Old 05-01-2022, 08:13 AM   #3837
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Do you notice any benefit in using W11?
Yes, windows search works now. Literally the biggest difference.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Dadhawk (05-01-2022)
Old 05-01-2022, 11:52 AM   #3838
Yea that is definitely a difference. If you have an Android phone, the phone link works very well for texting and photo transfers. I also like the window snap feature where you can automatically divide the screen into zones by hovering over what used to be the maximize button in the upper left.
It will also let you run Android apps through virtualization but I haven't tried that yet. My understanding is it works relatively well.
Old 05-03-2022, 12:41 AM   #3839
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
This would be funny if it was funny.
Old 05-03-2022, 01:21 AM   #3840
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Frankly I sometimes forget I'm running W11 because once you left justify the task bar you can't really tell the difference unless you REALLY look for it.
*Can* you put the task bar on the left edge of the screen?
Thought they riveted it to the bottom only this time.
Wouldn't want to live with even less vertical space.
Old 05-03-2022, 07:28 AM   #3841
Yoshoobaroo
TRACKBREAD
It can still auto-hide
Old 05-03-2022, 07:31 AM   #3842
No, it's nailed permanently to the bottom, and MS doesn't plan to change it anytime soon.
https://www.reviewgeek.com/114501/mi...ws-11-taskbar/
I'm personally not a fan of it in any location but the bottom so I forget that's a thing for some folks. @Yoshoobaroo good point, I do have it set to hide, so it doesn't take up any space on my screen.
Yoshoobaroo (05-03-2022)
Old 05-03-2022, 09:36 AM   #3843
Yoshoobaroo
TRACKBREAD
There are some registry hacks that allow the vertical task bar still, but I bet microsoft will make sure that breaks in a few updates. They seem adamant that Windows' taskbar belongs on the bottom.
Old 05-03-2022, 09:39 AM   #3844
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
AMD is selling the 6900XT at MSRP $999. In stock.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
weederr33 (05-03-2022)
Old 05-03-2022, 10:12 AM   #3845
I've seen reports that if you do the registry hacks and you move it, the icons don't move with it. It's basically a blank task bar. Since I haven't tried it I can't verify.
They also removed the option to use the "condensed task bar" which was about half size, although I think you can do a registry hack for that as well.
Old 05-03-2022, 10:45 AM   #3846
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I just unlock the taskbar and drag it to the side...
Why the need for registry hacks?
What is a "condensed" taskbar?
Old 05-03-2022, 11:01 AM   #3847
Are you running Windows 11?
Condensed task bar is a Windows 10 option (it may have been called small icons). It is basically half the height of the full one. For example, the right side only shows the date, not the time with the date underneath it. If you do the hack for W11, the time gets cut off at the top and the date at the bottom.
x808drifter (05-03-2022)
Old 05-03-2022, 12:34 PM   #3848
x808drifter
LMGTFY
I thought my sis was running 11.
Infact she is not and had some program modifying her taskbar.
I will continue to say every other version of windows is inferior.
XP-7-10
The Following User Says Thank You to x808drifter For This Useful Post:
Dadhawk (05-03-2022)
Old 05-03-2022, 12:44 PM   #3849
bcj
Geo Tyrebighter Esq
bcj's Avatar
My machines are too feeble for 11, so there's that.
A bit of a relief in fact.
Next one will be back to Linux for sure.
Old 05-03-2022, 01:13 PM   #3850
I just rebuilt an old Dell Dimension 9200 (Dual Core Duo, circa 2006) with Windows 10 and it runs like a champ for my purpose (MAME emulator I'm going to hook up in the arcade cabinet). Ultimately I'll want to replace it as the transition between the selection screen and the game running is a bit slow for my taste but every game I've tried runs fine.
I couldn't build it with WIndows 11 though because of the security requirements for W11 so it's next destination may be as a SAN.
I did a lot of UNIX stuff back in the day (mainly email servers, and some script servers) but have never gotten into Linux very deeply. Not out of any intent, just haven't had the need.
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 04:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 06:37 PM
