| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru BRZ
(Very Important) Brz Valve Spring Recall Information
I know there is probably a thread out there with this information but I am new to the forum and I need answers
Back in December my timing belt went When I took my car to the dealer they fixed the timing belt and also preformed a valve spring recall couple weeks later I started leaking oil so I took the car to the dealer and they resealed the engine free of charge couple weeks after that I was still leaking oil so I once a again, took my car to the dealer where they resealed the engine free of charge My car has been running fine up until a week a go when my car started to feel slower. Fast forward to last weekend I was driving on the highway and my car started sounding like a helicopter so I pulled over and got my car towed to the dealership. They called me today saying I have and cylinder 3 misfire and a rod knock and quoted me 15k for a new engine. I don't have much knowledge on engines but is it possible that the first two times I took my car to the dealer they did not use enough sealant (which caused the oil leaks) and the second time they applied too much sealant which caused the missfire and the rod knock? If anyone can give me more information I would greatly appreciate it, going to meet with the manager tomorrow hopping they will take the blame. |
#2 |
Drives: Crapcan
Thats exactly what happened. There is a whole thread on J02 recall failures.
#3 |
ProCrastinationConsultant
also important to note, these vehicles have a timing chain, not a timing belt. timing chains do not need to be replaced.
| The Following User Says Thank You to soundman98 For This Useful Post: | Teseo (05-12-2022) |
#4 |
Rust bucket enthusiast
Welcome to the j02 club. We should make t shirts
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Ultramaroon (05-10-2022) |
#5 |
Drives: 2013 frs; 1988 porsche 944s - > 948
very sad news to hear, haven't heard much more buzz on this but i have a 2012 and i'll be damned if i let anyone touch mine for this heinous recall.
been running boost for over 5 years and no issue so i see no reason to do anything on my end. here's hoping and i do hope you find a resolve that doesn't stick you with the entire bill. |
#6 |
Lawyer up. They screwed up the sealing and caused a blockage in the oil passages. This failure is on them but they will fight it every step of the way.
https://www.ft86club.com/forums/showthread.php?t=133095 https://www.ft86club.com/forums/showthread.php?t=133306
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Capt Spaulding (05-11-2022), Teseo (05-12-2022) |
#7 | |
Drives: 2013 GT86 fully standard
#8 | |
Who knows it could have been worse if it was a one off Toyota engine just as it is a one off Subaru one.
| The Following User Says Thank You to Tcoat For This Useful Post: | Teseo (05-12-2022) |
#9 |
you are right, it was not my timing belt, it was the serpentine belt. from what I remember one of the pulleys was not working properly and it burnt a hole through the belt
| The Following User Says Thank You to Nick.brz For This Useful Post: | soundman98 (05-11-2022) |
#10 |
To my understanding, this has nothing to do with the engine, this was caused by Subaru technicians not doing their job right.
#11 | |
#12 | |
#13 |
Drives: 22 BRZ limited
#14 | |
Did you authorize them to do the recall work or did they just do it on their own?
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Busybee (06-11-2022), soundman98 (05-11-2022) |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
| Not doing the Valve Spring Recall? | arnie0000 | Issues | Warranty | Recalls / TSB | 30 | 08-06-2019 05:24 PM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| I have the valve spring recall information. | meadowz06 | Issues | Warranty | Recalls / TSB | 24 | 12-23-2018 08:44 PM |
