Old 04-16-2022, 08:44 AM   #757
86-75309
Drives: Until recently, a 2020 Hakone 86
no, they're using all standard milwaukee m18 batteries. it just needs 2 of them. this is just the 12.0 battery, the largest they sell. all of milwaukee's yard tools use the same form factor m18 batteries. just different capacities. milwaukee's next largest battery is the mx series, but i don't believe that's sold in any stores.
one of the biggest reasons to getting this over other brands is that i can use the batteries in all my other tools. runner up was the eco mower, but then i'm stuck with a massive battery that only does one job.
i've got the weed whacker and the blower. it was a buy one, get the other and a battery for free deal, got a 9.0 battery with that. it lives on the work truck. i keep some older 5.0 batteries around the house for lawn duties.
i'm going to see how the summer goes. if i can do my lawn with only some 6.0's, the 12.0's will also migrate to work tool duty.
I did the same thing, except I went all Makita. I got one of their self-propelled walk-behind mowers, a string trimmer, a tire inflator, a blower and a drill that all run off of the same batteries. Because I bought some of the items as kits with batteries and a charger, I have a total of 8 battery packs and the ability to charge 4 packs simultaneously.
86-75309 is offline   Reply With Quote
The Following User Says Thank You to 86-75309 For This Useful Post:
soundman98 (04-16-2022)
Old 04-16-2022, 09:54 AM   #758
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
also got the creepiest real estate mail today too. sent in a halmark card
That’s hilarious lol
I’m looking at electric mowers too. Post up how you like it after a half dozen uses.
Old 04-16-2022, 12:25 PM   #759
Had a milestone today of sorts at our house. I replaced the very first LED lights we bought for household use. They were in our front porch lights. Not sure exactly how old they are, but it is probably in the 10 to 12 year range. I know I paid a fortune for them but they have been on at least at a low level the entire time and about 6 hour a night at full burn. They were always on at low level because they were on a non-LED aware timer that let a trickle of electricity through to power itself.
Replaced the timer switch with a Leviton smart switch as well.
We still aren't fully converted to LED. We have a handful of incandescent bulbs left in closets and bathrooms that are used infrequently.
Here's one of the four LED bulbs I replaced. Totally old school. 3 of the 4 still had 1 LED working, but they didn't put out enough light.
bcj (04-17-2022), soundman98 (04-16-2022)
Old 04-16-2022, 12:27 PM   #760
Hey, no worries I took care of it for you. Called him up off the card and said you'd rather meet in person at your house tonight around 1:00am.
No need to thank me.
The Following 5 Users Say Thank You to Dadhawk For This Useful Post:
humfrz (04-16-2022), NoHaveMSG (04-16-2022), soundman98 (04-16-2022), Tcoat (04-16-2022), Ultramaroon (04-16-2022)
Old 04-16-2022, 02:12 PM   #761
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
The house we moved to three years ago was new construction and all but the two dozen or so LED flood light were halogen bulbs. Halogen bulbs are exempt from the ban as they are considered higher efficiency, but they still consume 5 to 10 times more electricity than equivalent LED alternatives. I wholesale replaced every non-LED bulb in the house and to date none had to be replaced. However, the LED floods are one by one failing 10 years short of they predicted lifespan. An autopsy revealed that none of the LEDs in the arrays have failed, but the large electrolytic capacitor in the driver swells up and oozes goop. Laying out the parts on a bench, I substituted the capacitor and the lamp came back to life. Only way I would replicate this Frankenstein Bulb is during a Zombie Apocalypse where you have to recycle and reuse everything. More plastic and crap for the landfill. A friend of mine who has an alternative way of thinking which is in most cases 180° out of phase with the rest of the world, once reasoned that the incandescent light bulbs were not energy inefficient because the heat generated in the house is that much less heat that has to come from the furnace. If the Greenies are successful in banning natural gas here and all we have is electricity (available 4 hours on alternate days) he makes sense. With a 500 Watt flood lamp, you could light up the room so the kids could do their homework, heat the room and cook dinner.
Flarpswitch is offline   Reply With Quote
The Following 2 Users Say Thank You to Flarpswitch For This Useful Post:
Dadhawk (04-16-2022), soundman98 (04-16-2022)
Old 04-16-2022, 02:37 PM   #762
Originally Posted by Flarpswitch View Post
....A friend of mine who has an alternative way of thinking which is in most cases 180° out of phase with the rest of the world, once reasoned that the incandescent light bulbs were not energy inefficient because the heat generated in the house is that much less heat that has to come from the furnace.....
There is some sensibility to your friend's logic. I don't think I could fully list every way I've used incandescent bulbs for their heat rather than their light. There was cooking (easy bake oven, etc), keeping plumbing fixtures from freezing, heating dog houses, heating pump houses, heating out houses. They were a very convenient method for keeping small spaces above freezing, and sometimes well above that temp.
humfrz (04-16-2022)
Old 04-16-2022, 02:46 PM   #763
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
What's so creepy?
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Flarpswitch (04-16-2022), NoHaveMSG (04-16-2022), soundman98 (04-16-2022)
Old 04-16-2022, 02:48 PM   #764
What's so creepy?
Flarpswitch (04-16-2022), soundman98 (04-16-2022)
Old 04-16-2022, 03:21 PM   #765
soundman98
ProCrastinationConsultant
soundman98's Avatar
What's so creepy?
because you didn't list your forum name on the card!
Old 04-16-2022, 03:27 PM   #766
Flarpswitch
[/QUOTE]
For a while I would get a mailing several times a week. Some are the legitimate flyers that happen when a broker sells a property in your neighborhood, but most range from the truly lame postcards all in lower case chicken scratch to recycled stationary and greeting cards. The absolute best one was from a house flipper that came as a ransom note spelled out with clipped words from magazines. It was a good copy of the original, but it was one solicitation that at least caught my attention. I accidentally shredded it with a pile of other junk mail. I hope I get another, it was pretty cool. Now mostly I get cold calls asking if I wanted to sell the house. Everything is for sale; you just have to come up with a price. I usually say,”Yes, it is for sale.” I just take the approximate value and double it. Lot of time there is a long silence on the other end of the call. They don’t have a script prepared for that. About five minutes after I hung up on a car insurance scam, the phone rang again and it was the Jehovah’ Witness lady from the place up the road wanting to speak to my wife. I screen the calls and I said that she was not available. I was distracted at the time and was not really listening to what she was saying. I was going over a pile of papers concerning my dog who died recently and in my head, I was talking to the veterinarian clinic. I said that he died a few days ago. The woman offered a bit of condolences and I told her I had to go. A few days later I received a letter expressing condolences about the PASSING OF MY WIFE. Enclosed were the usual printed tracts about grieving yadda yadda yadda… my wife thought it was as funny as I did. Some time passed and I received more correspondence addressed to me. It suggested that I should join them at the Kingdom Hall and maybe I can get hooked up with a nice single lady.
The Following 4 Users Say Thank You to Flarpswitch For This Useful Post:
humfrz (04-16-2022), NoHaveMSG (04-16-2022), soundman98 (04-16-2022), Ultramaroon (04-16-2022)
Old 04-16-2022, 03:43 PM   #767
Plus, using a lightbulb under the hood of a car, with a blanket over the hood, to keep the engine from freezing.
Dadhawk (04-16-2022), Flarpswitch (04-16-2022)
Old 04-16-2022, 04:37 PM   #768
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
What's so creepy?
The front of the card said "Get Well Soon"
The Following 3 Users Say Thank You to Kiske For This Useful Post:
Old 04-16-2022, 04:44 PM   #769
Took me a minute to picture it. Now it's stuck there.
lol
Old 04-16-2022, 05:10 PM   #770
p1l0t
p1l0t's Avatar
That's old news. I'm talking about real-time.
Oh you probably want Ezekiel:38-39 then. Talks about the Gog-Megog war and how Rosh (Russia) comes down from the North to plunder.. I mean Russia hasn't invaded Israel directly yet but WWIII is only just getting started. There is some debate as to whether the rapture happens before or after the war of all nations is fully over.
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
