Old 04-09-2022, 11:51 AM   #1
Sam86
Drives: Toyota 86 GTS
86 Facelift TRD diffuser on a Pre-facelift
Can anyone confirm if the overall shape of the rear diffuser (specifically the textured, plastic part around the fog light) is any different to the pre-facelift aside from the little accent parts they added?
Wondering if this part will fit my pre 2017.
https://www.zerooffset.com.au/produc...style-diffuser
I know the OEM facelift TRD bumper with moulded diffuser won’t fit because the rear bumper is slightly different, but I don’t see why something like the above item wouldn’t fit the pre-facelift diffuser as the little accents they added shouldn’t interfere with the diffuser.
I know the listing says it’s for 17-20 but I messaged them and they haven’t actually tried fitting it. I don’t think there is an OEM equivalent of this diffuser (seperate from the TRD rear bumper) so I’m guessing they just labelled it as 17-20 since that’s what it’s based on
Sam86 is offline   Reply With Quote
Old 04-09-2022, 11:56 AM   #2
gpvecchi
gpvecchi's Avatar
Toyota facelift rear bumpers are completely different from pre-facelift ones. The diffuser is wider, the overall height of the bumper is higher, and there's an added part on the bottom.
Subaru uses the same rear bumpers of the pre-facelift models.
The Following 2 Users Say Thank You to gpvecchi For This Useful Post:
saltywetman (04-10-2022), soundman98 (04-09-2022)
Old 04-09-2022, 09:02 PM   #3
Sam86
Rear bumper part sure, if the only real difference with the diffuser is it’s wider, I still don’t see why that part I linked couldn’t fit assuming those 2 fins on either side of the fog light + the exhaust cut out locations were in the same place
When I messaged the place I hoped they would try test fitting it as if it does fit then it would expand their potential sales. They didn’t seem interested though :/
Old 04-09-2022, 11:49 PM   #4
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Site moderator, @ichitaka05, did it. It'll take some custom work to make it fit properly, but he did say he doesn't recommend it lol. Whether it's worth the trouble is up to you:
https://www.ft86club.com/forums/show...0&postcount=99
The Following User Says Thank You to NLSP For This Useful Post:
Sam86 (04-10-2022)
Old 04-10-2022, 02:18 AM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Correct, it does not fit at all. I highly NOT recommend it on zenki rear bumper to fit kouki rear lip. If you wanna go through same headache as me, you’re more than welcome to do so. End result is nice… but you’ll be cutting, fitting, more cutting & more fitting to get it the way it should be.
Sam86 (04-10-2022)
Old 04-10-2022, 09:19 AM   #6
Sam86
Thanks for clearing that up
I’ll give it more thought but I planned to pair it with the TRD quad exhaust garnish so I was already prepared to be doing some cutting.
Maybe I’ll try get a spare rear bumper from the wreckers and see if I can make it work
Old 04-10-2022, 09:50 AM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
If you gonna do that, mind as well get the kouki bumper. That’ll be easiest
Sam86 (04-12-2022)
DIY: pre-facelift to facelift steering wheel and cluster swap TRS DIY (Do-It-Yourself) Guides 16 10-22-2024 02:12 PM
GT86 2017 facelift bumper installed on pre-facelift 2015 model yoongjun Cosmetic Modification (Interior/Exterior/Lighting) 2 01-20-2021 11:28 AM
Facelift vs. non-facelift axlebacks alex87f Engine, Exhaust, Transmission 4 04-16-2020 09:26 PM
Facelift LED headlight to Pre facelift? teppei Cosmetic Modification (Interior/Exterior/Lighting) 0 09-17-2017 07:25 AM
TRD & TOM'S facelift Juvenile Scion FR-S / Toyota 86 GT86 General Forum 84 07-08-2016 07:52 PM
