Old 03-16-2022, 01:54 AM   #15
obito.frs
team TEMPEST
obito.frs's Avatar
Drives: 2015 Scion FR-S
You didn't ask me, but, I would suggest you just go with an OEM clutch - just don't hammer on it -
Why? My car is (partially) set up for drifting, and is continuing down that road, not hammering on it isn't exactly possible lol. And why OEM? The OEM clutches in these cars are known to be pretty terrible under power/hard driving. I guess I just expected more from ACT, and before anyone says anything yes it's not my daily and yes it is a drift project but I did break in the clutch correctly long after the recommended miles.
"I don't want to regret the way I lived"
obito.frs is offline   Reply With Quote
Old 03-16-2022, 02:01 AM   #16
So, how much power are you putting through the clutch in your car?
Old 03-16-2022, 08:32 AM   #17
WNDSRFR
Drives: FR-S,GTI
OEM is Exedy. And there's nothing wrong with it.
Maybe there's a reason why Toyota didn't use ACT as the OEM.
And sometimes aftermarket isn't better.
Old 03-16-2022, 09:36 AM   #18
Well when I say it's "brand new" that is still post-break in. I have put over 2K miles on the clutch, I drive the car quite a bit so it's happened pretty quick. As far as ACT goes, I've heard the stories but never had issues with them before. This isn't my first car, just the first time I've had this issue so quickly. I will check the clutch fork, that seems to be the unanimous possibility
Dude don't get all defensive and uppity. You asked for input and got it.
We are not talking about ACT in other cars here we are talking about them in the twins. The "unanimous" possibility here has been the ACT not the fork. Your friends that have one are probably a sample size of what 4 maybe 5? There are literally hundreds of complaints about the ACT on the forum alone. I have no answer as to exactly why they are so bad in this car but there is zero doubt that they indeed suck.
Fine if you don't want to believe it and throw parts at it to try to fix your issue but many have gone that route before and failed.
Old 04-11-2022, 09:26 PM   #19
eightsix
was when i was born
Drives: 2010 Turbo tC, 2011 rav4
Not trying to thread jack, I just want you to know that I have a very similar issue. For me it’s very difficult to get into 1st and reverse. Sometimes I’ll even turn off the car put it in gear then turn it back on. I have a south bend stage 2 and a versus clutch fork and pivot installed by PTuning along with their turbo kit . I’ve bled the line and adjusted the clutch pedal multiple times. Also replaced the slave cylinder. I still haven’t resolved the issue. This all started 2 months after my clutch/turbo install in March of 2019. Been driving with the issue ever since
Ptuning FTW
eightsix is offline   Reply With Quote
Old 04-12-2022, 12:28 PM   #20
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Have you tried to go under the dash and adjust the clutch rod?
Old 04-12-2022, 02:31 PM   #21
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I think you posted your symptoms in another thread and i replied it back.
I have exact same setup on clutch (South Bend stg 2) with clutch fork and pivot from Versus
I have same issue. i replaced transmission fluid as well as diff. fluid and got little better but it's still there.
It's hard to explain and this is not solution but there is a little momentum when you shift into gear and it goes in without problem. lol
also double clutching also helps when you stopped and try to get into 1st
I just live with it now.
Old 04-12-2022, 07:23 PM   #22
soundman98
ProCrastinationConsultant
soundman98's Avatar
Try what this guy did
https://www.ft86club.com/forums/showthread.php?t=149207
act, clutch, hard shifting, shift
Clunky and hard gear shifts nhuyvan1106 Issues | Warranty | Recalls / TSB 45 08-26-2017 01:52 PM
'Free XM' after head unit hard resets due to USB read error ? Breeeep Electronics | Audio | NAV | Infotainment 2 09-02-2015 09:53 AM
MT tight, hard shifts. Opinions? boead Issues | Warranty | Recalls / TSB 19 09-30-2014 03:59 PM
0-60... at below 3-4k rpm shifts iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 29 08-08-2013 08:16 PM
A/C Shifts off when accelerating hard? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 29 06-19-2012 12:24 AM
