| Engine Swaps Discussion of engine swaps. |
#197 | |
Drives: 2014 FRS LS Swap
TV6-358-29-NG Toyota 8", 3.58, 29 Spline, Nitro Ring & Pinion $294.95 YOKTOYFITKIT-29 Toyota, 29 Spline Fit Kit (Includes: Pinion Flange, Pinion Seal, Pinion Nut) $83.48 MKTLC100-IFS Toyota 8" Reverse IFS Nitro Master Install Kit, 100 Series $311.45 SKCSTV6 Toyota 8" V6 & FJ80, Nitro Solid Spacer $37.84 NPLUBE-3 80W-140 Nitro Para-Synthetic Plus Gear Oil, GL5 (3 Quarts) $59.50 Total: 787.22 CHESAPEAKE CITY shipping: $47.23 Grand Total: $834.45 You do have to have a few tools but nothing too bad: 12 ton press from harbor freight (170), punches, impact, deadblow hammer, bearing separator, dial indicator, etc Last edited by kurty85; 05-02-2022 at 07:14 PM. Reason: . |
#198 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#199 |
It is definitely due to the cost. The full blown kit costs 3995 without a diff. The diff is another 1895. The Grannas kit is 3185 plus 2000 for the diff. I would never buy those. I just wanted the mounts to make things easier. Maybe I will do a Rob Dahm and steal their cad designs like he did with the Hoonicorn lol.
#200 | |
#201 | |
#202 | |
#203 |
Got the front diff mounts removed today in prep for powdercoating. The diff housing is stripped. What a pita to remove even with a torch. Using Whiteline KDT923's for the front and KDT924's for the rear mount. Going to use KDT922 bushing lockers for the subframe for stiffening. Don't want completely solid mounts. Think this will be a good mix of NVH and less slop. All poly mounts. Also got the new pinion and solid crush spacer.
#204 |
Got the diff powder coated satin black and the rear cover. Need to assemble now!
![]() ![]() Sent from my SM-G973U1 using Tapatalk |
| The Following User Says Thank You to kurty85 For This Useful Post: | Irace86.2.0 (01-21-2023) |
#205 |
Started on upgrading the fuel cell to handle 3-4 pumps. I cut off the top of the aeromotive cell, made a 6x10 top hat and a center surge area and bought 3 DW400 pumps to install. Using a radium 3 into 1 distribution block to a bulkhead fitting then out to supply. 1 relay for each pump and the 2nd and 3rd pump will turn on at 4psi and whatever psi above that (probably 14psi) with a hobbs switch. With 3 DW400 pumps I should be able to have any amount of fuel I need. Going to pressurize the cell and check for any leaks then start closing it up. Mounting it in the new rear floor I put in. Riveted all around every 1 inch and sealed top and bottom.
#206 |
Got the pumps installed on the hanger and wiring done. Just need grounds now and tank reinstalled. 3 DW400 pumps with 3 30A relays. I can upgrade the output size if needed by switching to a 10an union, 10an bulkhead fitting, and 10an fitting on the radium block.
![]() ![]() Sent from my SM-S908U using Tapatalk |
| The Following 2 Users Say Thank You to kurty85 For This Useful Post: | DustinS (01-24-2023), Irace86.2.0 (01-21-2023) |
#207 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
This is how you end up with a machine shop in your garage. Oh yeah.
#208 |
Got the tank finished and reinstalled. Pressure tested the tank and it holds pressure with no issues. I wired two hobbs switches in to turn on at 4psi for the second pump and hopefully 12psi-15psi for the third pump. I want to run E85 and see where I am at after tuning then bump lines up to 10an if needed.
![]() ![]() ![]() Sent from my SM-S908U using Tapatalk |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Not just another ls swap | killin'_for_a_livin' | Member's Car Journals | 7 | 08-28-2016 05:58 PM |
| WRX SWAP!!! | PowderfaceTr. | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 02-24-2015 07:29 PM |
| Ej Swap | koyv90 | Engine Swaps | 50 | 11-14-2013 08:59 PM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) — General Topics | 8 | 06-12-2012 08:32 PM |
