Old 04-25-2022, 11:20 AM   #729
Spektyr
Drives: GR86
Anyone know if 16s fit the Gen2's at all?
Spektyr is offline   Reply With Quote
Old 04-26-2022, 02:20 AM   #730
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
[QUOTE=SCFD;3517890]I can't wait for winter to roll around again so I can run my new 15s.
Dat gap, yo ...
Old 04-27-2022, 11:33 AM   #731
gskv
Drives: 2017 BRZ
Originally Posted by NLSP View Post
Reviving this thread
what tire size are you running?
I'm wondering if this will fit the gen2..
gskv is offline   Reply With Quote
Old 04-27-2022, 12:12 PM   #732
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I don't see why not; the brakes seem to be carried over from Gen 1 (same part numbers for pads and rotors when I filter on Tire Rack, FT Speed, etc.), so clearance shouldn't be an issue. But I'm not 100% sure since I don't have first-hand experience with test-fitting on a Gen 2.
Tire size I'm running in this photo is 225/50/16 (on 16x8). The other common size if you have a narrower wheel (e.g. 16x7 or 16x6.5) is 205/55/16. These are the sizes closest to stock diameter for 16" tires.
My track setup will be 225/45/16 (on another 16x8) for better gearing and a lower profile sidewall, but won't be as aesthetically pleasing (about an inch smaller in diameter compared to the sizes above), but function > form for track duty
Old 04-27-2022, 12:58 PM   #733
gskv
Drives: 2017 BRZ
good to know. i just ordered 16s in rpf1 but i do like these comps more.
i am seeing some rear wheel fitments from gen1 that's hitting the rear fenders.
Old 04-27-2022, 01:27 PM   #734
SCFD
I haven't been paying too much attention to the gen2s but any fender clearance issues in the rear would have to be due to a combination of incorrect width/offset and not the diameter of the wheels.
SCFD is offline   Reply With Quote
Old 04-27-2022, 06:11 PM   #735
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
The brake system has not changed on the new gen car. A 16" will fit over the caliper no problem.
The extreme offsets from the last gen, like 17x9 +35 and 18x9.5 +38 Ive read have clearance issues. So any 16x7 +48 or out to 16x8 +35 should be ok.
The Enkei Comp wheels pictured above were a 16x8 +25, and they are discontinued. Those would not fit a new gen car.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
