| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2017 Toyota 86 (860 SE)
The Actually Helpful TPMS Thread
I have what should be a simple problem, but I have read and searched all afternoon on this forum and others, with the result that I now have more questions than answers. And from the look at the few dozen threads on the topic that I've read, I'm not alone.
But I'm a solutions guy, so let's make this a solutions thread. I'll open the floor with my situation, but will update this post with more problems/solutions as we go. First a few ground rules:
The New Wheelset With Preinstalled Sensors Problem (1G) Scenario: I ordered a new set of tires and rims, complete with pre-installed TPMS sensors. Since I have a first-gen, my ECU can only handle one set of sensors at a time (second-gens can take two sets, which is nifty). I'll be swapping back to the OEM wheels come winter, so I need to either
Option 1 seems less likely, since I have yet to come across a tool that can clone a sensor when it is already installed. If I've missed one, please educate me! Option 2 should be straightforward enough, except I can't seem to find any sort of consensus on what tool is best for the job. Can Techstream actually do it? Carista? Torque? A specific tool from ATEQ? SOLUTION: I ordered a Carista dongle, and used it (for free, no plan required) to retrieve the OEM TMPS IDs, which I saved in a Google Doc. Then I installed the new wheelset, drove to Discount Tire, and had them scan the new sensors (already installed in the wheels) and load them into the ECU. Then I pulled those IDs with Carista and saved them. Come winter, I'll use the paid Carista app to swap IDs when I put the stock wheels back on. Success! Last edited by Cephas; 04-12-2022 at 10:10 AM. |
#2 |
Be Kind
Drives: 2020 86
After a sensor broke in my FA5 and honda wanted $200 for a replacement, I vowed to never deal with it. Long story short, I didn't want a TPMS light on in the 86 when I got different wheels.
Tool purchased: Autel TS408 Using the autel, I can read sensors and sensor information. What this allowed me to do is get the OEM TPMS IDs. It can also program the autel MX sensors... Sensors purchased: Autel MX programmable sensors I have three sets of wheels and minus the OEMs, they all have these sensors in them and are all programmed to match the OEM TPMS IDs. Now I can switch wheel sets and never had to do any programming. I just pick the wheels I need to throw on and the TPMS system is happy. Total price for tool: $149 Total price per wheel set: $130
| The Following 5 Users Say Thank You to Wally86 For This Useful Post: | Cephas (03-12-2022), H380 (03-17-2022), mrderp (06-03-2024), Ohio Enthusiast (03-11-2022), ymshulman (03-11-2022) |
#3 | |
Wheels for Brains
So what you need is to write down or otherwise access the individual TPMS ID #'s (they are usually printed on the TPMS itself) before you put tires on the wheel. Anytime you swap wheels, update all 4 TPMS IDs If you haven't written down the IDs and already put the tires over them, then either:
| The Following User Says Thank You to EndlessAzure For This Useful Post: | Cephas (03-12-2022) |
#4 |
^ Okay cool. All the threads I read (and on Carista's own site) seemed ambiguous on whether they could actually change the TPMS IDs, or only read them. Thanks!
#5 | |
Wheels for Brains
Having convenient access to the dealership customizations is also nice (door bell chimes, dome light auto shut-off time, etc.) without having to go bootleg with Techstream |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | Cephas (03-16-2022) |
#6 | |
Be Kind
Drives: 2020 86
I bought a carista thinking I'd just use it every once in a while but being on my 5th set of wheels, I figured it was easier to just put the same sensor IDs in all the wheels lol It was nice to disable the passenger seatbelt chime when you throw your phone on the seat!
#7 | |
Wheels for Brains
I think to clarify, I have a generic Bluetooth OBDII adapter (you don't need to buy the Carista branded adapter). I just pay for a premium software access window (via the free App) on Android when I need it. |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | Wally86 (03-17-2022) |
#8 |
Drives: 2020 Toyota 86 GT 6M
Cloning is most convient way. There should be some devices that can pull your TPMS codes from the obd port. The ateq quickset does it but also can flash new codes for swaps. I'm sure a local tire shop can read the code for you for and clone a set of programmable sensors for u
#9 |
Drives: Some RX-7s
ATEQ Quickset works nice for me, and is cheap (~$70 on ebay).
It can read sensor codes from the car's ECU, and can store 2 sets of codes in the unit. For new sensors, you punch in the codes via software+laptop. Henceforth, at each seasonal tire change, you hook the plain unit to up to ODB (no laptop) and write codes to the car. It's a snap. |
#10 |
Drives: 2017 subaru brz
If we are purchasing a set of wheel/tire combo from Tirerack with pre-installed TPMS sensors, can we just go to an America's Tire and have them program the aftermarket sensors to work without issues? (I read another thread somewhere that it isn't this easy)
Also if the TMPS already comes pre-installed within the tire and wheels, how will they get to it/read it for the programming? |
#11 |
^ I went to Discount Tire and they had a reader that could pick up the IDs from next to the wheel and flash them into the ECU. Easy peasy.
#12 | |
#13 |
Drives: C5, GT-86, '24 Colorado TrailBoss
How much did they charge you?
#14 |
| Tags |
| carista, techstream, tire pressure, tpms |
| Helpful DIY Spark plug change video | DTMdreaming | Engine, Exhaust, Transmission | 13 | 10-17-2020 08:55 PM |
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 08:11 AM |
| Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? | Ahz | Issues | Warranty | Recalls / TSB | 9 | 11-06-2012 08:25 AM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
