Old 05-16-2022, 10:59 AM   #141
Spektyr
Drives: GR86
Originally Posted by Caeser View Post
Everyone saying to go with the meme knob.
I'd be interested in seeing how you make those buttons.
Spektyr is offline   Reply With Quote
Old 05-16-2022, 11:38 AM   #142
Caeser
Caeser's Avatar
Drives: Future
I had a print shop vinyl print my designs then epoxy a glass dome and a 3d printed base. Removed the top of the OEM shift knob and just press in the new top I made. Stays in without glue. The good thing is it's completely reversible and removable. Maybe I'll swap one every day of the weak. I am tweaking the size a bit so it feels like OEM too.
Caeser is offline   Reply With Quote
Old 05-16-2022, 12:22 PM   #143
Spektyr
Drives: GR86
Ah darn, I was hoping you had some trick to making those yourself that wasn't crazy-difficult.
Old 05-16-2022, 01:11 PM   #144
ddotffoeg
ddotffoeg's Avatar
Drives: 2022 GR 86 - Neptune Blue
Here's my 22 GR86. Things I've done over the last few months:
Carbon Shift Knob, Carbon Hand Brake, 25mm Spacers, camber bolts (-1.38 F and R), 20% window tints, 50% shield, Sound Enhancement disconnect, and Invidia Q300 Exhaust.
ddotffoeg is offline   Reply With Quote
Old 05-16-2022, 01:59 PM   #145
jbug187
Drives: 2022 Subaru BRZ Limited MT
I tried to install SPC Performance 81305 Camber Bolts on my front wheels this weekend, but ultimately got spooked and backed out. The install videos I had found show a 16mm top bolt and a 14mm lower bolt, but when I got the wheels off, both of the bolts were 19mm. Has anyone else run into this? Is it safe to assume I should not be using the SPC Performance 81305 Camber Bolts?
jbug187 is offline   Reply With Quote
Old 05-16-2022, 02:09 PM   #146
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The 14 and 16mm are the shank sizes not the bolt head size. Many run the lower bolts up to with a 14mm camber bolt in the bottom. Some run camber bolts in both holes.
Old 05-16-2022, 02:13 PM   #147
DylanJZA
DylanJZA's Avatar
Drives: GR86 Premium AT Trueno Blue
EDIT: beat me to it
DylanJZA is offline   Reply With Quote
Old 05-16-2022, 02:24 PM   #148
jbug187
Can you get more camber when running camber bolts in both upper and lower locations, and do you know if it would be a different part for a camber bolt that goes in the upper, larger slot? Thanks!
Old 05-16-2022, 02:45 PM   #149
dragoontwo
dragoontwo's Avatar
To run both properly, you would need a 14mm and 16mm camber bolt. It may be more than a 14mm lower camber bolt and lower bolts moved to the top position, but you may run into strut clearance issues.
Old 05-16-2022, 03:52 PM   #150
ddotffoeg
ddotffoeg's Avatar
I used the same SPC Camber bolts and they worked perfectly fine. Put them in the lower mount and make sure to get a proper alignment after. I was able to get matching -1.38 on both sides.
Old 05-16-2022, 09:11 PM   #151
Spektyr
Drives: GR86
3D printed a working shift knob. No pictures because it annoys me to post stuff online just to post in online somewhere else. (I've gotten lazy in my old-ish age and like when I can just CTRL-V into the forum.)
Also, the shift knob currently looks stupid - it's just big orange teardrop because I'm prototyping at the moment. Testing different ways to weight it, and may switch the plastic threads to an imbedded M10 nut (for strength and weight).
Then to make it anything other than a silly side project I'll have to think of something I'd genuinely want to replace the current knob with that the wife wouldn't be too embarrassed to be seen in public with.
Which rules out my first idea: the femur shifter from Fury Road. Sadly, that's going to stay on the tap of my kegerator.
Old 05-18-2022, 12:54 AM   #152
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Made a phone mount
Old 05-18-2022, 12:54 PM   #153
ozafar
Drives: 2015 Scion FRS Release Series 1.0
New Wheels
18x8.5 +40 Enkei TSV
245/35/18 PS4S
ozafar is offline   Reply With Quote
Old 05-18-2022, 12:58 PM   #154
justinco
justinco's Avatar
Drives: 2022 GR86
Made a phone mount
Pic of actual phone mount?
justinco is offline   Reply With Quote
GR86 Premium MPG joeDoe GR86 General Topics (2nd Gen 2022+ Toyota 86) 40 01-31-2022 01:03 PM
Why BRZ Over GR86? Lelandjt BRZ Second-Gen (2022+) — General Topics 45 12-26-2021 08:41 AM
GR86/BRZ Aerodynamics Jianlun GR86 General Topics (2nd Gen 2022+ Toyota 86) 4 12-15-2021 10:39 AM
GR86 PCD teppey GR86 General Topics (2nd Gen 2022+ Toyota 86) 23 07-29-2021 11:12 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
