Old 04-13-2022, 03:34 PM   #1
gcranston
Drives: 2015 Subaru BRZ Limited DGM
code reader recommendations?
Hi ft86-maintenance! Looking for recommendations for a code reader. I've been getting by with OBDLink LX + Torque for a while, but it's slow and cumbersome, and it doesn't read ABS codes. I currently have ABS+TC lights on and I'd like to try and diagnose it.
Any recommendations for a reliable code reader that can also read (& clear?) the ABS module codes?
Thanks.
gcranston is offline   Reply With Quote
Old 04-14-2022, 02:01 AM   #2
Boccaccio
CAD monkey
Boccaccio's Avatar
Drives: '15 GT86 Giallo - Supercharged
I personally use the "cracked" Toyota Techstream cable/software combo:
https://www.amazon.com/VCI-J2534-Cab...27&sr=8-7&th=1
It works on the BRZ.
Boccaccio is offline   Reply With Quote
Old 04-14-2022, 11:44 AM   #3
gcranston
Looks awesome. What do you need on the software side to run this?
Old 04-15-2022, 02:35 AM   #4
Boccaccio
CAD monkey
Boccaccio's Avatar
Installing the included software onto your laptop and connecting the cable from the PC to the OBD port, easy peasy
The Following User Says Thank You to Boccaccio For This Useful Post:
gcranston (04-15-2022)
Old 04-15-2022, 02:22 PM   #5
VACapsFan
Drives: 2017 BRZ Limited
Does this let you change settings like the auto headlight sensitivity?
VACapsFan is offline   Reply With Quote
Old 04-15-2022, 04:16 PM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
hmm I wonder if this works through a VM on Mac
Old 04-19-2022, 12:36 AM   #7
Boccaccio
CAD monkey
Boccaccio's Avatar
AFAIK from other Toyota products, it should work. I haven't tried it yet since my car is still in storage and haven't found time to tend to her needs :P
https://cimg9.ibsrv.net/gimg/www.clu...a085c9f720.jpg
Perhaps this will help:
https://forum.ih8mud.com/threads/tec...n-mac.1224791/
Yoshoobaroo (04-19-2022)
Old 04-20-2022, 04:21 PM   #8
VACapsFan
Well if it has the ability on other cars I'd assume it'll work on the BRZ, I'll give it try. Thanks for the info!
Best Abs Code reader ilovetheabel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-23-2018 03:36 PM
Anyone in southern Orange County with a code reader? bdanisi Southern California 3 08-08-2015 11:34 AM
Code reader recommendations? FLYFISHR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-01-2014 10:01 AM
is CarMD a good code reader? chenshuo Engine, Exhaust, Transmission 3 04-04-2013 10:32 AM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 05:06 PM
