
Noob Poster
1988 | 2016
The Following User Says Thank You to NARFALICIOUS For This Useful Post:
jflogerzi (05-26-2022)
DIY: 5lb Shorai Battery Install industrial DIY (Do-It-Yourself) Guides 157 01-11-2024 10:49 AM
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 12:07 AM
KC Machine Tray and Shorai battery + Shorai Charger toeout Engine, Exhaust, Bolt-Ons 0 02-15-2015 05:34 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Blew a fuse... will these home depot fuses work? cdo221 Cosmetic Modification (Interior/Exterior/Lighting) 5 02-17-2013 07:09 AM
