Old 04-17-2022, 10:29 PM   #1
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
Android Auto Keeps Crashing -> Need Wireless adapter?
"Launching Error: To use Android Auto, please check the vehicle settings and the Android Device. The application is unavailable due to no GPS signal or the system clock not being set."
I've used two different USB-C cables already and both do the same thing.
I'd like to try a wireless Android Auto box, but i haven't found any that works for Android phones. I bought a Carlink 3.0 but it only supports iPhones.
Stigmaru is offline   Reply With Quote
Old 04-18-2022, 12:03 AM   #2
edj
edj's Avatar
Drives: 2022 Toyota GR86
i had to un-pair my phone from the car and then pair it again. make sure the password
gets generated and stored/accepted correctly. ymmv.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
The Following User Says Thank You to edj For This Useful Post:
soundman98 (04-18-2022)
Old 04-25-2022, 12:09 AM   #3
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
I have the exact same problem/error message. I bought a couple high end USB cables, this didn't fix it. Same problem w/ my Moto G7 and a Pixel4a.
I gave up on Android Auto, and just use Bluetooth. I imagine there will be a firmware fix at some point.
Let me know if you figure it out!
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 04-26-2022, 01:22 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
We use a Motorola MA1 wireless adapter and get the same error some times. It usually fixes itself after a minute or two but sometimes I have to unplug the adapter and plug it back in. I thought it was the wireless having issues but I guess not
Old 04-26-2022, 01:37 PM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I have yet to see this error on the Subaru. Will keep a look out.
Old 04-26-2022, 04:25 PM   #6
Spektyr
Drives: GR86
I got this once. Set the clock.
Never saw it again.
Spektyr is offline   Reply With Quote
Old 05-03-2022, 10:46 AM   #7
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Some phones are a bit picky on what cables they allow for use. For example, my Apple, being Apple, carplay won't fully work unless I'm using an original Apple cable. I had an otterbox $30 cable and it barely works for carplay, but works 100% for charging at home.
Try using some contact cleaner on the USB/charging terminals on phone, cable, and car.
spcmafia is offline   Reply With Quote
Old 05-03-2022, 01:52 PM   #8
Dubscientist
Drives: 2022 BRZ Premium
I had this same issue, I haven't had it since I started plugging my phone before I start the car.
Dubscientist is offline   Reply With Quote
Old 05-04-2022, 02:49 AM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
So the essence of this thread is "Android Auto doesn't work reliably for me, should I replace a supposed-to-be-reliable connection method with a typically-less-reliable connection method"?
Follow the build thread for my GR86!
The Following 3 Users Say Thank You to timurrrr For This Useful Post:
CincyJohn (05-05-2022), DylanJZA (05-04-2022), Yoshoobaroo (05-04-2022)
Old 05-10-2022, 02:24 PM   #10
Mhaley777
Drives: 2022 GR86 Neptune Base AT
Call Customer Care
I had similar issues when I bought my car. It may be a toyota issue. I had to call customer care and they had to update settings on their end in order for my apps to work. Took longer for the toyota app but I was having android issues too and they helped resolve that. If you've exhausted all other options they may not be a bad idea to try. Hope it helps!
Mhaley777 is offline   Reply With Quote
Old 05-13-2022, 02:24 PM   #11
Stigmaru
Stigmaru's Avatar
1) Your hypothesis is highly inaccurate. Don't be a douche. There was a high chance that this is a software bug rather than a connection problem. Bluetooth connection itself is reliable, it's just software that is tricky.
2) I've read on a couple places that people blame the car's clock vs the phone's clock. There could possibly be a bug where if the car's clock and the phone's clock don't match up the Android Auto software crashes and this happens whenever the minute gets offset. Hard to tell as when it does crash the minutes are off between the two but it's difficult to say that it's not just coincidence
3) I fixed the problem. I ended up buying a wireless bluetooth adapter off Amazon (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) This one specifically, and I never got the crashing again. What I noticed is that this Ottocast device is a microcontroller that runs its own software that seems to emulate Apple Carplay. Which is funny because I'm using an Android device. So the Android phone bluetooth pairs with the Ottocast and the phone thinks it's connected by Android Auto, but on the GR86 side it sees Apple Carplay instead. No more crashing. Right now the culprit seems to be with Android Auto just being buggy with the GR86.
The Following 2 Users Say Thank You to Stigmaru For This Useful Post:
treedodger (05-19-2022), Yoshoobaroo (05-18-2022)
Old 05-18-2022, 01:56 AM   #12
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I've seen a good amount of people complain about Carplay and Android Auto issues on the Facebook groups, but they all use wired.
I've been using one of the wireless adapters and I've had 0 issues with mine.
Old 05-18-2022, 02:29 AM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Please re-read the supposed-to-be- and typically-less- qualifiers I've used in my previous post.
Glad the wireless solution helped you and @Andrew025!
Old 05-18-2022, 09:28 AM   #14
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Ugh. That’s like the only one of the major adapters I didn’t try lol. They all had connection drop issues after ~20-30mins of driving on CarPlay. I told myself I’m not buying another one lol
Auto Dimming Mirror Adapter Harness Face_Plant Cosmetic Modification (Interior/Exterior/Lighting) 14 02-14-2024 11:18 PM
FS: Wireless Android Auto / CarPlay Headunit villainous_frx Canada Classifieds 6 04-27-2022 09:41 AM
Android based stereo vs. stereo w/ Android auto redlined600 Electronics | Audio | NAV | Infotainment 12 02-24-2019 03:53 AM
Android Auto Vinsanity091 Electronics | Audio | NAV | Infotainment 7 07-15-2015 04:14 PM
Android Auto im2lazy789 Electronics | Audio | NAV | Infotainment 3 12-06-2014 02:25 AM
