Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-28-2022, 07:13 PM   #911
Liquidsnake
Drives: "I drives like a Porsche"
I swapped out the interior lights in the trunk lights for LEDs. It was my first official mod
Liquidsnake is offline   Reply With Quote
Old 04-29-2022, 04:18 PM   #912
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
The LED dome light upgrade really helps light things up. What is the LED lamp part number is for the one for the trunk light?
The ants are our friends, they’re blowing in the wind, that ants are blowing in the wind.
Flarpswitch is offline   Reply With Quote
Old 04-29-2022, 06:43 PM   #913
Liquidsnake
Give me the huge difference yeah I bought two packs of Noble T10 LED’s. So I had four in total but I only need three I replace the two dome lights inside and one in the trunk they’re all the same.
Old 04-30-2022, 02:37 AM   #914
kaesu
Drives: 22 BRZ
Originally Posted by Panda Grahams View Post
Going to be a fun weekend... Straight from Japan.
You're going to love them. Mine took about 2 weeks to break in; they're smoother now than when I had just installed them. They could be a bit stiffer too but for DD, can't go wrong.
kaesu is offline   Reply With Quote
Old 04-30-2022, 03:32 AM   #915
kaesu
Drives: 22 BRZ
So the legamax exhaust finally came in! There was a ~5week delay but after there was stock it was shipped super fast (Shoutout to japanparts for the amazing customer service).
Install was a breeze - everything lined up perfectly. Maybe took about 30mins to do including setup and cleanup.
Onto the good stuff. The exhaust has all the deep/low bass the car was lacking previously. It's there in the background in the lower rev range but tapers off around 3k. Under normal cruising, you'll barely notice any difference from oem.
Highway cruising even at around 3k rpm is still very mild. It's there, but not intrusive at all. Downshifts have a nice deep note to them now when you apply gas. Driving it more spiritedly is a little louder than oem but with a nice note to it. Startup is a bit boomy though, but I suspect it'll quiet down a bit after breaking it in. I remember my trd exhaust was like that after about 1000kms. i think in terms of volume, the perrin 2.5 resonated was louder than this by a little bit, but not quite as deep of a note.
Overall, perfect for DD. It's there, it's not intrusive, and it has a nice deep note to it. It could definitely be louder and still be tolerable, but if you're looking for something that won't attract unwanted attention from the officers, this checks all the boxes. A non burnt tip option would be nice too. Side note, if someone near Vancouver, BC has the STI exhaust, I'd love to compare.
Old 04-30-2022, 11:48 AM   #916
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Interesting. Given that they will take about 2 weeks to settle, would you recommend I wait until then to also perform an alignment?
Panda Grahams is offline   Reply With Quote
Old 04-30-2022, 01:11 PM   #917
jongers
Drives: 19 86, 22 BRZ
In my experiences, I'd still get it aligned after the install + dialing in the height.
If you're getting a shop to do it, maybe jump on the trunk/door sills to help with getting things settled (the caveman way)
jongers is offline   Reply With Quote
Old 04-30-2022, 01:42 PM   #918
kaesu
Drives: 22 BRZ
^ what jongers said. After getting the height where you'd like best to align first. Maybe it just took me 2 weeks to get used to them haha, but it feels a bit smoother now. Height wise I don't think they changed much after setting them.
Old 04-30-2022, 06:32 PM   #919
mlarz41
Drives: 2022 Subaru BRZ
3 months of ownership AND 4000 miles.
BC Racing BR Coils, have a finger gap all around (1.5ish in drop i think)
SPL LCAs
MXP Comp exhaust
Gram Lights 57dr 17x9 +38 on 245/40/17 indy500s
-1.5 degrees of camber all 4 corners, no rubbing anywhere that i can find or hear. rear is pretty flush, front could take maybe a 3-5mm spacer to get completely flush with fender.
mlarz41 is offline   Reply With Quote
Old 04-30-2022, 09:37 PM   #920
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Finally checked the numbers on the stock steering rack bushings.
They are: 34112CC000
They are different than previous gen and do not cross reference to anything else in the Subaru catalog.
Old 05-01-2022, 11:44 AM   #921
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
New Wheels!!! Bronze TS-7's with 245s! Wait, wait a sec... (checks notes) WHOOPS, those are for the WRX. No new wheels for the BRZ yet
Thinking I might got for some Enkei XM-6's (still in 17s and 7.5). But probably not until next year unfortunately. Can't really find many pictures online of Twins with XM-6's (makes me wonder if they are a newer style). Also, they are a tad heavy...Maybe I'd be better off with PF01s... Decisions, decisions.
Other than that, spent some time driving in the warmest conditions that I have yet had the car for (10-12C). The Primacys don't feel anywhere near as bad as I thought they would.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 05-01-2022, 12:26 PM   #922
dragoontwo
dragoontwo's Avatar
Autocross! Footage of terrible driving later.
Old 05-01-2022, 07:59 PM   #923
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
Got another update:
Cusco steering rack bushings
STI V Bars and front tower brace (from zc6 - it fits)
STI rear draw stiffener
It does not fit the USDM crash bar per se, you'll need to notch out a piece for the brackets to fit correctly. See here:
I really need the alignment done ASAP before I comment on the ride. So far the car drives great but the rear seems to be hunting around when there's vertical fluctuations in the road (dips/bumps/etc.). Steering feels slightly heavier and a little more immediate. Would love to drive a stock BRZ now as a back to back.
Next time attack is on the 13th, will give a report after that.
Re_Invention is offline   Reply With Quote
Old 05-01-2022, 08:52 PM   #924
jvincent
jvincent's Avatar
I have the PF01s on my 2022. I moved them over from my 2013 FRS.
Great wheels.
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
