#15 | |
Drives: Crapcan
You can get Tein Flex Z’s for under 1000. A little more money but FTspeed has Flex A’s for 1210. ST XA’s are also about 1200, these are basically KW V1’s with a cheaper body.
#16 |
Drives: Pearl White 2014 BRZ
What's the difference between the tein flex Z's vs the bc racing ones I linked? They seem relatively similar apart from how much dampening adjustment you have. I'll probably go with those just cause their cheaper.
| The Following User Says Thank You to SeddyBRZ For This Useful Post: | Wally86 (04-05-2022) |
#17 | |
Drives: Crapcan
Quality. The Tein’s will be higher quality and have more appropriate spring rates then what BC typically pushes.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#18 |
UPDATE: I decided to purchase the BC Racing Extreme Low coilovers. I found them for $1000 on a website ($200 cheaper than the regular ones). I decided firmly on BC Racing because I read somewhere that the tein flex coilovers can't be rebuilt and I'd rather save cost in the long run when the coilovers wear out. After a long week (along with resealing my timing chain cover), I got them installed and the car looks amazing. I will take an "after" shot tomorrow morning as I am at work currently.
Right now I am dialing in the dampening, started full hard due to my fear of rubbing and destroying something and I have to say, it was like driving a 90's car with chopped springs. I am currently at about the halfway mark (15) on the dampening and it's a nice firm ride that would be more suitable for a track. I will post another update when I get the right settings dialed in. I also purchased some adjustable lca's and toe arms for the rear but have yet to install them as I was busy with the timing chain cover which I don't recommend ever doing if you are a novice mechanic lol. It was a pain even for me having spent my whole 23 years of life working on cars. |
#19 | |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#20 |
Everywhere I've read, people have stated around $50-150 per coilover depending on type and if you do it yourself, that's nearly half as cheap as buying a new set and even if its $800 to have them rebuilt, it's still cheaper in the long run than just buying a new set every time you need them.
| The Following User Says Thank You to SeddyBRZ For This Useful Post: | Wally86 (04-29-2022) |
#21 | |
If you have the ability to DIY rebuild coilovers, I have a nice well-paying job ready for you. |
#22 |
I don't see why it couldn't be a DIY job unless there's special equipment needed that cost more than the jobs worth. New fluid, packings, a little bit of cleaning and they should be good. I'm no expert on the matter but I'll give it a shot when the time comes.
#23 | |
Components, ultrasonic cleaner, a way to measure stiffness, etc. You're in for far more than you think. |
#24 |
Drives: Crapcan
Eh, as a guy who used to work at a shop and rebuild motorcycle forks and shocks, I'd rather just pay to have it done.
#25 |
LMGTFY
Drives: 13 FRS, 91 Miata
I see post #3 was just ignored.
Not surprised. |
#26 |
I'm not using lowering springs so I don't see how this applies. The issue with the ride quality was due to me running on full hard dampening, not bump stops. Adjusting the ride height doesn't change shock travel on coilovers.
#27 | |
Drives: Crapcan
No matter how much travel you have at ride height, you only have so much room to actually move before things start hitting.
| Tags |
| car rides like shit 101, seddybrz = askhole |
| A few questions before buying a used BRZ/FRS | LudwigMiles | BRZ First-Gen (2012+) — General Topics | 15 | 08-10-2017 09:47 PM |
| A few questions before buying a used BRZ/FRS | LudwigMiles | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 08-04-2017 03:53 PM |
| Some questions before buying an Frs | jorgerendonjr | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 03-25-2017 09:43 PM |
| Questions before buying a FR-S. | Seeeon FRS | Engine, Exhaust, Transmission | 3 | 04-06-2014 09:05 PM |
| Questions about buying a brz | bitcloud | BRZ First-Gen (2012+) — General Topics | 23 | 09-22-2012 04:13 PM |
