Old 05-17-2022, 05:47 PM   #323
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Not sure how accurate their observations were, but assuming it's true, I really liked that they've mentioned stability during sliding at 30:36, this is something a lot of modern cars lack of and being overly twitchy in drifting, while the new Z is very stable in drifting and easily maintains angle. Looks like this Nissan's feature carried over to the new Z, which is great. Another very good point they mentioned is a very good front end grip, they even said that it's better than on Supra. Again, not sure how true that is, but from looking at the video, it's quite believable. Of course I'd love to test it myself.
Arthur-A is offline   Reply With Quote
The Following User Says Thank You to Arthur-A For This Useful Post:
Dadhawk (05-17-2022)
Old 05-17-2022, 08:38 PM   #324
Have zero issues with the shape or size of the grill in fact I rather like it. It is just those huge open blank spaces on either side begging to have something in them. .
Maybe that's it, the corners aren't balanced with the grill opening. Still, no other Z has needed anywhere near that size, and the middle third is the bumper guard so doesn't function as a grill anyway.
I agree with you on the handles though. I saw a high end car this weekend that had bright chrome on the door handles and that was all you could see. The days of chrome have passed us by I believe.
Old 05-17-2022, 08:47 PM   #325
The chrome, size and high location all add up to "LOOK AT ME I OPEN THE DOORS"
Dadhawk (05-18-2022)
Old 05-17-2022, 10:48 PM   #326
gymratter
Drives: BMW
Nissan Z Hoonage
https://www.nissanzclub.com/forum/th...es-skids.1166/
gymratter is offline   Reply With Quote
Old 05-17-2022, 11:35 PM   #327
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by WolfpackS2k View Post
So they went from viscous to haldex? Even though its stated in every publication to be "mechanical"?
Originally Posted by Arthur-A View Post
Where's the info about the haldex diff? I checked out couple of sources and they say the new Z will have clutch type diff.
Nissan's viscous diffs are not great, for sure. And yeah, active might be better compared to the viscous type.
But still, nothing beats proper mechanical (as in clutch or helical) diff.
Originally Posted by Yoshoobaroo View Post
When OEMs say clutch diff, they mean an active diff with an actuated clutch pack. No manufacturer will put an aftermarket style clutch LSD in a factory road car.
Well, if the clutch pack is actuated by a solenoid and in the end the diff locks properly - who cares if it's not 100 mechanical?
And if it's not good, just throw it out, buy Cuso, Kaaz, OS Giken, etc diff and enjoy.
What the Savagegeese video at 19:55. They say they went to a clutch type diff aka Haldex. They say why too, and it was because the old viscous diff would overheat and go open.
Pretty sure the "Active" part of the Supra and M diff isn't just that it is a Haldex system, but that they use multiple vehicle sensor imputs to activate the LSD before traction is ever lost. It entirely possible the Nissan uses an active diff too, but I haven't seen anything, and I am sure Savagegeese would have said something more if they did. Their technical breakdowns are pretty detailed.
https://www.carbibles.com/2023-nissa...od-brakes/?amp
Old 05-18-2022, 12:31 AM   #328
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
... Another very good point they mentioned is a very good front end grip, they even said that it's better than on Supra. Again, not sure how true that is, but from looking at the video, it's quite believable. Of course I'd love to test it myself.
Well yeah, the GR Supra has a horrible factory alignment. Mismatched camber and toe is very common to be found on them off the boat.
I'm pretty sure a day-one tech at GoodYear could do better.
Add in the active diff's occasional weirdness, staggered tires and bump steer issues early adopter encountered, and your up for a white knuckle track day and one twitchy rear!
A real easy fix but, an eye opener comming out of an 86.
The Following User Says Thank You to Kiske For This Useful Post:
Tcoat (05-18-2022)
Old 05-18-2022, 12:55 AM   #329
gymratter
Drives: BMW
https://www.nissanzclub.com/forum/th...e-review.1146/
Old 05-18-2022, 01:17 AM   #330
Arthur-A
Arthur-A's Avatar
Thanks, but no thanks. Don't want that electronic sensor crap anywhere near my car.
The Following 2 Users Say Thank You to Arthur-A For This Useful Post:
soundman98 (05-18-2022), WolfpackS2k (05-18-2022)
Old 05-18-2022, 08:33 AM   #331
Irace86.2.0
Unfortunately there will always be electronic sensor crap with a Haldex system. The difference is whether it engages after traction is already lost (using less sensors and less algorithms) or it engages before traction is lost (using more sensors and more algorithms) aka active. Active diffs and torque vectoring diffs will out perform a basic haldex diff. They probably feel better than a basic diff that tries to use individual wheel braking or anything else to control vectoring or whatever using the ESC system.
Old 05-18-2022, 08:42 AM   #332
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
IMO they should have gone for a helical diff like the twins. It’s the perfect compromise for a street car. It’s simple, you get predictable lockup, and there’s no clutch packs to wear out, special friction modifiers needed or electronics to go wrong.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Arthur-A (05-18-2022)
Old 05-18-2022, 09:01 AM   #333
ZDan
ZDan's Avatar
Drives: '23 BRZ
IMO helical diffs aren't the best. They tend to be overly locked under light load, but will open up if one of the rears is sufficiently unloaded. I've found a light-preload clutch-type with ramps that progressively lock more with more applied torque to be both less intrusive on the street and to provide more consistent lockup during hard cornering over curbs at the track.
The worn T2R in my LS3 FD would go through lock/unlock/lock cycles trying to put power down at corner exits at the track, very unnerving... Replaced it with an OSGiken ramp/clutch and it was a world of difference!
Irace86.2.0 (05-18-2022)
Old 05-18-2022, 11:02 AM   #334
Yoshoobaroo
TRACKBREAD
To be fair, I didn’t say they were the best. I said they were in my opinion the perfect compromise for a streetcar. No manufacturer would put a clutch type diff in a factory car because normal people would crash.
Old 05-18-2022, 11:48 AM   #335
ZDan
ZDan's Avatar
Drives: '23 BRZ
In my experience a mild-preload clutch-type acts a lot more linearly and with less cycling between full-lock/full-open behavior vs. helicals. Helical in my S2000 and in my BRZ act fully locked under very low speed parking maneuvering with a lot of steering angle, then would radically go from 100% to 0% during such maneuvers when one of the rears unloaded as when pulling into a ramped drive. Clutch types I've run would be seamless and operate unobtrusively in the same situation.
There's nothing about the operation of a minimal-preload clutch-type that should cause anyone to crash. If anything I've found them to act more consistently at the limit vs. helical.
Old 05-18-2022, 12:49 PM   #336
FrickingReallySlow
Drives: 2015 FR-S
All these guys are reviewing the 50K performance version. unless you like the styling and Z nostalgia at that price better to just get a used GT350 or a mustang GT with magna-ride suspension+money for bolt-ons and go full crowd killer lol. I was definitely looking forward to this release but the prices are really not making this worth it.
FrickingReallySlow is offline   Reply With Quote
The Following 2 Users Say Thank You to FrickingReallySlow For This Useful Post:
Irace86.2.0 (05-24-2022), Ohio Enthusiast (05-18-2022)
TOYOTA GAZOO Racing Presents World Debut of the New JDM GR 86 (Second Gen 86)! gymratter GR86 General Topics (2nd Gen 2022+ Toyota 86) 701 03-06-2023 11:36 AM
All-New 2022 Subaru BRZ Makes Global Debut gymratter BRZ Second-Gen (2022+) — General Topics 2296 12-07-2021 10:41 AM
Nissan patrol SUV vs the world SmsAlSuwaidi Other Vehicles & General Automotive Discussions 17 05-13-2013 06:05 PM
World's Greatest Drag Race! BRZ amongst Lambo, MClaren, Nissan GT-R Bfly BRZ Photos, Videos, Wallpapers, Gallery Forum 3 08-29-2012 01:51 AM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 02:57 PM
